Yes you are right Rathi, this was missing correction, specially when use SetProperty in Numeric TextBox.Rathinagiri wrote:Claudio, there is a small fix to h_controlmisc.prg with regard to numeric textbox.
When the value is assigned decimals are truncated.
Here is the fix. Change the following line No. 514 with the following:
Line with problem:
Fix:Code: Select all
SetWindowText ( c , ALLTRIM(STR(Int(value))) )
SetWindowText ( c , ALLTRIM(STR(value)) )
HMG 3.3.0 (Stable) Patch 1
- srvet_claudio
Re: HMG 3.3.0 (Stable) Patch 1
Done.Rathinagiri wrote:Claudio, there is a small fix to h_controlmisc.prg with regard to numeric textbox.
Line with problem:
Hola a todos :
estoy mirando file:///C:/hmg.3.3.0/doc/data/index.htm la seccion Read Keyboard and Mouse
en un lugar dice :
Hello everyone:
'm looking at file :/ / / C :/ hmg.3.3.0/doc/data/index.htm Read the section Keyboard and Mouse
in a place says:
donde genero el manejador hWnd , ya que necesito generar un funcion generica que usen varias ventanas
where gender handler hWnd , and I need to generate a generic function using multiple windows
en un lugar dice :
Hello everyone:
in a place says:
Complementary Functions:
- Gets Form/Control Name and Form Parent Name by window handle (complement, e.g. to the read keyboard functions):
- GetFormNameByHandle ( hWnd, @cFormName, @cFormParentName ) --> Return nFormIndex
- GetControlNameByHandle ( hWnd, @cControlName, @cFormParentName ) --> Return nControlIndex
