QR Code in HMG
Re: QR Code in HMG
mol wrote: Tue Oct 20, 2020 6:47 pm Sorry, I'm not familiar with Github.
I also don't touch sources because of none knowledge of this
If we do not add new feature in HMG but it is not possible to update bug/correction and upload minor version ?
How will do this ?
It is not time consuming and we can spare such time
Re: QR Code in HMG
If source code/bug fixes are contributed in Git, we can have a HMG bundle weekly updated from GIT.
Re: QR Code in HMG
Rathinagiri wrote: Wed Oct 21, 2020 7:17 am If source code/bug fixes are contributed in Git, we can have a HMG bundle weekly updated from GIT.
How contribute on Git, all user need help to do / submit code to Git
salamandra
DBs Used: DBF, MySQL, SQL
Re: QR Code in HMG
Post by salamandra »
Salamandra, Brazil
apais
Re: QR Code in HMG
Post by apais »
Who's the owner of the actual GitHub repo?
Angel Pais
Carlos Britos
Re: QR Code in HMG
Post by Carlos Britos »
Hi
How to use GitHub ( basic things )
1 go to https://github.com/
2 create an account
- name of your github site.
- your email
- github password
3 go to https://github.com/asistex/HMG
4 click on button fork
5 go to your github site
- there you have a copy (fork) of HMG
form here you can edit sources files from the web or from your your pc.
There are severals tool to use from your pc.
I'm using Github Desktop
1 download and install Github Desktop
2 You have to create a folder in your hard disk something like
c:\myforks
3 Open Github Desktop go to main menu
-> File
-> Clone Repository
-> Tab Github.com
-> select your site and clone
local path must be c:\myforks
4 in c:\myforks\HMG will be downloaded your fork with the sources
from there you can make changes on the sources. Once you check the code then you can commit to your fork
1 open github desktop and you`ll see the changed files
2 add a comment
3 commit to master
4 push origin
For sure i`m forgot some things, sorry
I`m just trying to help, i`m not an expert on git github. So your are at your own risk
Cómo usar GitHub ( muy básico )
1 ir a https://github.com/
2 crear una cuenta
- el nombre de su sitio github.
- su correo electrónico
- contraseña de github
3 ir a https://github.com/asistex/HMG
4 clic en el tenedor del botón
5 ir a su sitio github
- Ahí tienes una copia (fork) de HMG
desde aquí puedes editar los archivos de fuentes desde la web o desde tu pc.
Hay varias herramientas para usar desde tu PC.
Estoy usando Github Desktop
1 descargar e instalar Github Desktop
2 Tienes que crear una carpeta en tu disco duro algo como
c:\myforks
3 Abrir Github Desktop ir al menú principal
-> File
-> Clone Repository
-> Tab Github.com
4 en c:\miforks\HMG se descargará su fork con las fuentes
desde allí puedes hacer cambios en las fuentes. Una vez que compruebes el código, entonces podrás hacer commit a tu fork
1 abre Github Desktop y verás los archivos cambiados
2 añadir un comentario
3 commit to master
4 push origin
Sólo trato de ayudar, no soy un experto en git github. Así que estás bajo tu propio riesgo ...
Carlos
Re: QR Code in HMG
Carlos Britos wrote: Wed Oct 21, 2020 4:16 pm Hi
Carlos
Thank you
salamandra
Re: QR Code in HMG
2 create an account
- your email
- github password
c:\myforks
-> File
-> Clone Repository
-> Tab Github.com
2 add a comment
3 commit to master
4 push origin
2 crear una cuenta
c:\myforks
-> File
-> Clone Repository
-> Tab Github.com
3 commit to master
4 push origin
Carlos
Muchas gracias Carlos!
Salamandra, Brazil
jairpinho
Re: QR Code in HMG
Post by jairpinho »
h_HMG_Zebra.Prg updated on github
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: QR Code in HMG
I'm aboard GitHub....
