Error al compilar con HMG3.6
Re: Error al compilar con HMG3.6
What display MsgDebug ( cNM1, cNM2) ?
Hi Edward,
The same...
The same...
- f1.png (5.62 KiB) Viewed 2079 times
Can you prepare a sample of running code and sample SQL database? You've written before that gives the correct results. Show you in the console window or something else, e.g. in a file?
? cNM1- mjaviergutierrez
- DBs Used: DBF, MySQL
Hola !
edk dice : For version 8.0, the file can be found in the folder: C:\Program Files\MySQL\MySQL Server 8.0\lib\libmysql.dll
Pero me dá este error ....
- Captura de pantalla 2024-12-21 121426.png (8.63 KiB) Viewed 2063 times
Edward,
I get this error :
I missed something...?
I get this error :
P:/hmg.3.6/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lssleay32: No such file or directory
P:/hmg.3.6/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -llibeay32: No such file or directory
Serge, note what I wrote about having to modify the file p:\hmg.3.6\harbour64\contrib\hbssl.hbc
You cannot use the 32 bit libeay32 and ssleay32 libraries. In your .hbp project file you need to make changes to the use of 64 bit libraries to
or instead of these three definitions you just write one
libs=hbssl
libs=libssl-3-x64
libs=libcrypto-3-x64Code: Select all
hbcs=hbssl.hbc- serge_girard
Thanks! Forgot about that...!
