Grid2Print - Suggestions
Source code related resources
Re: Grid2Print - Suggestions
Hello,
The idea is that you see prominently in the message samples in the status bar.
Greetings
Ok. I understand. :)
Here is the latest version of GridPrint.
Change log:
1. I had grouped all the message strings in an array to make it easy to translate into various languages.
2. The first item of the grid in "columns" page is selected by default. (Thanks a lot Esgici)
Now I am working on browse/grids with data types other than character string along with my wish list.
rathinagiri wrote: Here is the latest version of GridPrint.
Good job, thanks a lot Rathi.
rathinagiri wrote:Here is the latest version of GridPrint.
Change log:
Great!
I'll try to do the Spanish translation during weekend.
Change log:
I've downloaded but I can't find the message array. The messages appears to be simply declared in the controls, ie: (line 166):
value "Select the Columns in the Report"
ROberto.
Roberto Lopez wrote: I've downloaded but I can't find the message array. The messages appears to be simply declared in the controls, ie: (line 166):
Hi Roberto
IMHO this is first version. Sometimes file conflicts may appear in file servers.
My downloaded ( last ) version is different, include msgArray.
IMHO you have re-download.
Regards.
Change log:
Ok.
Attached is my humble contribution to grid2print.
I've translated interface messages to Spanish and added a 'Do Case' structure, similar to the others in HMG to suppor multiple languages automatically.
We need now the collaboration of users of native languages other than English.
I guess that we have some of them here :)
Local cLang
	cLang := Set ( _SET_LANGUAGE )
	// LANGUAGES NOT SUPPORTED BY hb_langSelect() FUNCTION.
	IF _HMG_SYSDATA [ 211 ] == 'FI'		// FINNISH
		cLang := 'FI'
	ELSEIF _HMG_SYSDATA [ 211 ] == 'NL'	// DUTCH
		cLang := 'NL'
	do case
        case cLang == "TRWIN" .OR. cLang == "TR"
	// TÜRKÇE
	private msgarr := {"Nothing to print",;
                   "No printers have been installed!",;
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Name of the Column",;
                   "Width (mm)",;
                   "Double Click a Column to toggle between selecting and not selecting for printing.",;
                   "Edit Text Column Size",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Report Properties",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Welcome to Print Wizard",;
                   "You had selected more columns than to fit in a page!",;
                   "You have to select a printer!",;
                   "Printer could not be selected! Check Availability of Printer.",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
                   "Size of Columns other than text type can not be modified!",;
                   "Justification constants not given properly.",;
        case cLang ==  "CS" .OR. cLang == "CSWIN"
	// CZECH
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "HR852"
	// CROATIAN
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "EU"
	// BASQUE
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "EN"
	// ENGLISH
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "FR"
	// FRENCH
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "DEWIN" .OR. cLang == "DE"
	// GERMAN
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
	case cLang == "IT"
	// ITALIAN
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "PLWIN"  .OR. cLang == "PL852"  .OR. cLang == "PLISO"  .OR. cLang == ""  .OR. cLang == "PLMAZ"
	// POLISH
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "PT"
	// PORTUGUESE
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "RUWIN"  .OR. cLang == "RU866" .OR. cLang == "RUKOI8"
	// RUSSIAN
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "ES"  .OR. cLang == "ESWIN"
	// SPANISH
	private msgarr := {"Nada para imprimir",;
                   "No hay impresoras instaladas!",;
                   "Asistente de Impresión",;
                   "Generador de Reportes",;
                   "Columnas",;
                   "Nombre de la columna",;
                   "Ancho (mm)",;
                   "Doble clic en una columna para seleccionar o deselecionarla para impresión",;
                   "Editar tamaño del texto de columna",;
                   "Ancho Total :",;
                   "out of",;
                   "Encabezado 1",;
                   "Encabezado 2",;
                   "Encabezado 3",;
                   "Pie de Página 1",;
                   "Propiedades del Reporte",;
                   "Tamaño de Fuente",;
                   "Línea larga",;
                   "Ajuste de Línea",;
                   "Truncar",;
                   "Paginación",;
                   "Apagado",;
                   "Superior",;
                   "Inferior",;
                   "Líneas de Grilla",;
                   "Columna",;
                   "Fila",;
                   "Centrado de Página",;
                   "Vertical",;
                   "Página/Impresora",;
                   "Orientación",;
                   "Horizontal",;
                   "Vertical",;
                   "Impresora: ",;
                   "Tamaño de Página",;
                   "Ancho de Página",;
                   "Altura de Página",;
                   "Márgenes (mm)",;
                   "Superior",;
                   "Derecho",;
                   "Izquierdo",;
                   "Inferior",;
                   "Imprimir",;
                   "Cancelar",;
                   "Bienvenido al asistente de Impresión",;
                   "Ha seleccionado más columnas de las que entran en una página!",;
                   "La impresora no puede ser seleccionada! Verifique la disponibilidad de la impresora.",;
                   "Página Nro. :",;
                   "Tamaño :",;
                   "Hecho",;
                   "EL tamaño de las columnas que no sean del tipo texto no pueden modificarse!",;
                   "Constantes de justificación no dadas apropiadamente.",;
        case cLang == "FI"
	// FINNISH
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "NL"
	// DUTCH
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
        case cLang == "SLWIN" .OR. cLang == "SLISO" .OR. cLang == "SL852" .OR. cLang == "" .OR. cLang == "SL437"
	// SLOVENIAN
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
	OtherWise
	// DEFAULT (ENGLISH)
                   "Print Wizard",;
                   "Report Writer",;
                   "Columns",;
                   "Width (mm)",;
                   "Total Width :",;
                   "out of",;
                   "Header 1",;
                   "Header 2",;
                   "Header 3",;
                   "Footer 1",;
                   "Font Size",;
                   "Lengthy Line",;
                   "Word Wrap",;
                   "Truncate",;
                   "Pagination",;
                   "Off",;
                   "Top",;
                   "Bottom",;
                   "Grid Lines",;
                   "Column",;
                   "Row",;
                   "Page Center",;
                   "Vertical",;
                   "Page/Printer",;
                   "Orientation",;
                   "Landscape",;
                   "Portrait",;
                   "Printer: ",;
                   "Page Size",;
                   "Page Width",;
                   "Page Height",;
                   "Margins (mm)",;
                   "Top",;
                   "Right",;
                   "Left",;
                   "Bottom",;
                   "Print",;
                   "Cancel",;
                   "Page No. :",;
                   "Size :",;
                   "Done",;
	endcase
Oh! Thanks a LOT Roberto. Does your day have more than 24 hours?! ;)
Ok; mine is here:
   // TÜRKÇE
   private msgarr := {"Yazdırılacak bir şey yok",;
                      "Kurulu yazıcı yok!",;
                      "Yazdırma Sihirbazı",;
                      "Rapor Yazıcı",;
                      "Sütunlar",;
                      "Sütun Adı"",;
                      "Genişlik (mm)",;
                      "Yazıcı seçimi için bir sütunu çift tıklayın",;
                      "Metin sütun genişliğini değiştir",;
                      "Toplam Genişlik :",;
                      "dışında",;
                      "Başlık 1",;
                      "Başlık 2",;
                      "Başlık 3",;
                      "Altlık 1",;
                      "Rapor Özellikleri",;
                      "Font Boyutu",;
                      "Uzun Satır",;
                      "Sözcük kaydır",;
                      "Kes",;
                      "Sayfalama",;
                      "Kapalı",;
                      "Üst",;
                      "Alt",;
                      "Izgara Satırları",;
                      "Sütun",;
                      "Satır",;
                      "Sayfa Ortalama",;
                      "Dikey",;
                      "Sayfa/Yazıcı",;
                      "Baskı Yönü",;
                      "Manzara",;
                      "Portre",;
                      "Yazıcı: ",;
                      "Sayfa Boyutu",;
                      "Sayfa Genişliği",;
                      "Sayfa Yüksekliği",;
                      "Kenar Boşlukları (mm)",;
                      "Üst",;
                      "Sağ",;
                      "Sol",;
                      "Alt",;
                      "Yazdır",;
                      "İptal",;
                      "Yazdırma Sihirbazına Hoşgeldiniz",;
                      "Sayfanın alabileceğinden fazla sütun seçtiniz!",;
                      "Bir Yazıcı Seçmelisiniz!",;
                      "Yazıcı seçilmedi! Yazıcı var mı denetle.",;
                      "Sayfa No. :",;
                      "Boyut :",;
                      "Tamam",;
                      "Metin türü dışında Sütun Boyutu değiştirilemez!",;
                      "Yanaştırma sabitleri düzgün verilmedi."  }
