HMG Forum "Codebox" Reader
Re: HMG Forum "Codebox" Reader
here latest Version v0.6.2
HMGFORUM062.ZIP
Source, 32/64 Bit EXE
NO Image include for *.RC
(3.5 MiB) Downloaded 493 times
since v0.5.3 RELEASE EXE
// 12.10.2022 v0.5.4 special for Express++ Forum Attachment
// 01.11.2022 v0.5.5 no FILTER
// 02.11.2022 v0.5.6 ONCHANGE sync DBF using RECNO()
// 07.11.2022 v0.5.7 Msgno begin with 0 (zero) not 1 / DoShellLink()
// 08.11.2022 v0.5.8 RichEdit_Translate + HSCROLL .T.
// 27.01.2023 v0.5.9 Clip2Google()
// 04.02.2023 v0.6.0 SPINNER in Download
// 26.03.2023 v0.6.1 "more Filter" F2
// 23.04.2023 v0.6.2 DoReReadCODE()
v0.6.2 FIX 1st. Line of CODE. use "Re-Read all Source CODE" in Menu (can take a long Time)
v0.6.1 when search for Keyword / Author you can now use F2 on "Result" of Listbox for "more" search
v0.6.0 SPINNER at Download are default -50 / +50. you can change it in CONFIG.INI
v0.5.9 some "Translation" does not work while include HTML ...
copy "marked" Text from Original into Clipboard (right Menu)
change to "Translate" Window and use "translate from Clipboard" (right Menu)
Thanks Jimmy!
i have enhance Index TAG "DUPECHECK" and add AUTHOR
      cField := "STRZERO(TOPICNO,5)+DTOS(TDATE)+TTIME+AUTHOR"
you also need to edit DLFORUM.PRG and search for
      cSeek := STRZERO( nThreadNo, 5 ) + DTOS( dDATE ) + cTime
and change to
      cSeek := STRZERO( nThreadNo, 5 ) + DTOS( dDATE ) + cTime + cAuthor  // add cAuthor
3 x times
delete old *.CDX before run new CODE
