rathinagiri wrote:
That's great Roberto!
I hereby list the problems I found.
1. Console mode applications are not compiled properly through IDE. But it is running fine when called build.bat from command prompt.
2. If we have an error, the error log displays the harbour compiler output showing the line numbers complied like 100 200 300 400 etc., in IDE.
3. I could not compile with libhbmysql because it gives an error saying libmysql not available.
Ok.
I'll modify IDE to work this way:
- It will call buildapp.bat located at HMG root folder with ONLY TWO parameters: <filelist.hbp> [config.hbc]
- Prior to this, IDE will write adequate 'config.hbc' to meet user's configuration for the project.
This way, any future moddification in Harbour/hbmk2 will not require modifications in IDE. This will be (well... should be
) fully hbmk2 and HMG.4 compatile.
