Quick Browse Form
Re: Quick Browse Form
Hello bpd2000,
Thanks for your interest in the demo!
Hello Steed,
Thanks for accompany, I hope you find it useful!
No that gives you this error, compile it again and I compiles fine, also use the Win7 32bit version HMG.3.3.1dragancesu wrote: I guess it's well done, but so far I have not seen because it has a run-time error
p.s. Compiled with hmg 3.3.1
No compiling that gives me a date different from today cración the executable ?, that happens to me very often and sometimes gets me the correct date, today.
Any ideas?
Also you compile with HMG.3.4.0 without any problem.
- dragancesu
Well done
Just missing the picture to make it look perfect, in attachment
- QuickIcon.zip
- (16.84 KiB) Downloaded 548 times
I've tried attached QuickB.exe on two different .dbf files, and I've got errors:
HMG Errorlog File
Date:13/03/2015 Time: 10:47:15
Error BASE/1132 Bound error: array access
Called from _GRIDEX_DOGRIDCUSTOMDRAW(676)
Called from EVENTS(2873)
Called from UPDATEWINDOW(0)
Called from EVENTS(907)
Called from SHOWWINDOW(0)
Called from _ACTIVATEWINDOW(5391)
Called from PANTALLA(362)
Called from (b)MAIN(49)
Called from _DOCONTROLEVENTPROCEDURE(5745)
Called from EVENTS(1908)
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(5413)
Called from MAIN(196)
Date:13/03/2015 Time: 10:47:39
Hello Mol,
If you Might indicate step by step what you did and share your two DBF to try!
Thank You
Thank You
Leopoldo Blancas
Qué paso con este excelente trabajo?
What happened to this excellent job?
Thanks for sharing Dragan
Gracias por compartir !!!
Hi
I tried to run QuickB for two DBFs.
For one it went on smoothly but for other i got following error message.(pls see screenshot enclosed)
From earlier posts I found mol also got same error msg. mol could you solve your problem ?
Else anyone can help ?
- QuickB-Error.png (254.28 KiB) Viewed 8392 times
