Export data to OpenOffice Calc and MS Office Excel
Re: Export data to OpenOffice Calc and MS Office Excel
Do anybody knows how to change font size and font name while exporting data to openoffice sheet?
En OpenOffice no se, en Excel lo hago así.
In OpenOffice I do not know, in Excel I do it that way.
oSheet:Range( "A1:D2" ):Font:Name := "Calibri"
oSheet:Range( "A1:D2" ):Font:Bold := .T.
oSheet:Range( "A1:D2" ):Font:Size := 12
This does not work in OpenOffice.
It's more complicated.
apais
Post by apais »
Why don't you use libxlswriter ? It generates agnostic spreadsheets.
Angel Pais
ROBROS
Post by ROBROS »
Hi Marek,
I searched for:
openoffice calc functions change font
Maybe you can record the corresponding Makro?
I have no knowledge of VBA, but sometimes recording makros helps me a lot, Recording makros is certainly a feature in openoffice.
Robert
I'm trying to do it in this way. VBA is very easy opposite to macros in openoffice (I'm not familiar with Java).
It was so easy to realize, but so hard to find right method name :-D
nFontSize := 22
nFontName := "ARIAL"
oSheet:getCellRangeByPosition(1,1,1,2):CharHeight := nFontSize
oSheet:getCellRangeByPosition(1,1,1,2):CharFontName := nFontName
if you want to set BOLD, you must do int in this way
oSheet:getCellRangeByPosition(1,1,1,2):CharWeight := 150		// percent of font weight --- BOLD  ==>  "com.sun.star.awt.FontWeight.BOLD"
DONTKNOW The font weight is not specified/known.
THIN specifies a 50% font weight.
ULTRALIGHT specifies a 60% font weight.
LIGHT specifies a 75% font weight.
SEMILIGHT specifies a 90% font weight.
NORMAL specifies a normal font weight.
SEMIBOLD specifies a 110% font weight.
BOLD specifies a 150% font weight.
ULTRABOLD specifies a 175% font weight.
BLACK specifies a 200% font weight.
if you want to underline content of your cell:
oSheet:getCellByPosition(0,i):CharUnderline := nLineType
where nLineType can be: (info from http://www.openoffice.org/api/docs/comm ... rline.html)
0 - not underline
1 - single line
2 - double line
3 - dot line (....)
4 - not underline ???
5 - dotted line ( _ _ _ _ )
6 - dotted line ( __ __ __ __ )
7 - dot and dotted ( _._._._._)
8 - _.._.._.._..
9 - ~~~~~~~~~
10 - ~~~~~~~~
If you want to use Italic font:
oSheet:getCellByPosition(0,i):CharPosture := nFontSlant
where nFontSlant
0 - no slant
1 - slant not designed into the font (where font does not have italic option - it's slanted by openoffice)
2 - where font has italic option built-in
I used small piece of code to test it:
 function test1
 	begin sequence with { |e| break(e)}
		oServiceManager := TOleAuto():New("com.sun.star.ServiceManager")
		oDesktop := oServiceManager:createInstance("com.sun.star.frame.Desktop")
	recover using e
		oDeskTop := NIL
	end sequence
	IF oDesktop = NIL
	  MsgStop("OpenOffice not installed?","Error")
	  RETURN Nil
	oDocument := oDesktop:loadComponentFromURL("private:factory/scalc","_blank", 0, {})
	oSchedule := oDocument:GetSheets()
	oSheet := oSchedule:GetByIndex(0)
	for i:=0 to 100
		c := "Line: "+str(i,3)
		oSheet:getCellByPosition(0,i):SetString( c )
	next i
	for i:=0 to 10
		oSheet:getCellByPosition(0,i):CharUnderline := i
	next i
return
Mario Mansilla
Post by Mario Mansilla »
Hola Amigos :
necesito exportar a Excel una base de datos cuyos valores son : 00000001 ,001 , 0001 .
Si utilizo la propiedad Numberformat "###0" me coloca todos 1 alineados a la derecha .
oHoja:Columns(2):NumberFormat := "###0"
Si utilizo la propiedad Numberformat "@" me coloca todos 1 alineados a la izquierda .
oHoja:Columns(2):NumberFormat := "@"
Si directamente no coloco nada me asigna un valor numerico sin ceros
Que valor deberia usar para que al exportar me deje los valores tal como estan en la base de datos .
Mario Mansilla
Hello friends :
I need to export to Excel a database whose values are: 00000001, 001, 0001.
If I use the Numberformat property "### 0" I put all 1 aligned to the right.
oHoja: Columns (2): NumberFormat: = "### 0"
If I use the Numberformat property "@" I put all 1 aligned to the left.
oHoja: Columns (2): NumberFormat: = "@"
If I do not place anything directly, it assigns me a numeric value without zeros
What value should I use to export the values as they are in the database?
Al tener ceros a la izquierda, deben ser texto, por lo tanto deben de ir entre
comillas y no usar Numberformat "###0".
"00000001" ,"001" , "0001"
koke
DBs Used: DBF, mySql, mariaDB
Post by koke »
Si es un número que quieres exportar como texto agrega una comilla sencilla antes del mismo.
---- google translate ----
If it is a number that you want to export as text, add a single quote before it.
,___,
[O.o]
/)__)
KoKe
