Thanks.dhaine_adp wrote:Hi Roberto,So, the support for parameters in grid's create method is out of HMG.4 design.
Regarding other possible things, this is an early version yet to get some other conclusions.
OK. I'll post the changes here again.
Danny
Welcome to the Project Developers' Table
- HMG Founder
Re: Welcome to the Project Developers' Table
- HMG Founder
Hi Team,
I've uploaded the first version of Tab control (we finally can nest tabs!!!:)).
Currently only EditBox and Button are supported.
Please, do the following modification in your controls to get Tab support too:
In the create() method, please, change the Qt object creation to have two alternative parents in the case that a parent tab been specified.
IE, for Editbox I've changed in the following way:
Thanks!
* Create QT Object and other initialization tasks
If valtype( ::oContainer ) == 'U'
::oQTObject := QTextEdit():new( ::oParent:oQTObject ) * <- ORIGINAL
Else
::oQTObject := QTextEdit():new( ::oContainer:oQTObject )
EndIfThanks!
Thanks Roberto CheckBox and DatePicker are added to Tab.
That, really is a great news!we finally can nest tabs!!!:)
I have always tried with .jpg and gif files.Roberto Lopez wrote:Forgot your additions to demo4.prgmol wrote:Hello Roberto!
I've commited my code for IMAGE class souce\label.prg and samples\demo_1.prg
It won't work, but, maybe later, I'll find few minutes to work over it.
It takes only two lines of code to instruct to current label class to show an image instead a text.
Go to label.prg and about line #179 add this:
Of course, 'save.png' must be located at your test app folder.Code: Select all
<...> if ValType (::lAutoSize) != 'U' ; Self:AutoSize := ::lAutoSize ; endif qPixmap := QPixmap():new( "save.png" ) * <- NEW CODE ::oQTObject:setPixmap( qPixmap ) <- NEW CODE // set default label word wrapping to .T. <...>
You could copy the current LABEL.PRG into IMAGE.PRG and start the new image class around it. Eventually, later the image class could be optimized to inherit from label, so, saving code, but now we have more important things in mind, like make it work first
And now, I've observed qpixmap() works directly only with .png and .bmp files
two days of searching, wrrr
Maybe there is a bug in QT?
I've found in QT doc something like that:
Reading and writing SVG files is supported through Qt's SVG Module.
To configure Qt with GIF support, pass -qt-gif to the configure script or check the appropriate option in the graphical installer.
See also setFormat(), QImageWriter::supportedImageFormats(), and QImageIOPlugin.
- HMG Founder
Welcome to my worldmol wrote: <...>
As I've already pointed, I've just learning about QT, step by step, as it is needed, so, I have not an answer for you about this right now.mol wrote: Maybe there is a bug in QT?
I've found in QT doc something like that:Reading and writing SVG files is supported through Qt's SVG Module.
I'll start to research about this issue and if some appears, I'll keep you posted.
I'm still lerning QT and reading documentation.
IMAGE is realized, maybe not ended, but working with PNG images.
I think, I can take next control to create. Please assign me next job!
- HMG Founder
Ok.mol wrote:I'm still lerning QT and reading documentation.
I guess that Combobox is free, so you could work on it.
You could need to synchronize your work with rathinagiri, sin he is working on listbox and maybe you can share code for some properties.
- HMG Founder
Anyway...Roberto Lopez wrote:Ok.mol wrote:I'm still lerning QT and reading documentation.
My sample works with gif files.
If you change the current label code adding the following code in Create() method.
qPixmap := QPixmap():new( "hmg.gif" ) * <- NEW CODE
::oQTObject:setPixmap( qPixmap ) * <- NEW CODE
<...>hmg.gif, will be show instead label text.
So, gifs are directly supported.
- HMG Founder
The same applies to .jpg files.Roberto Lopez wrote: Then go to label samples folder, copy on it the hmg.gif file and compile the demo_1.
I've changed references to hmg.gif by hmg.jpg and works perfectly.
