HMG Easy Build
Re: HMG Easy Build
Agil Abdullah wrote:
I failed to recompile your source of hmg_easybuild.prg. Error read as below:
Kill process with Process Explorer , Sysinternals Microsoft.
Link Español ...
http://technet.microsoft.com/es-es/sysi ... 96653.aspx
Link English ...
http://technet.microsoft.com/en-us/sysinternals/
http://technet.microsoft.com/en-us/sysi ... s/bb795533
Re: HMG Easy Build
pctoledo wrote: In my initial code SEARCH_OPEN, was using Form_1.StatusBar.Item (1) to get the current open folder, but your suggestion included the name of the selected file, then the only way out was to use Form_1.Tree_1.Cargo (Form_1.Tree_1.Value)).
"Cargo" is undocumented property and not a obligation using it here. Getting path info from a full file specification isn't difficult nor unknown method.
The HMG Easy Build can be used to compile the demos of the SAMPLES folder, but can also build any other project HMG in other folders. So I thought it best to limit SEARCH_OPEN only when the SAMPLES folder is selected. So the search will be based on the selected folder, searching forum function / events / controls related to the current folder.
IMO unnecessary limitations are not good programming practice; instead programmer should open easy and free ways to user as soon as possible. For example if I have a project named "browse" out of <hmg>\SAMPLE folder, what problem may arise when I want search "browse" on forum ?
When any folder is selected, different SAMPLES, the button HMG Forum will open hmgforum
Again, IMO this is a wrong behavior.
Sorry, everything in this subject are different personal points of view and discussing is meaningless. Lets author of program will select his best way.
Re: HMG Easy Build
I think the best solution is that the user has available two clear alternatives:
1) direct access to the forum
2) allow search of any word, the name of the control in sample folder appear as suggestions but not as obligation
Re: HMG Easy Build
srvet_claudio wrote:I think the best solution is that the user has available two clear alternatives:
Re: HMG Easy Build
srvet_claudio wrote:...
Alright :arrow:
So my changed suggestion :
PROCEDURE SEARCH_FORUM()
   LOCAL nGrRow := Form_1.Grid_1.CellRowFocused
   LOCAL cPath := '',;
         cFNam := '',;
         cSStr := ''
   IF nGrRow > 0
      cPath := aFiles[ nGrRow, 5 ]
      IF !EMPTY( cPath )
         HB_FNameSplit( cPath, , @cFNam )
   cSStr := InputBox( "Enter search string :", "Search in HMG Forum", cFNam )
   IF !EMPTY( cSStr )
      URL_OPEN ( URL_FORUM + "/search.php?keywords=" + cSStr + "&ch=300" )
RETURN // SEARCH_FORUM()
Saludos to all friends :D
Re: HMG Easy Build
Alright :arrow:
   LOCAL cPath := '',;
         cFNam := '',;
         cSStr := ''
   IF nGrRow > 0
      IF !EMPTY( cPath )
   IF !EMPTY( cSStr )
This is nice!
Re: HMG Easy Build
Link Español ...
Link English ...
Since we have Task Manager, why using separate program for terminate any process ?
Simply right click the task bar, select task manager, select process to terminate and click terminate process button; that's all :arrow:
Re: HMG Easy Build
This is nice!
Thanks Claudio :D
Now may be it's time to add :
  • - Search in HMG DOC
    - Sampled HMG Doc (?)
    - Search in local HD (s)
Re: HMG Easy Build
This is nice!
Thanks Claudio :D
Very good ideas!
PS: For these days I've left this project because I'm finishing the new release of HMG.
Re: HMG Easy Build
srvet_claudio wrote:[
Very good ideas!
Thanks Claudio :D
OK. You are right; HMG should have high priority :arrow:
Regards :)
