HMG version installed
Thank you Serge and Nikos for your interest.
serge_girard wrote:I run my HMG on my P: drive (so I can run it from every attached PC) and I make backups to some other drives.
Your tool gives up 6 versions and totally I have 18 versions...
Hi Serge,
You are right to advise me in the way you also work. I will adapt it (it's really very easy to do it) to get all local drives.
Now this is not contemplated. But let me know more two things:
1. All your HMG installations are registered (installed by HMG <version> Setup.exe) or you have done only a simple copy of HMG folder?
2. Your HMG folders starting with "HMG" ? If not, please tell me what name have you used for?
Because HMG_Find() look up for obvious "HMG" name. Otherwise this searching at each disk, would it turns so extensive... a would spend a lot of time searching too... :oops:
Re: HMG version installed
Hi Pablo,
Apparantly there 2 versions copied, the rest is registered. No HMG-names changed !
Thx !
Hi Serge,
Download these and test it, please. :)
Added checkbox with text on the left, replaced statusbar with getting optional drives and optimized code.
Even conecting a new pendrive and clicking at first statusbar will search HMG installation.
Now it's much better now. Thank you for your comments about it. :)
<Files attached was removed because there is a nwest version ahead this topic>
Post by EduardoLuis »
Hi Pablo:
Great sample, usefull and provides us deep knowledge about HMG language.
Thanks for share.-
Eduardo
Hola Pablo:
Gran ejemplo, muy útil para profundizar nuestros conocimientos sobre el lenguaje HMG.
Gracias por compartir.
Eduardo
Pablo César wrote:Download these and test it, please. :)
Tested on win-10, Ok
Pablo,
One word: brilliant !
Thx,
Thank you all for your expressed interest and tips :P
Hi all,
ChangeLog:
  1. Main form off
  2. Selectable grid item
  3. Returning version to calling module
  4. Improving at date column at grid
  5. Form's title centered
  6. HMG icon added
Now GetHMGVersions function works independent.
Thanks to all the colleagues who encourage me to do better: always. :P
quartz565
Post by quartz565 »
Thank you my friend !
Nikos.
os: Windows Server 2019 - 64
Παρακαλώ φίλε μου !
