Project Free HRD & Payroll Application
Re: Project Free HRD & Payroll Application
Gracias Agil por compartir estos buenos ejemplos...
Agil Thanks for sharing these good examples ...
Agil Abdullah
Post by Agil Abdullah »
Daniel,
Thanks for your appreciation.
Salam Hangat dari Jakarta
Programmer Never Surrender
Agil Abdullah
Let me share new development and exercises. Pls note that I decided to MOVE BACKWARD (restart from beginning), in
order to get them better designed. So, managing 3 Master Tables (Company, Unit, Department) must be completed in full control and well designed. Then move to redesign master tables Manpower (Basic, Background, Biodata).
Pls also note this schedule:
..... OCTOBER 2014 - Completion of Master Tables
..... NOVEMBER 2014 - Completion of Payroll Transaction
..... DESEMBER 2014 - Completion of features and options
..... JANUARY 2015 - Ready to fully install & implement
...... FEb 2015..... - Improvement every month to reach maximum quality with HMG
(with bonuses include: Bostaurus, Richedit, ActiveX, important SAMPLES, excellent friend's shares)
Every advice, suggestion, help, comment, (and whatever) is highly appreciated with close attention. I will share newly full-attachment of source-progs when this Master Tables routines are completed and tested; to avoid improper attachment you do not want to see.
Regarding split box as shown before this with 3 Tables in one full window and no space remaining. You may find question; how to do dataentry/display in window, not within grid cell just like MS-Excel? Below screenshoot is the answer. Along with sample codes. Hopefuly, useful for beginners and students (especially in my country Indonesia).
Regards,,,,
Agil Abdullah
***mancomped.fmg*** (sample pieces) Window Template generated with IDE
* HMG-IDE UNICODE Form Designer Generated Code
DEFINE WINDOW TEMPLATE AT 143 , 386 WIDTH 438 HEIGHT 453 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "Company Record" ICON NIL CHILD
NOMAXIMIZE NOMINIMIZE NOSYSMENU CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON
MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR {142,238,150} NOTIFYICON NIL NOTIFYTOOLTIP NIL ON
NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX
Nil ON VSCROLLBOX Nil
    DEFINE LABEL Lab_Compcode
        ROW    20
        COL    20
        WIDTH  120
        HEIGHT 24
        VALUE "Company#"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .T.
        FONTITALIC .T.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        VISIBLE .T.
        TRANSPARENT .F.
        ACTION Nil
        AUTOSIZE .F.
        FONTCOLOR NIL
        RIGHTALIGN .T.
    END LABEL
    DEFINE TEXTBOX Text_Compcode
        ROW    20
        COL    160
        WIDTH  30
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ONCHANGE Nil
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONENTER Nil
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .F.
        RIGHTALIGN .F.
        DISABLEDBACKCOLOR Nil
        DISABLEDFONTCOLOR Nil
        CASECONVERT UPPER
        MAXLENGTH 2
        BACKCOLOR NIL
        FONTCOLOR NIL
        INPUTMASK Nil
        FORMAT "'!!'"
        VALUE ""
    END TEXTBOX
//--- the rest (in the middle) are repetations of above definition with different control-name,
//--- with ROW pos different at 30 line each
    DEFINE RADIOGROUP Radio_Company
        ROW    370
        COL    60
        WIDTH  250
        HEIGHT 28
        OPTIONS { 'Accept','Cancel'}
        VALUE 1
        FONTNAME "Arial"
        FONTSIZE 18
        TOOLTIP ""
        ONCHANGE Nil
        FONTBOLD .T.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        SPACING 125
        BACKCOLOR {0,128,64}
        FONTCOLOR {0,0,255}
        READONLY Nil
        HORIZONTAL .T.
    END RADIOGROUP
    DEFINE BUTTON Button_Go
        ROW    365
        COL    320
        WIDTH  70
        HEIGHT 40
        ACTION  ( MancompGetentry(.T.), MancompGetoption(.T.), MancompValidateentry() )
        CAPTION "GO"
        FONTNAME "Arial"
        FONTSIZE 18
        TOOLTIP "Go To Process"
        FONTBOLD .T.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .T.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
**manmastbl.prg (sample pieces)
* Activate/Deactivate Form Company Data entry
* Flag .T. activate/show, .F. to Hide
Function ManActivateCompEntry(Flag)
    IF Flag==.T.
        if .not. isWindowdefined(Form_MancompEntry)
	     LOAD WINDOW Mancomped AS Form_MancompEntry
        if  isWindowdefined(Form_MancompEntry)
            //-optional method: release, hide, disabled=.T.
	    Form_MancompEntry.hide
* COMP: Edit company's existing record
* Grid value (row post) return in array (row, col) because option CELLNAVIGATION is used
Procedure ManEditCompany()
    LOCAL cKey, aInitvalues, aResults, nRecord
    //---Send&Set mode of operation to Update=2
	 MancompEntrymode( .T. , 2)
    //---get record from grid
	 nRecord  := Form_Master.Grid_Company.value[1]
	 aResults := aInitValues:= Form_Master.Grid_Company.item(nRecord)
    //---Activate template, Send record to template, get user entry, do validation from template
    //---Protect key-field Compcode from editing
	 ManActivateCompEntry(.T.)
         MancompSetentry (aResults)
	 Form_MancompEntry.Text_compcode.Readonly:=.T.
         Form_MancompEntry.Text_compname.Setfocus
	 Form_MancompEntry.Activate
	//--if ACCEPT then check entry option & Validation of entry
	IF MancompGetoption() == 1 .and. MancompValidateentry(.T.)==.T.                          //Option ACCEPT & Valid entry
  	   aResults := MancompGetentry(.F.)
	    RETURN .F.
	If .not.Msgyesno("Update record?")        //to test only
	    return .F.
	//--Edit records to Database, Sent modified records to Database
        //--Make sure field length of key-field is exactly equal to field length in Database
        cKey:= padr( aResults[COMP_KEY_COL]), COMP_KEY_COL )
        IF ManCompUpdate(aResults, cKey)
	   //--go ahead
	    Msgstop('Error: Upadate record to Company Database')
 	    Return .F.
        //--Edit modify Array of records in grid
	Form_Master.Grid_Company.Item(nRecord) := aResults
        Form_Master.Grid_Company.Setfocus
* COMP: Validate data entry
* lGetValid : .T. to get value of lValid, else to do validation
* lValid    : .T. oke, .F. wrong
* nEntryMode: 1=Add/Update, 2=Update
Function MancompValidateentry(lGetValid)
    STATIC lValid   := .F.
    Local aResults  := MancompGetentry(.F.)
    Local nEntryMode:= MancompEntrymode(.F.)
	IF .not.lGetValid == NIL .and. lGetValid==.T.	                                      //Get last validation value
            Return lValid
	lValid := .F.
	IF MancompGetoption() == 2                                                            //CANCEL
            Form_MancompEntry.release
            Return ( lValid := .F. )
	ElseIF MancompGetoption() == 1                                                            //ACCEPT entry
	    //--NOT Valid for Append & Update
	    if empty( aResults[COMP_KEY_COL]) .or. empty( aResults[2])
                MsgExclamation('Invalid empty entry on Code or Name')
                Form_MancompEntry.Text_compcode.Setfocus
	    elseif  aResults[COMP_KEY_COL] = "**" .or. left(aResults[2], 1) = "*"
                MsgExclamation('Invalid entry ** on Code or Name')
           //--NOT Valid for Append only
	    elseIF nEntryMode==1 .and. ManFindCompGrid( aResults[COMP_KEY_COL] ) >= 1
                MsgExclamation(aResults[UNIT_KEY_COL] + ' already exists in grid.')
	        lValid := .T.
	    Endif
Return lValid
* Find existing record of Company in Grid
Function ManFindCompGrid( cKey )
    Static nRow := 0
    Local nRecNo := 1, i:=0
	FOR i=1 TO Form_Master.Grid_Company.ItemCount
	    if HMG_UPPER( Form_Master.Grid_Company.CellEx(i, COMP_KEY_COL) ) == cKey
               nRecno := nRow := i
                              //--test	Msginfo("found at grid rec#" +str(i))
		EXIT
    IF nRecNo>0
        Form_Master.Grid_Company.value :=nRecNo                        //found, move pointer of grid
	Form_Master.Grid_Company.value :=nRow                          //pointer to last record-search found
Return nRecNo
* COMP: Set/Fill in form for data entry
Function MancompSetentry(aValues)
        Form_MancompEntry.Text_compcode.value  := aValues[1]
	Form_MancompEntry.Text_compname.value  := aValues[2]
	Form_MancompEntry.Text_compctx.value   := aValues[3]
	Form_MancompEntry.Text_compaddr.value  := aValues[4]
	Form_MancompEntry.Text_compaddr2.value := aValues[5]
	Form_MancompEntry.Text_compcity.value  := aValues[6]
	Form_MancompEntry.Text_compzip.value   := aValues[7]
	Form_MancompEntry.Text_comptelp.value  := aValues[8]
	Form_MancompEntry.Text_compfax.value   := aValues[9]
	Form_MancompEntry.Text_compemail.value := aValues[10]
	Form_MancompEntry.Text_compweb.value   := aValues[11]
* COMP: Get/Fill in form for data entry
Function MancompGetentry(lNew)
    STATIC aValues[11]
	if lNew
                aValues[1]:= Form_MancompEntry.Text_compcode.value
		aValues[2]:= Form_MancompEntry.Text_compname.value
		aValues[3]:= Form_MancompEntry.Text_compctx.value
		aValues[4]:= Form_MancompEntry.Text_compaddr.value
		aValues[5]:= Form_MancompEntry.Text_compaddr2.value
		aValues[6]:= Form_MancompEntry.Text_compcity.value
		aValues[7]:= Form_MancompEntry.Text_compzip.value
		aValues[8]:= Form_MancompEntry.Text_comptelp.value
		aValues[9]:= Form_MancompEntry.Text_compfax.value
		aValues[10]:= Form_MancompEntry.Text_compemail.value
		aValues[11]:= Form_MancompEntry.Text_compweb.value
Return aValues
* COMP: Get/Set Option dataentry: Accept=1, Cancel=2
Function MancompGetoption(lSetNew)
    STATIC nOption:=0
	lSetnew := if(lSetnew==NIL, .F., lSetNew)
	if lSetNew
	    nOption:=Form_MancompEntry.Radio_Company.value
	    nOption := if( .not.Valtype(nOption)="N", 0, nOption)
Return nOption
* COMP: Get/Set Mode of dataentry: 0=No action, 1=Add/append, 2=Update, 3=Delete, 4=Copy-to-append
Function MancompEntrymode(lSetNew, nModeValue)
    STATIC nMode:=0
	if lSetNew
	    nMode:= nModeValue
Return nMode
Suggestion: keep 10 field as user defined so user can define, store data and use same filed for reporting
Download payroll program that will give you more idea
http://www.busywin.com/busydata/PAY%201 ... /SETUP.EXE
Agil Abdullah
Bpd2000 wrote;
http://www.busywin.com/busydata/PAY%201.0%20(k-4" onclick="window.open(this.href);return false;)/SETUP.EXE
Man thanks for kind suggestion. But, I failed to download your link. I stoped downloading before it finished.
Agil Abdullah
For Roberto Lopez,,,
I tried to execute your above sample codes for connecting Server NETIO. But, error found like this screenshoot. May be, codes I modified made some mistakes. Pls kindly help.
Regards.
#include "hmg.ch"                                                          //added by Agil
REQUEST HB_GT_WIN_DEFAULT                                        //added by Agil
Procedure Main                                                              //added by Agil
   ServerMain()                                                              //added by Agil
Return        //added by Agil
* On side of Server Application (console, multi-threaded in this sample):
Procedure Servermain()                                                   // changedd by Agil..... Procedure main()
   local pSockSrv , nPort , cIfAddr, cRootDir, lRPC, cPasswd, nCompressionLevel, nStrategy
   SetMode(25,80)                                                          // added by Agil
   cls
   nPort        := 65000 // or anyone you like
   cIfAddr      := '0.0.0.0'
   cRootDir     := '.'
   lRPC         := .T.
   cPasswd      := 'secret'
   nCompressionLevel   := 9
   nStrategy      := NIL
   pSockSrv := NETIO_MTSERVER( nPort , cIfAddr , cRootDir , lRPC , cPasswd , nCompressionLevel , nStrategy )
   if empty( pSockSrv )
      ? "Can't startl server !!!"
      wait "Press any key to exit..."
      quit
   ? 'NETIO Server Started!'
   hb_idleSleep( 0.1 )
   DO WHILE .T.
      INKEY(0)
      IF LASTKEY() == 27 // Esc
         ? 'Stopping... ESC to stop'
         netio_serverstop( pSockSrv, .t. )
         EXIT
         LOOP
   ENDDO
   CLS
   ALERT('SERVER STOPPED!')
return
Agil ,
Try with port 2941.
Agil Abdullah
Serge,
Set to port 2941, error remained the same.
FYI, I found it (a test) working when using codes of Extended Harbour from folder
Minigui\ SAMPLES\NETIO\NETIO-2. While SAMPLES\Misc\NETIO from HMG331 not working.
Thanks
Agil,
With me it is working fine since a week.
Maybe it is you firewall?
S
