HMG 3.4.4
Re: HMG 3.4.4
You're welcome, Marek.
I don't use IDE anymore since it crashes to often. And FMG is not my thing.... I'd rather keep it in my PRG!
Re: HMG 3.4.4
Hi Serge!
You keep everything in PRG and such a situation happens to you, so, it's HMG error, I think.
Re: HMG 3.4.4
This solution works ok in above sample, but in my application not. What's going on?
Re: HMG 3.4.4
I've checked. It's strange - there was no MAIN declaration - forn created by IDE.
I've added, but without positive results.
Re: HMG 3.4.4
Marek,
If IDE changes FMG then close IDE, check FMG and try to compile with bat-file.
Re: HMG 3.4.4
Ide changes fmg file during save operation
Re: HMG 3.4.4
I've tested this wrong behaviour with HMG341 and works bad, too
I must install new version today and only one solution is to move window definitions to prg file. Stupid work...
It's strange but moving code to prg does not give solution to problem.
I've added timer to main form, which call function WhereAmI() which puts active form name in status bar
After closing my modal form, GetActiveWindow() returns 0 - it should be MainForm handle in my opinion. So, what causes such a strange behaviour?
function WhereAmI()
local hWin := GetActiveWindow()
local i
local cFormName := ""
i:= ascan( _HMG_SYSDATA[67], hWin)
if i>0
cFormName := _HMG_SYSDATA[66][i]
MainForm.StatusBar.Item(1) := cFormName + " "+str(hWin)+ " " + time()
return .t.
Re: HMG 3.4.4
Marek,
if you want to share complete source in order to debug, please use Private Message!
Re: HMG 3.4.4
Thank you Serge, it's huge application and it will be hard to you to debug thi because of language barrier
