HMG 3.4.4
Re: HMG 3.4.4
OK, I see; no problem!
Re: HMG 3.4.4
It looks like interactive close causes destroy of modal windows chain
Re: HMG 3.4.4
I FOUND SOURCE OF PROBLEM!!!
I've used phrase:
load window OknoZlecenia
show window OknoZlecenia
// initiate table aZlecenia
activate window OknoZlecenia
when I eleminate show window OknoZlecenia
everything works OK.
So, SHOW WINDOW causes problems I think.
Maybe Claudio can help? I don't know if we have new leader to work over HMG..
Re: HMG 3.4.4
Great !
Claudio is retired...
Re: HMG 3.4.4
I'm getting strange error:
BASE/1068  Incorrect argument: Incorrect number of arguments
(b)MAIN(706)
GETFORMHANDLE(3802)
BT_WINHANDLE(61)
BT_STATUSBARHANDLE(404)
BT_STATUSBARHEIGHT(424)
REPOSITIONTOOLBAR(421)
EVENTS(1502)
C_MSGSTOP(0)
SHOWERROR(181)
DEFERROR(129)
(b)ERRORSYS(66)
OBSLBLEDU(1577)
(b)MAIN(706)
GETFORMHANDLE(3802)
BT_WINHANDLE(61)
EVENTS(1502)
DOMESSAGELOOP(0)
_ACTIVATEWINDOW(5717)
While activating one of forms which has na TOOLBAR (I don't use it anywhere in this application)
This error occured after 8 hours of intensive work of my client :)
Re: HMG 3.4.4
Have you checked whether you can reproduce this error?
Re: HMG 3.4.4
No, I can't reproduce this.
It happened after few hours of work. Path of called functions is straight, no recursion. Activated form is first after main form.
I've tried to search problem in HMG sources, but without results.
franco
Re: HMG 3.4.4
Post by franco »
Re: close on the X button. I think I had the same problem before in 3.2.
At first to solve problem I created my own X button for releasing window. Then I found that if a grid had focus it would lock the program.
Now in 3.2 to get around problem when releasing window when in a grid I set focus off the grid first then release window.
Usually I set focus to a label, then release the window.
Hope this was same problem ............ Franco ;)
All The Best,
Franco
Canada
Re: HMG 3.4.4
I still can't reproduce this error.
I'm closing window with X, reopening, closing with ESC, closing programmatically, all looks OK.
Maybe after few hours garbage collection doesn't work good enough? Few months ago I've added CLEAN MEMORY after closing this function.
