HPDFPRINT IMAGE Image cannot be loaded
- mustafa
Re: HPDFPRINT IMAGE Image cannot be loaded
Hello Franco:
For me it is a serious problem not to understand English
I'm translating with Google and I can't interpret
your writing sorry
My Sample is based on seeing the image with "camera.swf "
and then how the image is not saved correctly
due to lack of compression and resolution
I take a screenshot of the frame area
Where is the image
If you want to expand your Sample, please send
the Full Code in prg
your writing sorry
Where is the image
Hello Mustafa,
I modified the previous post. I have it sort of figured out.
I am just in the process of moving the capture to the left top of the screen, because my clients have touch screen tablets and
while taking a picture they just touch button with ther thumb.
Also trying to get rid of black lines on top and bottom, I thonk created by swf capture.
All the Best,
Franco.
All the Best,
Franco.
All The Best,
Franco
Canada
Franco
Canada
Auge_ore and Mustafa,
Auge that command works I am in process of testing.
Mustafa, I have a new simple version of your last post. I will replace my original with our new one.
All the Best,
Franco
All the Best,
Franco
All The Best,
Franco
Canada
Franco
Canada
- mustafa
Hola Franco
Espero que te funcione
Found something while testing
If I take a picture with the internal hmg camera to .jpg will not print to pdf. And open the picture file with notepad, they start is BMÎ( 6 (
If I open a picture that is taken with a real camera or windows camera they will print to pdf. The start in notepad is ÿØÿà JFIF ` `
I wonder what the BM at start means, Do you think the hmg picture is a bitmap and can be converted to a real jpg picture that can be printed to pdf.
All The Best,
Franco
Canada
Franco
Canada
BM indicates that's a bitmap (bmp), not jpg file. Just try to add image as bmp into pdf.
Or try to convert into jpg:
Note: this code was not tested, I wrote it from my mind.
#include "BosTaurus.CH"
BT_BitmapSaveFile ( ( hBitmap:=BT_BitmapLoadFile (cBmpFileName) ) , cJpgFileName, BT_FILEFORMAT_JPG )
BT_BitmapRelease (hBitmap)
edk, thank you, thank you, THANK YOU,
I have been looking for this for 2 months.
Mustafa this is what we where looking for.
Instead of CAMFORM.CAPTURE('TEST.JPG',15,7,300,230) in hmg camera
We now use CAMFORM.CAPTURE('TEST.BMP',15,7,300,230) BECAUSE IT IS A BITMAP.
Then add edk suggestion
BT_BitmapSaveFile ( ( hBitmap:=BT_BitmapLoadFile ("test.bmp") ) , "test.jpg", BT_FILEFORMAT_JPG )
This will print to pdf.
I am still working on the windows 10 camera as it is much clearer, and does not have the black lines around the picture.
Thanks to all,
Thanks to all,
All The Best,
Franco
Canada
Franco
Canada
New problem
After taking a picture in hmg which even though its name is jpg but it is a bitmap.
This works fine, BUT a 100 kb bp file becomes a 6 kb jpeg file, which becomes a poor quality picture.
Am I doing something wrong. If so this could be easy fix.
I can use:
BT_BitmapSaveFile ( ( hBitmap:=BT_BitmapLoadFile ("test.bmp") ) , "test.jpg", BT_FILEFORMAT_PNG )
This becomes a png file that is still 100 kb with name .JPG. This still works throughout my program except when I want to print it.
I set print image type by the name which is jpg because I also use other cameras to take pictures which are real jpg files.
IS THERE A PROCEDURE TO CHECK THE FILE BEFORE PRINTING TO SEE IF IT IS A PNG OR JPG. LIKE:
IF FILETYPE(JPG) OR FORMAT(PNG) , WHICH WOULD CHECK THE FILE NOT BY NAME OR EXTENTION.
I can use Fopen and Fread but do not like to low level open and close files (Can create problems)
Thanks in advance,
I can use:
Thanks in advance,
All The Best,
Franco
Canada
Franco
Canada
IMHO print quality is poor because offranco wrote: ↑Fri Jan 17, 2020 6:21 pm New problem
This will capture part of screen with 72 or 96 DPI
I am so sorry, I can't help you. I don't have any PC camera and I don't want to have it
Try to replace the _HMG_HPDF_IMAGE function in the h_HMG_HPDF.Prg file and then rebuild the HMG using the BuildLib32.bat batch file
Function _HMG_HPDF_IMAGE ( cImage, nRow, nCol, nImageheight, nImageWidth, lStretch , cImageType)
Local nWidth := _HMG_SYSDATA[ 150 ][ 4 ]
Local nHeight := _HMG_SYSDATA[ 150 ][ 5 ]
Local nxPos := _HMG_HPDF_MM2Pixel( nCol )
Local nyPos := nHeight - _HMG_HPDF_MM2Pixel( nRow )
Local oImage := Nil
default lStretch := .f.
default cImageType := "AUTO"
If _HMG_SYSDATA[ 150 ][ 1 ] == Nil // PDF object not found!
_HMG_HPDF_Error( 3 )
If _HMG_SYSDATA[ 150 ][ 7 ] == Nil // PDF Page object not found!
_HMG_HPDF_Error( 5 )
do case
case HMG_UPPER( alltrim( cImageType ) ) = "PNG"
oImage := _HPDF_LOAD_PNG (_HMG_SYSDATA[ 150 ][ 1 ], cImage)
case HMG_UPPER( alltrim( cImageType ) ) = "JPG"
oImage := _HPDF_LOAD_JPG (_HMG_SYSDATA[ 150 ][ 1 ], cImage)
case HMG_UPPER( alltrim( cImageType ) ) = "AUTO"
IF oImage = Nil .OR. Empty ( oImage )
HPDF_ResetError( _HMG_SYSDATA[ 150 ][ 1 ] )
otherwise
_HMG_HPDF_Error( 20 )
endcase
If oImage = Nil
_HMG_HPDF_Error( 7 )
endIf
If empty( oImage )
endIf
HPDF_Page_DrawImage( _HMG_SYSDATA[ 150 ][ 7 ], oImage, nxPos, nyPos - _HMG_HPDF_MM2Pixel( nImageHeight ), _HMG_HPDF_MM2Pixel( nImageWidth ), _HMG_HPDF_MM2Pixel( nImageHeight ) )
E.g. @ 126, 10 HPDFPRINT IMAGE "hmghpdf.valid_png_or_jpg" WIDTH 190 HEIGHT 46
