Project Free HRD & Payroll Application
gvaronas
Re: Project Free HRD & Payroll Application
Post by gvaronas »
Ok. I understand.
Thank you
BestRegards
GVS
Roberto Lopez wrote:
gvaronas wrote:Hola Roberto:
Tal como lo haz explicado es realmente muy sencillo el uso de NetIO.
Mis dudas están por el lado de la aplicación del servidor, en el ejemplo que haz descrito no utilizas el hbnetio.exe que viene con la distribución de harbour, en su lugar haz creado tu propia aplicación servidora.
¿Qué ventajas y/o desventajas implica el uso del servidor que viene con la distribución de harbour?
[Google]
Hi Roberto:
As explained beam is actually very simple to use netio.
My doubts are on the side of the server application, in the example you've described does not use the hbnetio.exe that comes with the distribution of harbour, in the beam spot created your own application server.
What advantages and / or disadvantages associated with using the server that comes with the distribution of harbor?
TIA
BestRegards
GVS
I've not tested NETIO server included with Harbour, but I'm sure that it is ok.
Simply, I like to have more control over things, so, I've preferred to create my own server, to add to it a customized logs, interface, etc.
Roberto,
Can you explain how to let NETIO working with MySQL?
Thx,
Roberto,
In the mean time I found out...
So never mind my previous question!
S
Agil Abdullah
Post by Agil Abdullah »
I am very sorry to tell you that I am late to reply last comments. This because I've been working hard to finish revised codes as required by you.
I'll be back some day this week with new attachment and explain things when neede ( and all reply all comments).
Many-many thanks to you all.
Programmer Never Surrender
Agil Abdullah
Many thanks for advices, comments, etc From:
- Serge Girard
- gvaronas
Today, I am finishing to separate GUI CODES from DBF handles (non-GUI) by creating new *.prg dan *.Fmg to make them easy to organize. But, suddenly error found in compiling. As if I made double functions, in fact I did not:
Harbour 3.2.0dev (r1407111333)
Copyright (c) 1999-2014, http://harbour-project.org/" onclick="window.open(this.href);return false;
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf01.o:mandbf01.c:(.text+0x0): multiple definition of `HB_FUN_OPENMANBIO'
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o:manpower.c:(.text+0x40): first defined here
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf01.o:mandbf01.c:(.text+0x20): multiple definition of `HB_FUN_OPENMANBACK'
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o:manpower.c:(.text+0x60): first defined here
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf01.o:mandbf01.c:(.text+0x40): multiple definition of `HB_FUN_OPENMANBASIC'
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o:manpower.c:(.text+0x80): first defined here
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf01.o:mandbf01.c:(.text+0x60): multiple definition of `HB_FUN_MANREINDEXDATABASE'
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o:manpower.c:(.text+0xa0): first defined here
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf01.o:mandbf01.c:(.text+0x80): multiple definition of `HB_FUN_MANDATAINTEGRITY'
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o:manpower.c:(.text+0xc0): first defined here
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf01.o:mandbf01.c:(.text+0xa0): multiple definition of `HB_FUN_LOCKMANCTRFILE'
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o:manpower.c:(.text+0xe0): first defined here
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf91.o:mandbf91.c:(.text+0x0): multiple definition of `HB_FUN_MAN01SAVEDATAENTRY'
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o:manpower.c:(.text+0x0): first defined here
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf91.o:mandbf91.c:(.text+0x20): multiple definition of `HB_FUN_MAN01DATAENTRY'
C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o:manpower.c:(.text+0x20): first defined here
hbmk2[manpower2]: Error: Running linker. 1
gcc.exe C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower2.o C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manpower.o C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manbio.o C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manback.o C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manlib.o C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf01.o C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manedit01.o C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/mandbf91.o C:/Users/toshiba/AppData/Local/Temp/hbmk_bxkw1n.dir/manbostaurus.o
As I remember this need a "cleaning thing" when building, but I don't know how to do it. Pls kindly help.
Best Regards.
Agil Abdullah
Ok. I can overcome the build/compile error. It^s my own mistake when putting progs in *.hbp file.
Agil Abdullah
Up to day, I finished some Master Tables as you can see on screenshoot below. This time we do exercises with Split Window/Box and many more.
And some modifications been made briefly as follows:
- Keyfield Company to name COMPCODE, CHARACTER, 2 LENGTH
- Keyfield Unit to name UNITCODE, CHARACTER, 2 LENGTH
- Keyfield Department to name DEPTCODE, CHARACTER, 4 LENGTH
These must be consistant in every tables to ensure connectibility between all tables.
The codes was written as suggestd by Roberto Lopez:
- Separate GUI codes from non-GUI and dbf-handling codes, placed in separates prog-files.
This is to make easy to evolve to MySQL in futher development
- Data entry/Query is organized to retrieve&save records from/to DBF, then placed in Array, then deploy into grid.
So no live data is used in Grid, instead use Recordset. This is for preparation to use NETIO for further development.
But sorry, Source codes is not attached this time coz i Need time put togather pieces of files needed to share. This time is 2 and half o'clock in the morning Jakarta Time.
Best Regards
Agil Abdullah wrote:...
Thanks to share, Agil.
I will wait eagerly the continuation :arrow:
Agil Abdullah
Many-many thanks to Esgici for kind attention.
I will finish this project scheduled to be ready to fully implemented at beginning of 2015. May be developed in 2 or 3 versions to accommodate users' specific need.
Cheers. :D :D
Agil Abdullah
Before I put in latest attachment of source progs in full and new data structures in full, let me share pieces of codes of how I did exercises with Split Window/Box as seen at obove screenshoot. May be useful for beginners.
Salam Hangat dari Jakarta.
**manmastbl.prg** (topmost pieces)
#include "i_color_nvo.ch"
//--Open dbf method-set
#Define D_SHARED        .F.
#Define D_EXCLUSIVE     .T.
#Define D_WAIT           1
#Define D_READWRITE     .T.
#Define D_READONLY      .F.
SET CENTURY ON
SET DELETED OFF
SET DATE TO BRITISH
#Define COMP_KEY_COL     1
#Define COMP_KEY_LEN     2
#Define UNIT_KEY_COL     1
#Define UNIT_KEY_LEN     2
#Define DEPT_KEY_COL     1
#Define DEPT_KEY_LEN     4
* Edit Master Tables (Company, Unit, Department)
Function ManEditMasterTables()
        PRIVATE aCompHeaders
	PRIVATE aCompRecords
	PRIVATE aCompWidths
	PRIVATE aCompControls
	PRIVATE aUnitHeaders
	PRIVATE aUnitRecords
	PRIVATE aUnitWidths
	PRIVATE aUnitControls
	PRIVATE aDeptHeaders
	PRIVATE aDeptRecords
	PRIVATE aDeptWidths
	PRIVATE aDeptControls
	Private nMainWidth := getdesktopwidth()*0.90
	Private nMainHeight:= getdesktopheight()*0.50
	Private bBackcolor, bFontcolor
	Private isCompanyActive, isUnitActive, isDeptActive
	//--initial startup set active to Company Table Grid
	isCompanyActive := .T.
	isUnitActive    := .F.
	isDeptActive    := .F.
	//--Grid get-settings
	aCompHeaders  := Mangetcomphead()
	aCompRecords  := Mangetcomprecord( "ALL" )
	aCompwidths   := MangetcompWidth()
	aCompControls := MangetcompControl()
	aUnitHeaders  := MangetUnithead()
	aUnitRecords  := MangetUnitrecord( "ALL" )
	aUnitwidths   := MangetUnitWidth()
	aUnitControls := MangetUnitControl()
	aDeptHeaders  := MangetDepthead()
	aDeptRecords  := MangetDeptrecord( "ALL" )
	aDeptwidths   := MangetDeptWidth()
	aDeptControls := MangetDeptControl()
    bBackColor := { || if ( This.CellRowIndex/2 == int(This.CellRowIndex/2) , {128,128,128} , {192,192,192} ) }
    bFontColor := { || if ( This.CellRowIndex/2 == int(This.CellRowIndex/2) , BLUE , RED ) }
    CellNavigationColor (_SELECTEDCELL_FORECOLOR, BROWN)
    CellNavigationColor (_SELECTEDCELL_BACKCOLOR, YELLOW)
    CellNavigationColor (_SELECTEDCELL_DISPLAYCOLOR, .T.)
    CellNavigationColor (_SELECTEDROW_FORECOLOR, YELLOW)
    CellNavigationColor (_SELECTEDROW_BACKCOLOR, MAROON)
    CellNavigationColor (_SELECTEDROW_DISPLAYCOLOR, .T.)
        //--start main window
 	DEFINE WINDOW Form_Master ;
               AT 0,0                ;
               WIDTH    nMainWidth   ;
                HEIGHT   nMainHeight     ;
                TITLE    'Master Tables' ;
                CHILD                    ;
                ON INIT  ManEditMasterInit()   ;
                FONT    'Arial' SIZE 10
		DEFINE STATUSBAR
			STATUSITEM 'HMG Power Ready'
		END STATUSBAR
	     DEFINE MAIN MENU
                      POPUP 'Client-Server'
                              ITEM 'Test Client to Server NETIO' ACTION ServerConnect()
                      END POPUP
		      POPUP '&Help'
			     ITEM 'Master Table Company status'  ACTION Msginfo ( "Company Table is " + iif(isCompanyActive, "Active", "Not Active"))
			     ITEM 'Master Table Unit status'          ACTION Msginfo ( "Unit Table is " + iif(isUnitActive, "Active", "Not Active"))
			     ITEM 'Master Table Department status'    ACTION Msginfo ( "Department Table is " + iif(isDeptActive, "Active", "Not Active"))
			     ITEM 'Help Page'	                     ACTION MsgInfo ("not available yet")
		       END POPUP
		END MENU
		DEFINE SPLITBOX
                COMBOBOX Combo_Master ;
                        ITEMS        {'Company Table','Unit Table','Department Table'} ;
                        VALUE        1 ;
                        TOOLTIP      'Choose a Master Table of records to add, edit, delete' ;
                        ON CHANGE    ManSelectMaster() ;
                        GRIPPERTEXT "Master Table To Edit: "
                 DEFINE TOOLBAR ToolBar_Comp BUTTONSIZE 85,85 FLAT
			BUTTON        Button_AddCompany      ;
				   CAPTION   '&Add'          ;
				   PICTURE   'Add-64'        ;
				   ACTION    ManAddCompany() ;
                                   TOOLTIP   'Add new record to Company'
			BUTTON Button_UpdateCompany ;
				    CAPTION   '&Update' ;
				    PICTURE   'Update-64' ;
				    ACTION     iif( Form_Master.Grid_Company.Itemcount=0, MsgInfo("No record to update" ), ManEditCompany()) ;
                                    TOOLTIP   'Update existing record of Company'
			BUTTON Button_DeleteCompany ;
				    CAPTION   '&Delete' ;
				    PICTURE   'Remove-64' ;
				    ACTION    iif( Form_Master.Grid_Company.Itemcount=0, MsgInfo("No record to delete" ), ManDeleteCompany()) ;
                                    TOOLTIP   'Delete existing record of Company'
 			END TOOLBAR
		DEFINE TOOLBAR ToolBar_Unit BUTTONSIZE 85,85 FLAT
                         BUTTON        Button_AddUnit      ;
				    CAPTION   '&Add'          ;
				    PICTURE   'Add-64'        ;
				    ACTION    ManAddUnit() ;
                                    TOOLTIP   'Add new record to Unit of Company'
			  BUTTON Button_UpdateUnit ;
				    CAPTION   '&Update' ;
				    ACTION     iif( Form_Master.Grid_Unit.Itemcount=0, MsgInfo("No record to update" ), ManEditUnit() ) ;
                                   TOOLTIP   'Update existing record of Unit of Company'
			  BUTTON Button_DeleteUnit ;
				     CAPTION   '&Delete' ;
				     ACTION    iif( Form_Master.Grid_Unit.Itemcount=0, MsgInfo("No record to delete" ), ManDeleteUnit() ) ;
                                     TOOLTIP   'Delete existing record of Unit of Company'
 		END TOOLBAR
                DEFINE TOOLBAR ToolBar_Dept BUTTONSIZE 85,85 FLAT
			  BUTTON        Button_AddDept      ;
				    CAPTION   '&Add'          ;
				    PICTURE   'Add-64'        ;
				    ACTION    ManAddDept() ;
                                   TOOLTIP   'Add new record to Department'
			  BUTTON Button_UpdateDept ;
				    CAPTION   '&Update' ;
				    ACTION     iif( Form_Master.Grid_Dept.Itemcount=0, MsgInfo("No record to update" ), ManEditDept() ) ;
                                   TOOLTIP   'Update existing record of Department'
		          BUTTON Button_DeleteDept ;
				    CAPTION   '&Delete' ;
				    ACTION    iif( Form_Master.Grid_Dept.Itemcount=0, MsgInfo("No record to delete" ), ManDeleteDept()) ;
                                   TOOLTIP   'Delete existing record of Department'
                END TOOLBAR
		DEFINE TOOLBAR ToolBar_Network BUTTONSIZE 85,85 FLAT
			   BUTTON Button_Network ;
				    CAPTION   'Net&work' ;
				    PICTURE   'network-64' ;
				    ACTION    ( Msginfo("You are going to run NETIO Server."), Servermain() );
                                    TOOLTIP   'Network Transmission, Server Application'
			   BUTTON Button_Server ;
				    CAPTION   '&NETIO' ;
				    PICTURE   'NETIO-64' ;
				    ACTION    ( Msginfo("You are going to connect NETIO Server as Client."), ServerConnect() );
                                   TOOLTIP   'Connect to Server NETIO, Client application'
		END TOOLBAR
		DEFINE TOOLBAR ToolBar_Exit BUTTONSIZE 85,85 FLAT
			   BUTTON Button_Exit3 ;
				    CAPTION   '&Exit' ;
				    PICTURE   'exit-64' ;
				    ACTION    ( Form_Master.release ) ;
                                   TOOLTIP   'Back to Main Menu'
		END TOOLBAR
                //-*- Grid Value (row post) return in array (row, col) because option CELLNAVIGATION is used
                DEFINE GRID Grid_Company
                        WIDTH        400
                        HEIGHT       200
                        FONTNAME     'ARIAL'
                        FONTSIZE     9
                        FONTBOLD     .T.
                        TOOLTIP      NIL
                        ONGOTFOCUS   ( ManCompEnableUpdate(.T.) , ManCompEnableDelete(.T.) )
                        ONLOSTFOCUS  ( ManCompEnableUpdate(.F.) , ManCompEnableDelete(.F.) )
                        ITEMS        aCompRecords
                        HEADERS      aCompHeaders
                        WIDTHS       aCompWidths
                         VALUE        1
                         BACKCOLOR    SpringGreen
                         FONTCOLOR    MediumBlue
			 DYNAMICBACKCOLOR bBackColor
                         DYNAMICFORECOLOR bFontColor
                         COLUMNCONTROLS NIL
                         CELLNAVIGATION .T.
                         LOCKCOLUMNS  2
                 END GRID
                 Form_Master.Grid_Company.ColumnHEADER (1) := aCompHeaders[1]
                 DEFINE GRID Grid_Unit
                         WIDTH        400
                        HEIGHT       200
                        FONTNAME     'ARIAL'
                        FONTSIZE     9
                        FONTBOLD     .T.
                       TOOLTIP      NIL
                       ONGOTFOCUS   ( ManUnitEnableUpdate(.T.) , ManUnitEnableDelete(.T.) )
                       ONLOSTFOCUS  ( ManUnitEnableUpdate(.F.) , ManUnitEnableDelete(.F.) )
                       ITEMS        aUnitRecords
                       HEADERS      aUnitHeaders
                       WIDTHS       aUnitWidths
                       VALUE        1
                        BACKCOLOR    Seashell
                        COLUMNCONTROLS NIL
                        CELLNAVIGATION .T.
                        LOCKCOLUMNS  2
                END GRID
                Form_Master.Grid_Unit.ColumnHEADER (1) := aUnitHeaders[1]
                DEFINE GRID Grid_Dept
                          WIDTH        400
                          HEIGHT       200
                          FONTNAME     'ARIAL'
                          FONTSIZE     9
                          FONTBOLD     .T.
                          TOOLTIP      NIL
                          ONGOTFOCUS   ( ManDeptEnableUpdate(.T.) , ManDeptEnableDelete(.T.) )
                          ONLOSTFOCUS  ( ManDeptEnableUpdate(.F.) , ManDeptEnableDelete(.F.) )
                          ITEMS        aDeptRecords
                          HEADERS      aDeptHeaders
                          WIDTHS       aDeptWidths
                          VALUE        1
                           BACKCOLOR    PowderBlue
                           COLUMNCONTROLS NIL
                           CELLNAVIGATION .T.
                           LOCKCOLUMNS  2
                END GRID
                Form_Master.Grid_Dept.ColumnHEADER (1) := aDeptHeaders[1]
            END SPLITBOX
       CENTER WINDOW Form_Master
       ACTIVATE WINDOW Form_Master
