NC Clone
Re: NC Clone
Hi Jimmy,
I just test it on another PC, but it has the same error message, could please take a look of the " Registry HKEY_CURRENT_USER\Control Panel\Colors" that I snap from my PC. Thanks.
- 2020-02-12_085150.jpg (218.26 KiB) Viewed 6237 times
- AUGE_OHR
Re: NC Clone
it seems me all OK
hm ... i just can send you DBF/FPT and hope it will work with your PC.
it seems me all OK
Re: NC Clone
Hi Jimmy,
It works now with those files that you provided. Thanks.
- AUGE_OHR
Re: NC Clone
i have found "my Error" ...
YOU are right on C_FMSETUP but i try it wrong Way.
Problem of ErrorLog.HTM : it does not show Argument "A" <> "N"
under Xbase++ i use "Number" for Color but under harbour / HMG i use RGB Array.
so i have to convert RGB to Number ... and that i forgot in C_FMSETUP
i have fix "my Error" and add new : Everything Search (ALT-F7)
also USB Eject is include ( Icon on Taskbar )
btw. Icon on Taskbar all working
REPLACE COLOR1 WITH RGB2Num(SP_nColor1())i have fix "my Error" and add new : Everything Search (ALT-F7)
- AUGE_OHR
Re: NC Clone
to use ALT-F7 you need Everything.DLL in Path.
how to configure it you can read here
http://hmgforum.com/viewtopic.php?f=12&t=6192
- AUGE_OHR
Re: NC Clone
v0.38 fixed :
F2 some CSIDL_
F3 it work with BMP ... but fail with JPG, GIF, PNG
USB Eject "Info" output
new :
all Image as Bitmap Resource "MY"
Contex Menu -> Tab Close
with new ErrorSys
Directory() with DHS and "L" (Hardlink ... under construction )
add "UpDirPath" and "RootUpDirPath" Button
v0.38 fixed :
F2 some CSIDL_
new :
with new ErrorSys
- AUGE_OHR
Re: NC Clone
v0.042 fixed :
add new :
RegDB in Toolbar
Contex Menu ->
"send to Desktop"
"send to Startup"
"Properties"
GETKEYBOARDLAYOUT() -> German -> 1031
-> F11 Menue DE or EN
v0.042 fixed :
add new :
RegDB in Toolbar
Contex Menu ->
"send to Desktop"
"send to Startup"
"Properties"
Re: NC Clone
I have got the following error after pressing 'Plus' key:
HMG Errorlog File
Date:02/18/2020 Time: 09:15:12
Error BASE/1003 Variable does not exist LVIS_SELECTED
Called from ITEMMARK(1123)
Called from DOMARKFILES(3613)
Called from DOAUSWAHL(3517)
Called from DOGRIDKEY2(2347)
Called from (b)DEFGRIDRIGHT(1283)
Called from _HMG_GRIDONCLICKANDONKEYEVENT(608)
Called from EVENTPROCESS(161)
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(5699)
Called from MAIN(846)
- AUGE_OHR
Re: NC Clone
dammit, i lost a #include file ...gfilatov wrote: ↑Tue Feb 18, 2020 7:56 am Hi,
I have got the following error after pressing 'Plus' key:HMG Errorlog File
i have change "somewhere" Warning Parameter and now i got no Warning when missing Constant.
i try to include -w -es2 into *. HBP but after load Project it is gone.
i also try *.HBC but it seems not to work.
so where do i enable Warning again
fixed Version v0.042a
- AUGE_OHR
Re: NC Clone
i have found my Problem : missing "hbmk.hbm"
so now Variable, which are not declare, will produce Error when compile.
but there was a 2nd Problem : i have change Errorsys and Array-Error will produce recursive Error ---
so here clean-up Version v0.043
HBFM.hbc
-w1 -es2
-mtbut there was a 2nd Problem : i have change Errorsys and Array-Error will produce recursive Error ---
