HMGSCRIPT 2012: Programming For The Web in The Right Way :)
- luisvasquezcl
Re: HMGSCRIPT 2012: Programming For The Web in The Right Way
Hi again,
new method setget value for controls.
function Value( cid, cvalue ) {
var el = document.getElementById( cid );
switch ( arguments.length ) {
case 1:
el.value; break;
case 2:
el.value = cvalue; break;
return el.value;
best regards,
case 1:
el.value; break;
case 2:
return el.value;
best regards,
- HMG Founder
Thanks!luisvasquezcl wrote:Hi again,
case 1:
el.value; break;
case 2:
return el.value;
best regards,
I still working in server communication, when finished, I'll include these new functions on the library.
- luisvasquezcl
Estimado,
para solucionar el problema con el control imagen cambia lo siguiente en el archivo hmgscript.js
function Image( cId , cParentId , nRow , nCol , cSrc )
Dice : var control = document.createElement( "image" ) ;
Cambiar por : var control = document.createElement( "img" ) ;
Esto soluciona el problema de imagen en Firefox.
Saludos cordiales,
Saludos cordiales,
Increíble, funciona en FieFox, IE y G.Chrome.Cambiar document.createElement( "image" ) ;
por document.createElement( "img" ) ;
To further mimic the window with the Windows style, I´ve changed at hmgs.xp.css adding border-top-left-radius and border-top-right-radius:
It is not working in lower version of IE9, but in G.Chrome, FireFox it´s works !
I have a question, why not use myWindow=window.open("","","width=600,height=400"); ? With it is going to open a windows of OS.
.window
position : absolute ;
background-color : rgb(236,233,216) ;
text-align : center ;
border : 3px solid rgb(2,106,254) ;
border-top-left-radius : 0.5em ;
border-top-right-radius : 0.5em ;
.window h1
font-family : Arial ;
font-size : 12pt ;
background : rgb(2,106,254) ;
color : white ;
margin : 0 ;
padding : 4px ;
border-top-left-radius : 0.2em ;
border-top-right-radius : 0.2em ;
} I have a question, why not use myWindow=window.open("","","width=600,height=400"); ? With it is going to open a windows of OS.
- HMG Founder
Gracias!luisvasquezcl wrote:Estimado,
Saludos cordiales,
AHora funciona bien en FF.
- HMG Founder
It looks good!Pablo César wrote:To further mimic the window with the Windows style, I´ve changed at hmgs.xp.css adding border-top-left-radius and border-top-right-radius:
I've already applied your changes.
It is only a design decision, based on that (AFAIK) we has not full control over it. ie: (AFAIK again) you can't make it modal or avoid minimize and maximize buttons, etc. Maybe I'm missing something, since I'm just learning.Pablo César wrote: I have a question, why not use myWindow=window.open("","","width=600,height=400"); ? With it is going to open a windows of OS.
More important, being non-modal clicking outside it, it will simply disappear (you must search it at taskbar).
Another consideration is how it behaves in other OSs than Windows.
Anyway, it can be added as an alternate way to do things.
I see. Thank you Roberto for clarifying.
I also will see what I can do with Standard ou Win7 style. I saw another frame with rounded border.
- HMG Founder
R005 with this new features:
- Server demo: you must start the included server before test.
- Contrib demo: a separated .html page and .js files for contributed samples.
- Contrib lib: A separated library for contributions.
Spliting the core from contrib (library and demos) will make easier and more effective our work.
I've included Rathi, Luis and Pablo contributions.
The server access requires a lot of work yet... I know
Enjoy!
Enjoy!
- hmgs005.zip
- (601.25 KiB) Downloaded 418 times
- HMG Founder
I want to turn the server in a way that no recompile be required.
I'm thinking on make it able to run precompiled .hrb files called from the web client.
Anybody knows how to invoke (run) a .hrb file from an application?
TIA.
TIA.
