HMG_HPDF - Export to PDF made easy... (New Version)
bpd2000 wrote:...URL link working in Acrobat Reader
Must be a difference; Reader version, reader settings even OS settings :?
rathinagiri wrote:Duly noted and coded. Will be released in the next version.
Thanks.
rathinagiri wrote:Regarding the tooltip I didn't understand about the space you have mentioned. The sample is working fine for me in Sumathra.
When icons placed vertically and successive, tooltips not seen other than last one:
Vertically placed icons
1: Cursor is on last icon; 2: Cursor is on first icon.
In fact tooltip come, but for a very short duration; seen as not came.
When icons placed Horizontally and successive, all tooltips seen:
Horizontally placed icons
1: Cursor is on first icon; 2: Cursor is on 2nd icon.
By the way, does Sumatra PDF Reader is better than Acrobat ?
Formerly I was installed an tried for a short time and as far as remember, it haven't any significant advantage than Adobe reader.
If you recommend, for cooperation, we all can use Sumatra.
But my opinion is Adobe have a superiority as user count and personally I don't guess that one of my users know Sumatra ;)
With mu best regards
On seeing your pics, I can assume that, these icons are inside the reader themselves and not in the library.
See the icon sets in Sumatra.
In Sumatra it is working fine. I don't know how and why!
I don't think so. However, I prefer using Open Source software over copyrighted software. I prefer LibreOffice over MS Office and so on. That is my personal preference.
Sumatra's benefits that I feel:
1. Small footprint in memory.
2. Just having the required functionality. Nothing more nothing less.
3. Portable
4. Open source
rathinagiri wrote:Regarding the Adobe Acrobat security block, you can remove it using the methods mentioned here.
This setting really helped, thanks.
rathinagiri wrote:In Sumatra it is working fine. I don't know how and why!...
... I prefer using Open Source software over copyrighted software. I prefer LibreOffice over MS Office and so on.
OK, all right ...
Cooperation is more important than personal preferences ;)
Sumatra pdf reader installed, made default pdf reader and all problems gone away :)
Now it's time to advance ahead :arrow:
TIA
Best regards
Here comes a new version with 3 new features:
pdf.zip
(283.91 KiB) Downloaded 304 times
1. HMG_HPDF_PageNo() -> nCurPage
2. SET HPDFINFO AUTHOR|CREATOR|TITLE|SUBJECT|KEYWORDS|DATECREATED|DATEMODIFIED TO xValue [ TIME cTimeString ]
3. GET HPDFINFO AUTHOR|CREATOR|TITLE|SUBJECT|KEYWORDS|DATECREATED|DATEMODIFIED TO cVariable
I think all the features are self explanatory. TIME clause is effective only with DATECREATED or DATEMODIFIED clause.
rathinagiri wrote:Here comes a new version with 3 new features:
pdf.zip
Thank you, most important requirement for automation
Thanks, Impressive :)
Is there a way referencing a point ( tag / header / paragraph / anything else ) other than page / page no ?
TIA
A new version with a small feature:
pdf.zip
(284.79 KiB) Downloaded 307 times
New command is:
SET HPDFDOC PAGENUMBERING [ FROM nPage ] [ STYLE DECIMAL|ROMAN|LETTERS ] [ UPPER|LOWER> ] [ PREFIX cPrefix ]
This command is used in thumbnails and page numbering.
1. You can start numbering from any page.
2. If the style selected is Roman or Letters, you can use Upper/Lower.
3. If the prefix clause is included, the numbering will have the prefix.
Example:
SET HPDFDOC PAGENUMBERING FROM 2
SET HPDFDOC PAGENUMBERING STYLE ROMAN
SET HPDFDOC PAGENUMBERING STYLE ROMAN LOWER PREFIX "PAGE: "
TIA
If I am correct, you want to hyperlink to an image or paragraph or text inside a document.
I think not. There is only a page link. So the destination can only be a page.
rathinagiri wrote: If I am correct, you want to hyperlink to an image or paragraph or text inside a document.
Yes, hyper or not ;)
rathinagiri wrote: I think not. There is only a page link. So the destination can only be a page.
Bad news :(
Who know, mayhap a day ...
TIA
rathinagiri wrote:New command is: SET HPDFDOC PAGENUMBERING ...
Very good, thanks :)
TIA
