PDF Viewer DLL?
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
The following example shows how to:
- resize/maximize Sumatra window,
- display bookmarks panel on start.
Sumatra.zip
(6.01 MiB) Downloaded 408 times
PeteWG
Re: PDF Viewer DLL?
Post by PeteWG »
andyglezl wrote: Sat Feb 18, 2017 1:39 am That is, using the UPX directly in the normal compilation, reduce it more!
Please let me note, that using UPX, if there are no really good reasons to do so, is not a good idea.
And simply reducing the size of executable isn't alone a good reason, since the drawbacks
are significantly more than advantages.-
The same applies for embedding big binaries (like sumatraPDF.exe) into executable.
Using an archiver, like for example the excellent 7-zip, is a much better solution.
best regards,
Pete
PeteWG
Re: PDF Viewer DLL?
Post by PeteWG »
KDJ wrote: Sun Feb 19, 2017 3:44 pm The following example shows how to:
Quite interesting improvements! :thumbsup:
Re: PDF Viewer DLL?
Thanks!
Re: PDF Viewer DLL?
PeteWG wrote: Sun Feb 19, 2017 4:20 pm
best regards,
Pete
In my case, the app, updates itself automatically via the network, and since some clients has slow/unstable connections, minimizing the executable size, saves me a lot of problems, but I agree with you, that if there is no need, it is preferable to avoid EXE compression.
Maybe I should change my updater to work with .7z compressed updates and omit UPX use.
Re: PDF Viewer DLL?
Post by EduardoLuis »
Hi Friends:
This is my first implementation on Roberto Lopez idea.-
Hopping this helps you and give new ideas.-
With regards.
Eduardo
PDF_VIEWER_EXES.zip
(6.84 MiB) Downloaded 354 times
PDF_VIEWER_CODE.zip
(3.6 MiB) Downloaded 405 times
Re: PDF Viewer DLL?
I'm in fault, because i forget to mention that my samples was inspired on KDJ sample posted on this topic.-
Forgive me KDJ and thanks.-
Eduardo
Re: PDF Viewer DLL?
Print PDF silently on default printer
EXECUTE FILE '"' + cExeFile + '"' PARAMETERS '-print-to-default -exit-on-print' + ' "' + cPdfFile
Print PDF on selected printer
EXECUTE FILE '"' + cExeFile + '"' PARAMETERS '-print-dialog -exit-on-print' + ' "' + cPdfFile
Re: PDF Viewer DLL?
Hi BDP:
Thanks for your contribution.-
But i get an error message before printing, as i show:
When i accept, print begins.-
I don't understand why.- Please check if is on my case or on everybody.-
Thanks again.-
Eduardo
Re: PDF Viewer DLL?
EduardoLuis wrote: Tue Feb 21, 2017 1:05 pm Hi BDP:
Thanks again.-
Eduardo
I have no error, code attached
SumatraPrint.rar
(41.34 KiB) Downloaded 354 times
