HMG 3.4.3
jorge.posadas
Re: HMG 3.4.3
Post by jorge.posadas »
A todos los que estan mejorando HMG les doy mi agradecimiento por esto,
Muchas gracias de corazon
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
Re: HMG 3.4.3
Hola
Probando otro ejemplo.... Error de ejecucion.
Hello
Proving another example .... Runtime error.
kcarmody
Re: HMG 3.4.3
Post by kcarmody »
andyglezl wrote:Hello
Thank you, Andrés, for reporting this bug. It was caused by a minor miscopy from my previous proposal (http://hmgforum.com/viewtopic.php?f=43&t=4711) to 3.4.3. The fix is to insert the following line after line 4 in hfcl\RichEditBoxEx_H.prg:
#include "hfcl.ch"
Then rebuild the HFCL library and recompile WordScribe.
I have posted all these changes on my website, including the recompiled library and WordScribe executable, as a proposed patch to 3.4.3.
Zip for my current proposal http://kevincarmody.com/hmg/HmgChangeProposal.zip
List of changes for this proposal http://kevincarmody.com/hmg/Changes.txt
Compiled WordScribe executable http://kevincarmody.com/hmg/SAMPLES/HFC ... Scribe.exe
Thank you, Claudio, for 3.4.3!
chrisjx2002
Re: HMG 3.4.3
Post by chrisjx2002 »
Hello,
There is a bug when changing image in a button : Form_1.Button_1.Picture := ....
I think that the problem is at line 2547 in h_controlmisc.prg.I change .and. by .or. :
if  .Not. Empty (_HMG_SYSDATA [ 25 ] [i] ) ;
        .Or. ;
        .Not. Empty (_HMG_SYSDATA [ 33 ] [i] ) ;
        .Or.;
        (_HMG_SYSDATA [ 22 ] [i] == 'I' .And. IsAppThemed())
Another problem exists when using right or left option:
I use the Claudio's program for toolbar and change it for button :
Function Main()
   DEFINE WINDOW Form_1 ;
      AT 0,0  ;
      WIDTH 240 HEIGHT 200 ;
      MAIN
        @10,10	BUTTON Button_1 CAPTION "Test 1 (No Img)" PICTURE "" left ACTION ButtonClick() width 100 height 60
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
Function ButtonClick
STATIC i := 1
   i++
   IF i > 3
      i := 1
   DO CASE
      CASE i == 1
         Form_1.Button_1.Caption := "Test 1 (No Img)"
         Form_1.Button_1.Picture := ""
      CASE i == 2
         Form_1.Button_1.Caption := "Test 2"
         Form_1.Button_1.Picture := "button5.bmp"
      CASE i == 3
         Form_1.Button_1.Caption := "Test 3"
         Form_1.Button_1.Picture := "button6.bmp"
   ENDCASE
At the beginning the result is
After clicking three times the result is :
Re: HMG 3.4.3
1.- Anomalía en Documentos PDF, caida de la posición de las letras
solución del amigo " tonton2" ver :
http://hmgforum.com/viewtopic.php?f=43& ... &start=140
SOURCE\h_HMG_HPDF.Prg
Línea--> 312 Anular --> // nyPos -= nFontSize
1.- Documents PDF anomaly, falling position letters
Friend solution "tonton2" see:
Line--> 312 Removed --> // nyPos -= nFontSize
2.- Faltan Libs copiado de versión hmg.3.4.0
Parece que funciona
libeay32.a 2.273.502 17/08/2009
libhmgmysql.a 4.952 23/05/2014
libhmgpgsql.a 5.898 23/05/2014
libhmgsqlite.a 5.688 23/05/2014
2.-Libs missing copied version hmg.3.4.0
It seems to work
Gracias a todos los que estais colaborando en este magnifico proyecto
Thanks to all you who collaborate in this magnificent project
Lib.zip
(131.4 KiB) Downloaded 452 times
Re: HMG 3.4.3
This is a patch file for those using HMGSQL bridge. Please update and build the lib files again.
HMGSQLPatch.zip
(18.72 KiB) Downloaded 609 times
Re: HMG 3.4.3
Gracias Rathi !
Rathi thanks!
Re: HMG 3.4.3
I want to report that HMG Debugger crashes when your application is built from few modules, incremental compilation and ane main module is compiled without debugger, depending module compiled with debugger.
When calling debugger, error occurs:
Error: HMG 3.4.2 Stable Patch 4 (32 bits)
Non Modal WIndows can't be activated when a modal window is active. _HMG_FormDebugger Program Terminated
Called from _ACTIVATEWINDOW(5686)
Called from PROCINITGUIDEBUGGER(462)
Called from (b)HMGDEBUGGER(245)
Called from (b)HMGDEBUGGER(253)
Called from HMGDEBUGGER:GUICREATEFORMDEBUGGER(0)
Called from HMGDEBUGGER:ACTIVATE(276)
Called from __DBGENTRY(114)
Called from DRUKUJFAKTUREWGWZORCA(27)
Called from DRUKUJFAKTURE(3255)
Called from DRUKUJPONOWNIEFAKTURE(1578)
Called from (b)REJESTRFAKTUR(373)
Called from _DOCONTROLEVENTPROCEDURE(6044)
Called from EVENTS(1717)
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(5707)
Called from REJESTRFAKTUR(447)
Called from AKCJATESTPRZYCISKOW(1647)
Called from (b)ZDEFINIUJOKNOGLOWNE(1590)
Called from EVENTS(1762)
Called from MAIN(595)
Re: HMG 3.4.3
I will check.
Re: HMG 3.4.3
mol wrote:I want to report that HMG Debugger crashes when your application is built from few modules, incremental compilation and ane main module is compiled without debugger, depending module compiled with debugger.
Hi Marek,
change in function _ActivateWindow (file h_windows.prg) the original line 5647:
			If _HMG_SYSDATA [ 271 ]
				MsgHMGError("Non Modal WIndows can't be activated when a modal window is active. " + Formname +" Program Terminated" )
for this
			If _HMG_SYSDATA [ 271 ] .AND.  lActivateMsgLoop == .T.
				MsgHMGError("Non Modal Windows can't be activated when a modal window is active. " + Formname +" Program Terminated" )
and rebuild.
