Grid2Print - Suggestions
Re: Grid2Print - Suggestions
My wishlist for Grid Print:
1. Auto adjustment of default fontsize, orientation, lengthy line word wrap.
2. Saving the settings of each grid called by print method in an ini file like gridprint.cfg, so that every time you need not adjust the settings for that grid.
3. Print Grid Command in addition to plain print method with the parameters
a. Font name, size
b. Paper size, orientation
c. widths (mm) in array
syntax: PRINT GRID cGrid OF cWindow FONT cFontName SIZE nSize PAPERSIZE PRINTER_PAPER_LETTER ORIENTATION PRINTER_ORIENT_PORTRAIT WIDTHS aWidths
Any other suggestions?
Thanks.
a. Font name, size
Thanks.
- HMG Founder
Since you are the author, I guess that you will make real these dreams for usrathinagiri wrote:My wishlist for Grid Print:
a. Font name, size
Thanks.
GREAT!
Anybody had checked the new version?rathinagiri wrote:Here comes the new version. It can be downloaded from here.
Change Log:
1. No parameter is now required for the print method. Just call Form1.Grid1.Print(). Thanks a lot Roberto.
2. Wordwrap option is now available for longer text. For text columns, you can increase/decrease the column size (in mm) using the small button near the column selection table. (see the image) Select wordwrap option in Report Properties.
Please give your suggestions and bug reports. Thanks.
Set Language to Spanish
Muy Impresionante tu trabajo rathinagiri, aqui uno se da cuenta de que nos falta mucho por aprender, te felicito.
Duda
con un Browse podria funcionar
Set Language to English ( Powered By Google )
Very Impressive rathinagiri your job, here one realizes that we lack a lot to learn, I congratulate you.
Doubt
It could work with a Browse
Duda
Doubt
Thanks jrendon.
It is now working on grid. I am planning to extend this to browse also. As of now, browse is not supported.
- HMG Founder
Please consider to put interface messages in an array, to allow easy translation as HMG does, so it could work woth 'Set language To'.
When this be ready, I'll offer myself for Spanish language translation.
Thanks Roberto. I will do it and post soon.
Hi Rathirathinagiri wrote: Anybody had checked the new version?
Sorry for delay
Congratulations, we gained a new tool; many thanks to your efforts.
By adding UCI, wordwrapping and line size editing features and minimizing main/test prg your work has been perfect.
TODO list and suggestions will never end. In fact, computer programs will never terminate; only we use it beginning anywhere, any time.
A little "thing" :
When "Print" button clicked on "main" grid page, "Columns" page open without any selected line. User may don't know that before clicking "Edit text column size", one of lines must be selected in the "Columns" page. In this case, "Edit text column size" button does nothing, left inactive. This is very bad situation by user viewpoint. There may be many way for avoiding this and surely you will select the best.
- luisvasquezcl
Hello rathinagiri
Excellent work.
We suggest if you can enable a table for messages or gridprint the highlights in the statusbar as for example when it displays the message "You Had selected more columns than to fit in a page" until you realize not start reading anything that appears on the window is not looking that activates the print button.
Congratulation again.
Hola rathinagiri
Excelente trabajo.
Te sugiero si puedes habilitar un cuadro para mensajes del gridprint o lo destaques en el statusbar ya que por ejemplo cuando muestra el mensaje "Se ha seleccionado columnas más largas que la pagina" no te das cuenta hasta comenzar a leer todo lo que aparece en la ventana buscando por que no se activa el botón imprimir.
Felicitaciones nuevamente.
Saludos cordiales,
Luis Vasquez
Excellent work.
Hola rathinagiri
Excelente trabajo.
Saludos cordiales,
Luis Vasquez
I am sorry I cannot understand what you are pointing out.We suggest if you can enable a table for messages or gridprint the highlights in the statusbar as for example when it displays the message "You Had selected more columns than to fit in a page" until you realize not start reading anything that appears on the window is not looking that activates the print button.
