Migration from HMG to HMG Minigui
Re: Migration from HMG to HMG Minigui
ou puis je trouver les codes d'erreurs comme ici c''est Error E0030 merci
where can I find the error codes like here it's Error E0030 thank you
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
- dragancesu
E0030 is wrong syntax
you have
but you mix this syntax, look line SYSMENU
you must make decision: Strandad or Alternate syntax
you have
or
Standard Syntax (xBase Style):
DEFINE WINDOW <WindowName>
AT <nRow> ,<nCol>
WIDTH <nWindth>
HEIGHT <nHeight>
[ VIRTUAL WIDTH <nVirtualWindth> ]
[ VIRTUAL HEIGHT <nVirtualHeight> ]
[ TITLE <cTitle> ]
[ ICON <cIconName> ]
[ MAIN | CHILD | MODAL | SPLITCHILD | PANEL ]
[ NOSHOW ]
[ TOPMOST ]
[ NOAUTORELEASE ]
[ NOMINIMIZE ]
[ NOMAXIMIZE ]
[ NOSIZE ]
[ NOSYSMENU ]
[ NOCAPTION ]
[ CURSOR <CursorName> ] ...
Alternate Syntax:
ROW <nRow>
COL <nCol>
WIDTH <nWindth>
HEIGHT <nHeight>
WINDOWTYPE MAIN | CHILD | MODAL | SPLITCHILD | STANDARD | PANEL
[ VIRTUALWIDTH <nVirtualWindth> ]
[ VIRTUALHEIGHT <nVirtualHeight> ]
[ TITLE <cTitle> ]
[ VISIBLE <lValue> ]
[ TOPMOST [<lValue>] ]
[ AUTORELEASE <lValue> ]
[ MINBUTTON <lvalue> ]
[ MAXBUTTON <lValue> ]
[ SIZABLE <lValue> ]
[ SYSMENU <lValue> ]
[ TITLEBAR <lValue> ]
I understand , i'm going to fix it step by step Thank'sdragancesu wrote: ↑Wed Jan 25, 2023 2:57 pm E0030 is wrong syntax
you have
or
AT <nRow> ,<nCol>
WIDTH <nWindth>
HEIGHT <nHeight>
[ TITLE <cTitle> ]
[ NOSHOW ]
[ TOPMOST ]
[ NOAUTORELEASE ]
[ NOMINIMIZE ]
[ NOMAXIMIZE ]
[ NOSIZE ]
[ NOSYSMENU ]
[ NOCAPTION ]
Alternate Syntax:
ROW <nRow>
COL <nCol>
WIDTH <nWindth>
HEIGHT <nHeight>
[ TITLE <cTitle> ]
Y.TABET
Y.TABET
step by step ! That's what I did too!
Bonsoir,
can you to do this example in HMG.3.4.4 to HMG extended Minigui Thank's
it's working (I changed GRID to BROWSE)@ 40,10 GRID Grid_Creance_Cli_NEW ; // 10,10
WIDTH 720 ; // 770 ;
HEIGHT 420 ;
HEADERS {'Gestion ','Montant TTC ','T.v.a','Avances Esp','Autres Avances','Representation', 'Solde'} ;
WIDTHS {70,110,100,110,110,100,110};
EDIT ;
VALUE { 1 , 1 } ;
justify {0,1,1,1,1,1,1};
COLUMNCONTROLS { aCrCtrl_1 , aCrCtrl_2 , aCrCtrl_3 , aCrCtrl_4 , aCrCtrl_5 , aCrCtrl_6, aCrCtrl_7 } ;
ROWSOURCE "GEST_ANT" ;
COLUMNFIELDS { 'Gestion' , 'Mont_ht' , 'Mont_Tva' , 'AvancEsp' , 'AutreAva', 'Represent' , 'SoldeAva'} ;
ALLOWAPPEND ;
ALLOWDELETE ;
DYNAMICDISPLAY { creaDisplay_1 , creaDisplay_2 , creaDisplay_3 , creaDisplay_4 , creaDisplay_5 , creaDisplay_6 , creaDisplay_7 } ;
Y.TABET
Y.TABET
tout se compile bien avec compile.bat ,aucune erreur n'est signalée par DOS ,mais pas de fichier en exe ,Demain je verrais ça
Bonne nuit a tous .
everything compiles fine with compile.bat, no error is reported by DOS, but no exe file, tomorrow I will see that
Good night all
Bonne nuit a tous .
Good night all
Y.TABET
Y.TABET
Bonsoir,
En compilant avec IDE Minigui ==> (Error Gestion.Rc 35 33: Invalid bitmap format),
et par "compile.bat" , j'ai le même problème a ci joint l'image de la compilation.
est ce un problème de fichier.rc.
est il différent du fichier de HMG.3.4.4.
By compiling with IDE Minigui ==> (Error Gestion.Rc 35 33: Invalid bitmap format),
and by "compile.bat" , I have the same problem attached ( the image of the compilation.)
is this a file.rc problem.
is it different whith file.rc of HMG.3.4.4
- gestion.rar
- (472 Bytes) Downloaded 356 times
- ErreurCompilation.JPG (55.48 KiB) Viewed 28778 times
Y.TABET
Y.TABET
Hi,tonton2 wrote: ↑Wed Feb 01, 2023 6:28 pm Bonsoir,
It seems that your bitmap image in Gestion.Rc file is not like to the Borland resource compiler.
You have two options now:
1) replace this bitmap with another one;
2) replace BCC compiler with MinGW C compiler which used in HMG.3.4.4.
What help do you need
- AUGE_OHR
use
if try instead of
MYBMP BITMAP RES\SOME.BMPCode: Select all
#define RCDATA 10
MYBMP RCDATA RES\SOME.BMPhave fun
mon programme fonctionne très bien dans HMG.3.4.4 , ,maintenant j'ai migré vers HMG EXTENDED (MINIGUI) , tout va bien sauf gestion.rc.gfilatov wrote: ↑Wed Feb 01, 2023 7:38 pmHi,tonton2 wrote: ↑Wed Feb 01, 2023 6:28 pm Bonsoir,
What help do you need![]()
comment compiler avec Borland ce fichier.
encore merci beaucoup de votre précieuse aide
my program works fine in HMG.3.4.4, now i migrated to HMG EXTENDED (MINIGUI), everything is fine except management.rc.
how to compile with Borland this file.
Thanks again for your precious help.
- Compile.rar
- (383 Bytes) Downloaded 350 times
Y.TABET
Y.TABET
