implement LETODB
fouednoomen
Re: implement LETODB
Post by fouednoomen »
how I can connect simultaneously to two LETODB servers from a workstation on the same application
thanks in advance
I dind't try.
Really interesting
fouednoomen
I just found this article on a site which confirms the possibility of simultaneously connecting to several servers from a single application but I cannot deploy the solution.
i need your help
Try this:
#include "dbinfo.ch"
//#include "leto_std.ch"
REQUEST LETO
//RDDSETDEFAULT( "DBFCDX" )
REQUEST HB_GT_WIN_DEFAULT
REQUEST HB_LANG_PL852
request HB_CODEPAGE_PL852
	Local i, plikDBF1, plikNTX1, plikDBF2, plikNTX2, lCreate, pola, plik
	public cRDDDriver := "DBFNTX"
	public cLocalRDDDriver := "DBFNTX"
	public cLetoSerwer1 := "192.168.1.18"
	public nLetoSerwerPort1 := 2812
	public cLetoSerwer2 := "192.168.1.52"
	public nLetoSerwerPort2 := 2812
	public nHotbuf := 100
	public nTimeOut := 6000
	public lUseSerwerLeto1 := .F.
	public nStatusLETO1 := -1
	public cLetoSerwerPath1 := ""
    public lAllowWorkWithoutLetoSerwer := .T.
    Public cPath1 := ""
    public lUseSerwerLeto2 := .F.
	public nStatusLETO2 := -1
	public cLetoSerwerPath2 := ""
    Public cPath2 := ""
    Public cLetoUser := ""
    Public cLetoPass := ""
SET LANGUAGE TO POLISH
SET CODEPAGE TO POLISH
SET MULTIPLE OFF WARNING
set( _SET_CODEPAGE, "PL852" )
hb_LangSelect( 'PL852')
SETBLINK(.F.)
SETCANCEL(.F.)
SET MARGIN TO 0
SET SCOREBOARD OFF
SET WRAP ON
SET CONFIRM ON
SET DATE ANSI
SET ESCAPE OFF
@0,0 CLEA
if !( Empty( cLetoSerwer1 ) .OR. Empty(nLetoSerwerPort1) )
	cLetoSerwerPath1 := "//" + Alltrim ( cLetoSerwer1 ) + ":" + Alltrim( Str( nLetoSerwerPort1 ) ) + "/"
	lUseSerwerLeto1 := (( nStatusLETO1 := LETO_CONNECT( cLetoSerwerPath1, cLetoUser /*user*/, cLetoPass /*pass*/, nTimeOut /*timeout*/, nHotBuf /*hot buffer*/ )) >= 0)
	? "nStatusLETO1", nStatusLETO1
	if lUseSerwerLeto1
		RDDSETDEFAULT( "LETO" )
		cRDDDriver := "LETO"
		cPath1 := cLetoSerwerPath1
		? "1", LETO_GetServerVersion(), " at address: ", Leto_getLocalIP( .T. )
		? "DBF DATABASE DRIVER        :", LETO_DBDRIVER()[ 1 ], "MEMOTYPE:", LETO_DBDRIVER()[ 2 ]
		? "CurrentConnection: ", LETO_GETCURRENTCONNECTION()
		if lAllowWorkWithoutLetoSerwer
			? "Brak połączenia z serwerem LETO1 ", cLetoSerwerPath1, leto_Connect_Err( .T. )
			? "Brak połączenia z serwerem LETO1 ", cLetoSerwerPath1, leto_Connect_Err( .T. ), "Program zatrzymany!"
			quit
		RDDSETDEFAULT( "DBFNTX" )
if !( Empty( cLetoSerwer2 ) .OR. Empty(nLetoSerwerPort2) )
	cLetoSerwerPath2 := "//" + Alltrim ( cLetoSerwer2 ) + ":" + Alltrim( Str( nLetoSerwerPort2 ) ) + "/"
	lUseSerwerLeto2 := (( nStatusLETO2 := LETO_CONNECT( cLetoSerwerPath2, cLetoUser /*user*/, cLetoPass /*pass*/, nTimeOut /*timeout*/, nHotBuf /*hot buffer*/ )) >= 0)
	? "nStatusLETO2", nStatusLETO2
	if lUseSerwerLeto2
		cPath2 := cLetoSerwerPath2
		? "2", LETO_GetServerVersion(), " at address: ", Leto_getLocalIP( .T. )
			? "Brak połączenia z serwerem LETO2 ", cLetoSerwerPath2, leto_Connect_Err( .T. )
			? "Brak połączenia z serwerem LETO2 ", cLetoSerwerPath2, leto_Connect_Err( .T. ), "Program zatrzymany!"
			quit
? "UseLetoSerwer1", lUseSerwerLeto1
? "UseLetoSerwer2", lUseSerwerLeto2
? "RDD: ", RddSetDefault(),  " , DBF EXTENSION:", hb_rddInfo( RDDI_TABLEEXT )
inkey ( 5 )
plikDBF1 := cPath1 + "MyFile1.DBF"
plikNTX1 := cPath1 + "Indeksy1.NTX"
lCreate := .F.
if !lUseSerwerLeto1
	lCreate := !File( plikDBF1 )
	lCreate := !Leto_file( plikDBF1 )
? "Create file ", plikDBF1, lCreate
inkey (1)
if lCreate
	pola := {}
	AADD(pola, {'REGON','N',13,0})
	AADD(pola, {'AKT','C',2,0})
	AADD(pola, {'DATA','D',8,0})
	//file on Leto server #1
	DBCREATE( F_DBF (plikDBF1), pola )
	DBUseArea(.T., cRDDDriver, F_DBF (plikDBF1), .f., .f.)
	INDEX ON regon TO &plikNTX1
	FOR i:=1 TO 10
		APPEND BLANK
		REPLACE regon WITH i
		REPLACE akt WITH CHR(i+64)
		REPLACE data WITH hb_date() - i
	NEXT i
	USE
SELECT 1		//file on Leto server #1
plik := F_DBF ( plikDBF1 )
USE &plik INDEX &plikNTX1
? ALIAS()
go top
do while !eof()
? recno()
?? regon
?? akt
?? data
inkey(1)
skip
enddo
plikDBF2 := cPath2 + "MyFile2.DBF"
plikNTX2 := cPath2 + "Indeksy2.NTX"
lCreate := .F.
if !lUseSerwerLeto2
	lCreate := !File( plikDBF2 )
	lCreate := !Leto_file( plikDBF2 )
? "Create file ", plikDBF2, lCreate
inkey (1)
if lCreate
	pola := {}
	//file on Leto server #2
	DBCREATE( F_DBF (plikDBF2), pola )
	DBUseArea(.T., cRDDDriver, F_DBF (plikDBF2), .f., .f.)
	INDEX ON regon TO &plikNTX2
	USE
SELECT 2	//file on Leto server #2
plik := F_DBF ( plikDBF2 )
USE &plik INDEX &plikNTX2
GO TOP
DO WHILE !EOF()
	APPEND BLANK
	REPLACE 2->regon WITH 1->regon
	REPLACE 2->akt WITH 1->akt
	REPLACE 2->data WITH 1->data
	SKIP
ENDDO
? ALIAS()
go top
do while !eof()
? recno()
?? regon
?? akt
?? data
inkey(1)
skip
enddo
close data
Leto_Disconnect( cLetoSerwerPath1 )
Leto_Disconnect( cLetoSerwerPath2 )
? "press any key to exit...."
inkey(0)
QUIT
FUNCTION F_DBF ( cFileName )
RETURN hb_FNameExtSet(cFileName, "")
Note: Unlike to RDD "DBFNTX" when referencing DBF files in "LETO" (eg USE, DBCREATE) the default file extension ".DBF" cannot be used, causes error 1010 invalid characters in Alias.
JRGEMS
Post by JRGEMS »
After I add the following line in my main prg, error occurs while compiling.
REQUEST leto
error on compiling:
hbmk2: Error: Referenced, missing, but unknown function(s): LETO()
Ramesh Bhat.
1. Download the package from Marek containing the library "librddleto_20190517.a" (link: http://hmgforum.com/viewtopic.php?p=65987#p65987)
2. Place the downloaded file librddleto_20190517.a in the folder c:\hmg.3.4.4\lib\
3. If you are using the IDE, in the project's * .hbc configuration file enter: libs=rddleto_20190517
or
3. If you are using build.bat: your command line should look like this: call c:\hmg.3.4.4\build.bat project.hbp -lrddleto_20190517
JRGEMS
Post by JRGEMS »
Thank you EDK.
Now it is compiling OK using IDE.
Build.bat still giving same error.
my command prompt build command is:
build.bat jt.hbp jt.hbc
jt.hbc given below:
incpaths=
libpaths=
gt=
mt=yes
Bhat.
Try:
build.bat jt.hbp -lrddleto_20190517
Hi!
I want to refresh this topic.
Now, I need to connect to read and write data from php application.
Sample attached to leto is working,but it shows only a few information.
Did anybody realize change data from PHP to DBF and vice versa?
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
