Drag grid item to another grid
Re: Drag grid item to another grid
Great Work Edward !
One question : would it also be possible to COPY to grid2 with CTRL-key (now it is always MOVEd)?
serge_girard wrote: Fri Jan 04, 2019 3:14 pm Great Work Edward !
What to do during the DragAndDrop operation depends on how you program this event.
You have the following functions:
HMG_DaD_Drag_Window () -> returns the name of the form from which the drag started.
HMG_DaD_Drag_Control () -> returns the name of the control from which the drag started.
HMG_DaD_Drop_Window () -> returns the name of the form on which it was dropped.
HMG_DaD_Drop_Control () -> returns the name of the control on which it was dropped.
HMG_DaD_DragTreeValue () -> returns the value of the position of the tree from which the drag began.
HMG_DaD_DropTreeValue () -> returns the value of the tree position on which it was dropped.
HMG_Is_RButtonDaD () -> returns .T. if dragging was with the right mouse button.
Replace this function to copy from tree # 1 to tree # 2 with the right mouse button or with the ALT key.
Function Drag_Tree2()
Local cDragFName := HMG_DaD_Drag_Window()
Local cDragCName := HMG_DaD_Drag_Control()
Local cDropFName := HMG_DaD_Drop_Window()
Local cDropCName := HMG_DaD_Drop_Control()
Local nDragTreeValue := HMG_DaD_DragTreeValue()
Local nDropTreeValue := HMG_DaD_DropTreeValue()
Local lIsDraggedWithRightButton := HMG_Is_RButtonDaD()
Local lCopy, aDragItems, nAddPos
IF HMG_Is_DaD()
	HMG_Release_DaD()
	DO CASE
		CASE cDropCName == 'Tree_2'
			//Move nodes/items
			lCopy := HMG_VirtualKeyIsPressed (VK_LCONTROL) .OR. HMG_VirtualKeyIsPressed (VK_RCONTROL) .OR. HMG_VirtualKeyIsPressed (VK_ALT) .OR. lIsDraggedWithRightButton
			aDragItems := _GetTreeItemStru( cDragFName, cDragCName, nDragTreeValue )
			IF !EMPTY ( aDragItems )
				IF !lCopy .AND. nDropTreeValue < nDragTreeValue		//dropped above the drag
					DoMethod (cDragFName, cDragCName, "DeleteItem", nDragTreeValue)
				nAddPos := nDropTreeValue
				AEVAL ( aDragItems, { |x| ( DoMethod (cDropFName, cDropCName, "AddItem", x[2] , nAddPos + x[3] ),  IF( x[3]=0 /* 1-st item added as last nodes item */, nAddPos := nAddPos + LEN( _GetTreeItemStru( cDropFName, cDropCName, nDropTreeValue ) ) - 1 - x [1] , Nil) ) } )
				IF !lCopy .AND. nDropTreeValue > nDragTreeValue		//dropped below the drag
				DoMethod (cDropFName, cDropCName, "Redraw")
				DoMethod (cDragFName, cDragCName, "Redraw")
		ENDCASE
Control and Shift key disrupt the action of DragAndDrop (they trigger a separate event while dragging) but you can read their value when dropped. So just before dropping, press and hold Control and then drop.
Great !
Edk
Very interesting
Congratulations
Great work!
It would be excellent to have colorized new parent element in the tree while dragging child.
Thank you very much, Edward!
Anand
Post by Anand »
Thanks Edward for such a useful enhancement !!
Anand
Anand
quartz565
Post by quartz565 »
Thank you Edward!
Nikos.
os: Windows Server 2019 - 64
mol wrote: Sat Jan 05, 2019 7:10 am Great work!
Marku, mówisz i masz :D
Marek. You say, and you have. :D
DragAndDrop_0.005.zip
(11.84 KiB) Downloaded 513 times
Tree DragAndDrop.gif (77.57 KiB) Viewed 24117 times
Jesteś wielki!
Król Edward na 3 Króli! :-D
Ps. Jakim programem robisz te animowane gify?
Dzięki, gify zrobilem oCam'em
