label at runtime
Re: label at runtime
Here is working demo ;)
 * Copyright 2008 Roberto Lopez <mail.box.hmg@gmail.com>
 * http://www.hmgforum.com//
Local aRows [20] [3]
	aRows [1]	:= {'Simpson','Homer','555-5555'}
	aRows [2]	:= {'Mulder','Fox','324-6432'}
	aRows [3]	:= {'Smart','Max','432-5892'}
	aRows [4]	:= {'Grillo','Pepe','894-2332'}
	aRows [5]	:= {'Kirk','James','346-9873'}
	DEFINE WINDOW Form_1 ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'HMG Demo' ;
		MAIN
		DEFINE TAB Tab_1 ;
			AT 10,10 ;
			WIDTH 600 ;
			HEIGHT 400 ;
			VALUE 1 ;
			TOOLTIP 'Tab Control'
			PAGE 'Page 1'
			      @ 100,250 BUTTON Button_1 CAPTION "Add Label On Page 4" WIDTH 150 HEIGHT 50 ACTION Make_label()
			      @ 180,250 BUTTON Button_2 CAPTION "Release Label On Page 4" WIDTH 150 HEIGHT 50 ACTION IF (IsControlDefined (NewLabel2 , Form_1) , DoMethod('Form_1','NewLabel2','Release') , Nil )
			END PAGE
			PAGE 'Page &2'
				DEFINE RADIOGROUP R1
					ROW	100
					COL	100
					OPTIONS	{ '1','2','3' }
					VALUE	1
				END RADIOGROUP
			END PAGE
			PAGE 'Page 3'
				@ 100,250 SPINNER Spinner_1 ;
				RANGE 0,10 ;
				VALUE 5 ;
				WIDTH 100 ;
				TOOLTIP 'Range 0,10' ;
				ON CHANGE PlayBeep()
			END PAGE
			PAGE 'Page 4'
				@ 50,50 GRID Grid_1 ;
					WIDTH 200 ;
					HEIGHT 330 ;
					HEADERS {'Last Name','First Name','Phone'} ;
					WIDTHS {140,140,140};
					ITEMS aRows ;
					VALUE 1
			END PAGE
		END TAB
	Form_1.Center
	Form_1.Activate
FUNCTION Make_label()
 define label NewLabel2
			parent Form_1
			row 150
			col 300
			backColor {96,96,96}
			value "BAR"
			height 80
			width  30
end label
//_AddTabControl ( TabName , ControlName , ParentForm , PageNumber , Row , Col )
_AddTabControl ( 'Tab_1' , 'NewLabel2' , 'Form_1' , 4 , 150 , 300 )
It is very simple.
First define the control having the parent as the same window where the tab resides.
Then use the following method to add the control the the tab page.
<WindowName>.<ControlName>.AddControl ( ControlName , nPagenumber , nRow , nCol )
hI!
I found a bug in BosTaurus BT_DrawTextEx function
I want to print centered text rotated by 90 deg.
But, when changing length of text , it's position is not centered in vertical axis, it's always always positioned at the begin row, bet column of text is changed.
I think it should be opaque
jairpinho
Post by jairpinho »
mol wrote: Wed Nov 11, 2020 10:11 am hI!
Marek can post the code he used
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
I prepared some code, maybe I'm wrong, but centering text is with bug.
Also, vertical orientation is bad.
function main
	DEFINE WINDOW F1 ;
		WIDTH 700 HEIGHT 700 ;
		TITLE 'Draw text sample' ;
		MAIN ;
		backcolor {225,255,255} ;
		ON PAINT DoTest()
		DEFINE MAIN MENU OF F1
			DEFINE POPUP "tEST"
				MENUITEM "Test" action NIL
			END POPUP
		END MENU
	CENTER WINDOW F1
	ON KEY ESCAPE OF F1 ACTION F1.RELEASE
	ACTIVATE WINDOW F1
return
function DoTest
	local nMiddleRow
	local nMiddleCol
	LOCAL hDC, BTstruct
	hDC := BT_CreateDC ("F1", BT_HDC_INVALIDCLIENTAREA, @BTstruct)
	nMiddleRow := F1.Height/2
	nMiddleCol := F1.Width/2
	// print cross in the middle of the form
	DRAW LINE IN WINDOW F1 at nMiddleRow, 0 to nMiddleRow, F1.Width PENCOLOR RED PENWIDTH 1
	DRAW LINE IN WINDOW F1 at 0, nMiddleCol  to F1.Height, nMiddleCol PENCOLOR RED PENWIDTH 1
	//print vertical margins
	DRAW LINE IN WINDOW F1 at nMiddleRow-201, nMiddleCol-201  to nMiddleRow+201, nMiddleCol-201 PENCOLOR {0,128,0} PENWIDTH 1
	DRAW LINE IN WINDOW F1 at nMiddleRow-201, nMiddleCol+201  to nMiddleRow+201, nMiddleCol+201 PENCOLOR {0,128,0} PENWIDTH 1
	// draw text in normal -  horizontal orientation
	// left aligned
	BT_DrawTextEx(hDC,;
			nMiddleRow-200, nMiddleCol-200,;			// row, col
			400, 20,;								// width, height
			"Normal, horizontal oriented, left aligned text",;
			"ARIAL", 12,;
			{0,128,0}, {255,255,224},;
			BT_TEXT_OPAQUE + BT_TEXT_BOLD,;
			BT_TEXT_LEFT + BT_TEXT_TOP,;
			BT_TEXT_NORMAL_ORIENTATION)
	// center aligned
	BT_DrawTextEx(hDC,;
			nMiddleRow-170, nMiddleCol-200,;			// row, col
			"Normal, horizontal oriented, centered text",;
			"ARIAL", 12,;
			BT_TEXT_CENTER + BT_TEXT_TOP,;
	// right aligned
	BT_DrawTextEx(hDC,;
			nMiddleRow-140, nMiddleCol-200,;			// row, col
			"Normal, horizontal oriented, right aligned text",;
			"ARIAL", 12,;
			BT_TEXT_RIGHT + BT_TEXT_TOP,;
	//print horizontal margins
	DRAW LINE IN WINDOW F1 at nMiddleRow-201, nMiddleCol-201  to nMiddleRow-201, nMiddleCol+201 PENCOLOR {255,128,0} PENWIDTH 1
	DRAW LINE IN WINDOW F1 at nMiddleRow+201, nMiddleCol-201  to nMiddleRow+201, nMiddleCol+201 PENCOLOR {255,128,0} PENWIDTH 1
	// draw text in vertical orientation
	// left aligned
	BT_DrawTextEx(hDC,;
			nMiddleRow+200, nMiddleCol-200,;			// row, col
			"Vertical oriented,left aligned text",;
			"ARIAL", 9,;
			{255,0,0}, {255,255,128},;
			BT_TEXT_VERTICAL_ASCENDANT)
	// center aligned
	BT_DrawTextEx(hDC,;
			nMiddleRow+200, nMiddleCol-180,;			// row, col
			"Vertical oriented, center aligned text",;
			"ARIAL", 9,;
			{255,0,255}, {255,255,128},;
	// the same coordinates as above, but longer text
	BT_DrawTextEx(hDC,;
			"Vertical oriented, center aligned text - transparent - which is longer - drawn somewhere",;
			"ARIAL", 8,;
			BT_TEXT_TRANSPARENT + BT_TEXT_BOLD,;
	// right aligned
	BT_DrawTextEx(hDC,;
			nMiddleRow+200, nMiddleCol+200,;			// row, col
			"Vertical oriented, right aligned text",;
			"ARIAL", 9,;
			{0,0,255}, {255,255,128},;
	// tho only one way to print vertical aligned
	// centered text
	w := BT_DrawTextSize(hDC,"VERTICAL ALIGNED CENTERED TEXT", "ARIAL", 10, BT_TEXT_BOLD + BT_TEXT_ITALIC)
	BT_DrawTextEx(hDC,;
			nMiddleRow-200 + w[1]/2 + 400/2, nMiddleCol -w[2]/2,;
			400, 20,;
			"VERTICAL ALIGNED CENTERED TEXT - OK",;
			"ARIAL", 10, {255,0,0}, {224,224,224},;
			BT_TEXT_OPAQUE   + BT_TEXT_BOLD + BT_TEXT_ITALIC,;
			BT_TEXT_LEFT+BT_TEXT_TOP,;
	BT_DeleteDC (BTstruct)
return
Hello Marek,
Thanks for your sample :!:
Please replace in your header file BosTaurus.CH the following line
#define BT_TEXT_CENTER 6
with
#define BT_TEXT_CENTER 1
and try to start your sample with above modification :idea:
It should fix the text center alignment in the horizontal orientation.
