HMG 3.6 (64 bit version)
Red2
Re: HMG 3.6 (64 bit version)
Post by Red2 »
Hello EDK,
Thank you for your very generous work on adapting hblibxlsxwriter to 64-bit.
Your kind efforts in this (and so many other matters) are much appreciated!
Hopefully others with C experience will share their ideas.
Gracias por su generoso trabajo en la adaptación de hblibxlsxwriter a 64 bits.
¡Sus amables esfuerzos en este (y tantos otros asuntos) son muy apreciados!
Con suerte, otros con experiencia en C compartirán sus ideas.
edk wrote: Wed May 17, 2023 2:02 pm There is a problem with the console mode under hmg.3.6: if I set the GT driver in the sources: REQUEST HB_GT_WIN_DEFAULT, the application starts but the console window is not visible, you have to kill the application via the task manager.
Hi Edward,
There is not a problem with the console mode. ;)
Please take a look at the attached archive along with the console executable. :arrow:
Note that the compilation line should be like this
build.bat hello.prg
CONSOLE.ZIP
(668.32 KiB) Downloaded 6248 times
gfilatov wrote: Wed May 17, 2023 3:13 pm Hi Edward,
build.bat hello.prg
Hi Grigory, but it's not quite OK.
Maybe I didn't explain exactly what I mean.
In previous versions of HMG, although I called the build without the /c parameter (%gtdrivers% is -gtgui -gtwin), e.g. call c:\hmg.3.4.4\build.bat hello.prg and in the .prg file I had declared REQUEST HB_GT_WIN_DEFAULT then according to this declaration the default driver was GT_WIN.
However, in hmg.3.6 this is not the case. The REQUEST HB_GT_WIN_DEFAULT command is ignored and I have to compile with /c enabled (%gtdrivers% is -gtwin -gtgui). Equally, the same .prg can be without the REQUEST HB_GT_WIN_DEFAULT declaration and compiled with the /c parameter, so why declare it? Yes, to make it work without the /c parameter.
I would like it to be as before so that I don't have to remember that I have some prg. compile differently than the others just because I use the GT_WIN driver. HB_GT_WIN_DEFAULT is declared so this should work and it shouldn't matter which GT drivers are in order.
edk wrote: Thu May 18, 2023 8:46 am
build.bat hello.prg
I understand your point of view.
But I guess that it is impossible after the following Harbour modification:
2023-01-15 11:17 UTC+0100 Przemyslaw Czerpak (druzus/at/poczta.onet.pl)
* src/rtl/hbgtcore.c
* changed the order of defualt GT initialization. Now GT specified by -gt*
hbmk2 option has higher priority then GT chosen by
request HB_GT_<name>_DEFAULT
It is a solution of the main Harbour developer :shock:
gfilatov wrote: Thu May 18, 2023 9:07 am It is a solution of the main Harbour developer :shock:
Thanks Grigory for the explanations, indeed a change at the harbour level - I personally don't understand this change, but it's Przemek's decision.
vientopamperosur
DBs Used: DBF, SQLite, MySQL, MariaDB, PostgreSQL
Post by vientopamperosur »
Muchas gracias, la probaré y comentaré.
ROBROS
Post by ROBROS »
Rathinagiri wrote: Wed May 10, 2023 2:11 pm Please test with your existing projects.
If you are using IDE, please select to use IDE for 64 bits. Otherwise use the build64.bat file to build. Any discrepancy please report.
I downloaded and setup. For building a program I use IDE. But ide.exe is dated 26.03.2017 and is 32 bit. Where can I download 64 bit IDE?
TIA
Robert
ROBROS
Post by ROBROS »
TIA
Robert
Now everything seems to be ok. When Choosing run in IDE I got a message "build.bat" not found and program terminated. When searching for build.* I found build64.bat. I renamed it to build.bat. Result: a new exe. Size of the old exe: 4389 kb, size of new exe:4637 kb
Red2
Post by Red2 »
Hi Robros,
That worked well for me too!
ROBROS
Post by ROBROS »
Thx for confirming. As you can see on my screenshot, the status line on ide was a bit confusing me.
