Edit Extended / Edit WorkArea - ABM / ABM2
t57042
Re: recordlocking
Post by t57042 »
My problem is not that I do not understand the different locking methods.
I want the EDIT EXTENDED to work with 'prelocking' - but I don' t know how to adapt the code.
Richard
Re: recordlocking
Hi Richard
Something like this does will help you ?
Screen shoot for Edit Extended with pre-lock
EditRExtCB19.zip
Source files for Edit Extended with pre-lock
(37.99 KiB) Downloaded 328 times
t57042
Re: recordlocking
Post by t57042 »
Hi Esgici,
Very nice job, I just had the time for a quick first look... some rermarks:
1. When a user Cancels or OK a record that is edited the record should be immediatly UNLOCKED (I think it stays locked until other record is selected)
2. When a user intends to add a NEW record (append blank) other users get (sometimes) RECORD LOCKED. Other users must do another append blank and lock that one.
The way it works now, only one user can enter new data.
3. When deleting a record I sometimes get: "record locked by another user" (something left from original code?)
4.. The text could be: Record is locked by another user; please try again.
Best regards
Richard
t57042
Re: recordlocking
Post by t57042 »
t57042 wrote:Hi Esgici,
Best regards
Richard
I had a little more time and figured finally out how the .CH system works.
I already corrected points 1 and 4.
I get back when have more.
Richard
Re: recordlocking
t57042 wrote: I had a little more time and figured finally out how the .CH system works.
Good news :)
OK, I'll wait.
t57042
Re: recordlocking
Post by t57042 »
Hello,
Included is zip file containing changes for Prelock of records in multuser network:
1. When opening dbf check is made to see if file is not exlusively in use by someone else.
2. When adding, deleting and editing a record it is locked before action
and unlocked when saving (or cancel) the action.
Richard
edit_ex.zip
(37.08 KiB) Downloaded 358 times
Re: recordlocking
Good :)
Thanks to share.
t57042
Edit Extended
Post by t57042 »
The language selection doesn't seem to work here.
I tried to set it with HB_LANGSELECT in the sourcecode and with the 'language select' option in the menu.
Always get english.
How does it work?
Where is the sourcefile with the differnet language texts?
Richard
t57042
Re: edit (R)extended
Post by t57042 »
With version 3.0.28 it works - with version 3.0.48 it doesn't?
t57042 wrote:With version 3.0.28 it works - with version 3.0.48 it doesn't?
It's just time of jump to UT8 ;)
