Login to website
Re: Login to website
tomtagaris wrote: Wed Sep 25, 2019 11:27 am thank you very much edk
I'm trying to understand how it works
it's too deep for me
and my english is not good
your work is amazing
Thank you very much
without your help I wouldn't succeed
I hope this is the last thing I ask of you
Also remember that the received xml are encoded in UTF-8. If you use other character encoding in your application, you should translate the strings to your code page:
hb_utf8ToStr( <cUTF8Str> [, <cCPID>] ) ➜ cStr
it performs "translation" from UTF-8 to <cCPID> Harbour codepage id, f.e.: "EN", "ES", "ESWIN" etc.
<cUTF8Str> supposed to be a UTF-8 encoded string.
When <cCPID> is not given then the default HVM codepage (i.e. that set by hb_cdpSelect()) is used.
tomtagaris
Post by tomtagaris »
Thank you very much
tomtagaris
USE THE RATES BUT I HAVE NO RESULT
REQUEST HB_LANG_EL
REQUEST HB_CODEPAGE_ELBIN
SET CODEPAGE TO GREEK
REQUEST HB_CODEPAGE_ELWIN
HB_LANGSELECT ("ELWIN")
HB_CDPSELECT ("ELWIN")
cAnsi: = hb_UTF8ToStr (responseHttp, "ELWIN")
cOEM: = HB_ANSITOOEM (cAnsi) OR cOEM: = HB_OEMTOANSI()
THE RESULT IS SAME
tomtagaris
TRYING TO UNDERSTAND THE XML FILE
IN THIS XML WHO IT IS THE NODE
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<packages>
<package actor_afm="029690710" month="3" year="2017">
<groupedRevenues action="replace">
<revenue>
<afm>029690710</afm>
<amount>8,63</amount>
<tax>1,12</tax>
<invoices>1</invoices>
<note>normal</note>
<date>2018-02-28</date>
</revenue>
<revenue>
<amount>0</amount>
<tax>0</tax>
<note>normal</note>
<date>2014-01-01</date>
</revenue>
</groupedRevenues>
<groupedExpenses action="replace">
<expense>
<amount>656,00</amount>
<tax>85,29</tax>
<invoices>4</invoices>
<note>normal</note>
<nonObl>0</nonObl>
</expense>
<expense>
<amount>105,92</amount>
<tax>24,22</tax>
<invoices>3</invoices>
<note>normal</note>
<nonObl>0</nonObl>
</expense>
<expense>
<amount>172,49</amount>
<tax>22,42</tax>
<note>normal</note>
<nonObl>0</nonObl>
</expense>
<expense>
<amount>5,64</amount>
<tax>1,35</tax>
<note>normal</note>
<nonObl>0</nonObl>
</expense>
<expense>
<amount>10,00</amount>
<tax>2,40</tax>
<note>normal</note>
<nonObl>0</nonObl>
</expense>
<expense>
<amount>16,13</amount>
<tax>3,87</tax>
<note>normal</note>
<nonObl>0</nonObl>
</expense>
<expense>
<amount>662,50</amount>
<tax>0,00</tax>
<note>normal</note>
<nonObl>1</nonObl>
</expense>
<expense>
<amount>0</amount>
<tax>0</tax>
<note>normal</note>
<nonObl>0</nonObl>
</expense>
</groupedExpenses>
<groupedCashRegisters action="replace">
<cashregister>
<amount>301,20</amount>
<tax>4108,19</tax>
</cashregister>
</groupedCashRegisters>
<otherExpenses>
<amount>1370,84</amount>
<tax>170,42</tax>
</otherExpenses>
</package>
</packages>
And you see, my poor English came out :)
Probably incorrectly "group" or "data block" I called "node". Big apologies.
Each "group" is a hash table, consisting of as many elements as there are instances of the "group" in xml. Each of the elements of this "group" may contain subsequent "groups" (subsequent tables) and / or "node" (hash pairs specifying name_node => value).
If there are any attributes in the "group" then another hash table containing these attributes is created (attribute_name => value).
Bez tytułu.png (94.55 KiB) Viewed 5901 times
You can debug the contents of the Hash table by MsgDebug ( hHash ).
tomtagaris wrote: Thu Sep 26, 2019 8:38 am USE THE RATES BUT I HAVE NO RESULT
REQUEST HB_LANG_EL
THE RESULT IS SAME
Please, sent a xml in Greek encoded utf-8
tomtagaris
if i understood good first then this is it
xInvoice := hHash["packages"][1]["package"][1]
for i=1 TO Len( xInvoice )
xInv_Root :=xInvoice[ i ][1]["actor_afm"] +xInvoice[ i ][1]["month"]+xInvoice[ i ][1]["year"]
next i
This is not the case, because "actor_afm", "year", "month" are not nodes but are attributes.
If you had this xml structure:
<packages>
	<package>
		<actor_afm>029690710</actor_afm>
		<month>3</month>
		<year>2017</year>
			<revenue>
				<tax>1,12</tax>
				<note>normal</note>
			</revenue>
		</groupedRevenues>
	</package>
</packages>
then it would be correct.
Note that the group "groupedRevenues" also has one attribute called "action" with the value "replace"
See in the image from my previous post, I showed how to read the attributes.
In your example, this will be correct:
xAttr_year:=hHash["packages"][1]["package@attribute"]["year"]
xAttr_month:=hHash["packages"][1]["package@attribute"]["month"]
xAttr_actor_afm:=hHash["packages"][1]["package@attribute"]["actor_afm"]
xAttr_action:=hHash["packages"][1]["package"][1]["groupedRevenues@attribute"]["action"]
msgdebug (hHash["packages"][1]["package"][1]["groupedRevenues"][1]["revenue"][1]["date"])
msgdebug (hHash["packages"][1]["package"][1]["groupedRevenues"][1]["revenue"][2]["date"])
tomtagaris
yes I understood it now
I understood what its structure is
Thanks again edk
tom
tomtagaris
LET'S REPEAT ANY QUESTION
WHAT IS THE DIFFERENCE BETWEEN THIS FILE AND THE PREVIOUS
SO THIS FILE CAN'T RECEIVE THE DATA BUT THE PREVIOUS WORK IS RIGHT
I CANNOT UNDERSTAND THE PROBLEM
<?xml version="1.0" encoding="utf-8"?>
<RequestedInvoicesDoc xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<invoicesDoc>
<invoice xmlns="http://www.aade.gr/myDATA/invoice/v1.0">
<uid>8B5F90485B444AC25259C053646A3F098C6965F9</uid>
<mark>1000000280443</mark>
<issuer>
<vatNumber>029690710</vatNumber>
<country>GR</country>
<name>οΏ½οΏ½οΏ½οΏ½οΏ½οΏ½οΏ½</name>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>οΏ½</series>
<aa>2</aa>
<issueDate>2019-07-19</issueDate>
<invoiceType>1.1</invoiceType>
<vatPaymentSuspension>true</vatPaymentSuspension>
<currency>EUR</currency>
<exchangeRate>8.00</exchangeRate>
<correlatedInvoices />
<selfPricing>false</selfPricing>
<dispatchTime>16:47:51.7000000+00:00</dispatchTime>
<vehicleNumber />
<movePurpose>1</movePurpose>
</invoiceHeader>
<invoiceDetails>
<lineNumber>1</lineNumber>
<measurementUnit>1</measurementUnit>
<netValue>140</netValue>
<vatCategory>2</vatCategory>
<vatExemptionCategory>1</vatExemptionCategory>
<dienergia>
<applicationId />
<applicationDate>1986-12-20</applicationDate>
<shipId />
</dienergia>
<discountOption>true</discountOption>
<withheldAmount>0</withheldAmount>
<stampDutyPercentCategory>1</stampDutyPercentCategory>
<feesAmount>0</feesAmount>
<otherTaxesPercentCategory>1</otherTaxesPercentCategory>
<deductionsPercentage>0</deductionsPercentage>
<incomeClassification>
<classificationType>101</classificationType>
<classificationCategory>1</classificationCategory>
<amount>140</amount>
</incomeClassification>
</invoiceDetails>
<invoiceDetails>
<quantity>10</quantity>
<invoiceDetailType>1</invoiceDetailType>
<dienergia>
<applicationId />
<applicationDate>2004-12-14</applicationDate>
<shipId />
</dienergia>
<withheldPercentCategory>1</withheldPercentCategory>
</invoiceDetails>
<invoiceSummary>
<totalNetValue>140</totalNetValue>
<totalVatAmount>18.2</totalVatAmount>
<totalWithheldAmount>0</totalWithheldAmount>
<totalFeesAmount>0</totalFeesAmount>
<totalStampDutyAmount>0</totalStampDutyAmount>
<totalOtherTaxesAmount>0</totalOtherTaxesAmount>
<totalDeductionsAmount>0</totalDeductionsAmount>
<totalGrossValue>158.2</totalGrossValue>
<amount>158.2</amount>
</invoiceSummary>
</invoice>
<mark>1000000282404</mark>
<issuer>
<name>ΤΑΓΑΡΗΣ</name>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<aa>1</aa>
<dispatchTime>16:47:51.0000000+00:00</dispatchTime>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
<quantity>1</quantity>
<invoiceDetailType>2</invoiceDetailType>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000282405</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<uid>33632AB432D1D0FEB5F48F26821490CDB918CB1D</uid>
<mark>1000000916314</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
<discountOption>false</discountOption>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000916315</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000916316</mark>
<issuer>
<name>ΤΑΓΑΡΗΣ ΑΘΑΝΑΣΙΟΣ</name>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000916317</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000916489</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000916999</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000917670</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
<netValue>158.2</netValue>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000917672</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000917673</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000917675</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<mark>1000000917679</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>A</series>
<aa>1</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
</invoicesDoc>
</RequestedInvoicesDoc>
