HMG 2.8.3 (Forum Test)
Re: About 2.8.3 and Esgici Sample...
Roberto Lopez wrote: Well... The only problem with the current version is that 'OnChange' is executed twice when you change the row and column (both) with the mouse.
Sorry... I've forgot to mention that a change is needed in 'h_windows.prg' (yet, it was already discussed in this thread by Grigory and me).
The current 2.8.3 'problematic' code is:
				* Grid Click ...........................
				If GetNotifyCode ( lParam ) == NM_CLICK
					IF _HMG_SYSDATA [32] [i] == .T.
						aCellData := _GetGridCellData(i)
						IF aCellData [2] <> _HMG_SYSDATA [ 15 ] [i]
							IF aCellData [1] <> _HMG_SYSDATA [ 19 ] [i]
								_DoControlEventProcedure ( _HMG_SYSDATA [ 12 ] [i] , i )
						_HMG_SYSDATA [ 15 ] [i]  := aCellData [2]
						LISTVIEW_REDRAWITEMS ( _HMG_SYSDATA [ 3 ] [i] , _HMG_SYSDATA [ 39 ] [i] - 1 , _HMG_SYSDATA [ 39 ] [i] - 1 )
				EndIf
The main problem with it, is that variables containing the new values for row and column are updated AFTER the OnChange procedure was executed. The 'minor' problem is a wrong check I've attempted to avoid multiple execution (but I've was wrong about it).
It should be replaced by:
				EndIf
Please, remember... the double execution of OnChange still exists with this modification. It arises when you change selected cell row and col with mouse click.
Re: HMG 2.8.3 (Forum Test)
I had reviewed the code and even though I could not follow the logic without knowing which values the internal HMG_SYSDATA variable hold, I had tested the code, after changing h_windows.prg as mentioned by Roberto.
Now, test this code.
* MiniGUI Grid Demo
* (c) 2009 Roberto Lopez
#include "minigui.ch"
Local aRows [40] [3]
	lInit := .T.
	DEFINE WINDOW Form_1 ;
		WIDTH  640 ;
		HEIGHT 400 ;
		TITLE 'Mixed Data Type Grid Test' ;
		MAIN
        ON KEY ESCAPE ACTION Form_1.Release
		DEFINE MAIN MENU
			DEFINE POPUP 'File'
				MENUITEM 'Set Value To {5,2}'	ACTION Form_1.Grid_1.Value := {5,2}
				MENUITEM 'Set Value To {0,0}'	ACTION Form_1.Grid_1.Value := {0,0}
				MENUITEM 'Get Value'		ACTION GetSelectionValue()
				MENUITEM 'Delete Item 5'	ACTION Form_1.Grid_1.DeleteItem(5)
				MENUITEM 'AddItem'		ACTION Form_1.Grid_1.AddItem({'X','X','X'})
				MENUITEM 'Delete All Items'	ACTION Form_1.Grid_1.DeleteAllItems
			END POPUP
		END MENU
		aRows [1]	:= {'Simpson','Homer','555-5555'}
		aRows [2]	:= {'Mulder','Fox','324-6432'}
		aRows [3]	:= {'Smart','Max','432-5892'}
		aRows [4]	:= {'Grillo','Pepe','894-2332'}
		aRows [5]	:= {'Kirk','James','346-9873'}
		aRows [6]	:= {'Barriga','Carlos','394-9654'}
		aRows [7]	:= {'Flanders','Ned','435-3211'}
		aRows [8]	:= {'Smith','John','123-1234'}
		aRows [9]	:= {'Pedemonti','Flavio','000-0000'}
		aRows [10]	:= {'Gomez','Juan','583-4832'}
		aRows [11]	:= {'Fernandez','Raul','321-4332'}
		aRows [12]	:= {'Borges','Javier','326-9430'}
		aRows [13]	:= {'Alvarez','Alberto','543-7898'}
		aRows [14]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [15]	:= {'Batistuta','Gol','485-2843'}
		aRows [16]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [17]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [18]	:= {'Samarbide','Armando','854-7873'}
		aRows [19]	:= {'Pradon','Alejandra','???-????'}
		aRows [20]	:= {'Reyes','Monica','432-5836'}
		aRows [21]	:= {'Fernandez','Raul','321-4332'}
		aRows [22]	:= {'Borges','Javier','326-9430'}
		aRows [23]	:= {'Alvarez','Alberto','543-7898'}
		aRows [24]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [25]	:= {'Batistuta','Gol','485-2843'}
		aRows [26]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [27]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [28]	:= {'Samarbide','Armando','854-7873'}
		aRows [29]	:= {'Pradon','Alejandra','???-????'}
		aRows [30]	:= {'Reyes','Monica','432-5836'}
		aRows [31]	:= {'Fernandez','Raul','321-4332'}
		aRows [32]	:= {'Borges','Javier','326-9430'}
		aRows [33]	:= {'Alvarez','Alberto','543-7898'}
		aRows [34]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [35]	:= {'Batistuta','Gol','485-2843'}
		aRows [36]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [37]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [38]	:= {'Samarbide','Armando','854-7873'}
		aRows [39]	:= {'Pradon','Alejandra','???-????'}
		aRows [40]	:= {'Reyes','Monica','432-5836'}
		DEFINE GRID Grid_1
		    ROW             10
		    COL             10
			WIDTH           500
			HEIGHT          300
			HEADERS         {'Column 1','Column 2','Column 3'}
			WIDTHS          {100,100,100}
			ITEMS           aRows
			VALUE           1
			ALLOWEDIT       .T.
			CELLNAVIGATION  .T.
            ONCHANGE        msginfo("Here")
			ONCHANGE { ||  IF( ( _IsControlDefined( "spnRow", "Form_1" ) .AND. ;
                                 _IsControlDefined( "spnCol", "Form_1" ) ) ,;
                                 ( aCurValue := this.value,;
                                 SetProperty( "Form_1", "spnRow", "Value", aCurValue[ 1 ] ),;
                                 SetProperty( "Form_1", "spnCol", "Value", aCurValue[ 2 ] ) ), '' ) }
		END GRID // Grid_1
        @ 13, 520 LABEL lblRow WIDTH 50 VALUE "Row No:"
        @ 53, 520 LABEL lblCol WIDTH 50 VALUE "Col No:"
		DEFINE SPINNER spnRow
		   ROW   10
           COL   580
           WIDTH 50
           RANGEMIN 1
           RANGEMAX LEN( aRows )
           VALUE 1
           ONCHANGE { || aCurValue := GetProperty( "Form_1", "Grid_1", "Value" ),;
                         aCurValue[ 1 ] :=  this.Value,;
                         SetProperty( "Form_1", "Grid_1", "Value", aCurValue ) }
        END SPINNER // spnRow
		DEFINE SPINNER spnCol
		   ROW   50
           COL   580
           WIDTH 50
           RANGEMIN 1
           RANGEMAX 3
           VALUE 1
                         aCurValue[ 2 ] :=  this.Value,;
        END SPINNER // spnCol
        DEFINE STATUSBAR
           STATUSITEM WIDTH 100
        END STATUSBAR
 	Form_1.Grid_1.setfocus
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Function GetSelectionValue
Local a
	a := Form_1.Grid_1.Value
	MsgInfo( Str (  a [1] ) + ' ' + Str (  a [2] ) )
Return nil
It is the last sample (without Spinners) by esgici.
I had changed the on change event to just a msginfo("Here") to find out how many times the on change event is fired. When run, to my surprise, while using keyboard navigation, row, col values change accordingly and on change event is fired once. In the case of mouse click (in a different row and col), on change event is fired once, but, the col value doesn't change at all. May be this is the reason?
rathinagiri wrote:I had reviewed the code and even though I could not follow the logic without knowing which values the internal HMG_SYSDATA variable hold, I had tested the code, after changing h_windows.prg as mentioned by Roberto.
I guess I've found a solution (five minutes ago).
I've made various test and all appears to be working fine now, but is 01:57 am here and I'm extremely tired (I'm going to bed right now).
So, I'll do some more tests tomorrow and if all still ok, I'll publish a complete package with a demo app to be tested here.
Thanks Roberto.
A famous Tamil proverb says, We can draw a painting if and only if we have a wall. :) So, Take Care of your body too.
Hello Roberto, time to get up!!!
:lol:
I'm waiting for your example...
I shall be out of station for 3 days. So, when I shall back, get new version of HMG!!! :D
mol wrote:Hello Roberto, time to get up!!!
:lol:
Peae... wait... the morning coffee is not ready yet :)
Hi Rathi
Hearty Thanks for stand up for me :D
When change ONCHANGE line of GRID to
ONCHANGE msginfo("Here"+CRLF+GetSelectionValue())
and RETURN line of GetSelectionValue() to
Return ( Str ( a [1] ) + ' ' + Str ( a [2] ) )
situation can be seen more clear ( without a second step to going menu ).
Thanks a lot
Best Regards
esgici wrote: blah, blah, blah ...
And when added spinners to Rathi's example "double execution" can be seen clearly.
Double, because one for row spinner and one for other.
Interesting comment :)
