Backup & Restore Dbf Files
Re: Backup & Restore Dbf Files
Problem lays in these lines:
aTemp := DIRECTORY( BackUp.T_SourceFolder.Value + "\*.*" )
   AEVAL( aTemp, { | a1 | AADD( aFilesToBackup, a1[ 1 ] ) } )
   IF EMPTY( aFilesToBackup )
      MsgStop( "No file found to backup !", " ERROR !" )
      BackUp.ProgressIndicator.RangeMax := len(aFilesToBackup)
      BackUp.ProgressIndicator.Value := 0
      COMPRESS aFilesToBackup ;
         TO cArchiveName ;
         BLOCK {|cFile,nPos|  BackUp.ProgressIndicator.Value := nPos }  ;
         OVERWRITE
      lBackupStatus  := .t.
      msgbox("Backup created successful!")
They should be:
   AEVAL( aTemp, { | a1 | AADD( aFilesToBackup, BackUp.T_SourceFolder.Value + "\"+ a1[ 1 ] ) } )
         TO cArchiveName ;
         OVERWRITE
Another way is to change current dir to folder being compressed.
The problem is, that version does not compress subdirectories of selected location :(
Hi all
Please forgive me for disturbing :(
Found source of error: it's my fault :(
Our COMPRESS command doesn't have any problem :)
Again, sorry for false report :(
Best regards
No problem Esgici. :)
Didn't you try to build archiving with subdirectories?
Marek
Hi Mol
mol wrote:Didn't you try to build archiving with subdirectories?
Marek
I am working on it (with others).
I gues it's possible, but require a little extra effort; such as recursion.
And I guess also, if <aFiles> include path info together file names, COMPRESS store its in the result (.zip) file.
But sadly, Windows doesn't show content of such (including path infos) archive files :(
If I will reach a acceptable result, I will inform you.
Regards.
Hola muchachos:
perdon por hacer esta pregunta tonta.
modificando Zipdemo de HMG3.0.40
C:\hmg.3.0.40\SAMPLES\ZIP
los pasos se hacen correctamente, pero al abrir el archivo compactado me encuentro que esta vacio..
utilizando el depurador veo que toma el contenido de la carpeta en cuestion.
uso este ejemplo ya que tengo algo parecido para el respaldo de mi aplicacion y me hace lo mismo.
donde fallo ????
/****************** Translate Google *************************/
Hi guys:
sorry for asking this silly question.
modifying Zipdemo of HMG3.0.40
steps are done correctly, but when you open the zip file is empty I find that ..
using the debugger I see that takes the contents of the folder in question.
use this example because I have something similar to the support of my application and I do the same.
where failure ?????
Function main()
	DEFINE WINDOW form_1 ;
		AT 114,218 ;
		WIDTH 334 ;
		HEIGHT 276 ;
		TITLE 'ZIP TEST' ;
		MAIN
		DEFINE MAIN MENU
			DEFINE POPUP "Test"
				MENUITEM 'Create Zip' ACTION CreateZip()
			END POPUP
		END MENU
		@ 80,120 PROGRESSBAR Progress_1 RANGE 0,10 SMOOTH
		@ 120,120 LABEL label_1 VALUE ''
	form_1.center
	form_1.activate
Return NIL
Function CreateZip()
local aDir:=Directory("Text\*.txt")
local afiles:={}
Local x
local nLen
	For x:=1 to len(aDir)
	    aadd(afiles,adir[x,1])
	next
	COMPRESS afiles ;
		TO 'c:\ZipTest.Zip' ;
		BLOCK {|cFile,nPos| ProgressUpdate( nPos , cFile ) }  ;
		OVERWRITE
Return nil
function ProgressUpdate(nPos , cFile )
	Form_1.Progress_1.Value := nPos
	Form_1.Label_1.Value := cFile
aadd(afiles,"text\"+adir[x,1]) // Line 40
paimar
Post by paimar »
First off all sorry for my horrible english.
If there is not a "clean" solution for making a backup of subdirectories I'm thinking in a very "dirty" solution :)
May be go throgh all directories and copy the files I need to one only directory. For the restore do the opposite.
Ahggg que alivio escribir en español :) Si no hay una solucion mas limpia para el tema de hacer backups de directorios con subdirectorios estoy pensando
en ir por los subdirectorios y copiar todos los archivos a un unico directorio y luego comprimir este. Para el restore se haria a la inversa copiando segun el tipo
de archivo a su directorio Dbf's a directorio dbf jpg's a directorio jpg etc.
Seria posible no?
un saludo
Gipuzkoa - ESPAÑA
IMATECH
Post by IMATECH »
I think it's not a "clean" solution: But Works Well :)
  LOCAL sCMD := 'WINRAR.EXE a -v -r BK_' + DTOS( DATE() ) + ' *.DB? *.JPG'
  HB_RUN( sCMD )
IF you have time... then can use a Better solution using "HB_DirScan(...)"
See the sample at:
\Harbour\contrib\hbmzip\tests\myzip.prg
\Harbour\contrib\hbmzip\tests\myunzip.prg
PROCEDURE Main( ... )
   LOCAL hZip, aDir, aFile, aWild, ;
         cZipName, cPath, cFileName, cExt, cWild, cPassword, cComment,;
         tmp
   aWild := { ... }
   IF LEN(aWild) < 2
      ? "Usage: myzip <ZipName> [ --pass <password> ] [ --comment <comment> ] <FilePattern1> [ <FilePattern2> ... ]"
   HB_FNameSplit( aWild[ 1 ], @cPath, @cFileName, @cExt )
   IF EMPTY( cExt )
      cExt := ".zip"
   cZipName := HB_FNameMerge( cPath, cFileName, cExt )
   HB_ADEL( aWild, 1, .T. )
   FOR tmp := LEN( aWild ) - 1 TO 1 STEP -1
      IF LOWER( aWild[ tmp ] ) == "--pass"
         IF EMPTY( cPassword )
            cPassword := aWild[ tmp + 1 ]
         aWild[ tmp ] := ""
         aWild[ tmp + 1 ] := ""
      ELSEIF LOWER( aWild[ tmp ] ) == "--comment"
         IF EMPTY( cComment )
            cComment := aWild[ tmp + 1 ]
         aWild[ tmp ] := ""
   hZip := HB_ZIPOPEN( cZipName )
   IF ! EMPTY( hZip )
      ? "Archive file:", cZipName
      FOR EACH cWild IN aWild
         IF !EMPTY( cWild )
            HB_FNameSplit( cWild, @cPath, @cFileName, @cExt )
            aDir := HB_DirScan( cPath, cFileName + cExt )
            FOR EACH aFile IN aDir
               IF ! cPath + aFile[ 1 ] == cZipName
                  ? "Adding", cPath + aFile[ 1 ]
                  HB_ZipStoreFile( hZip, cPath + aFile[ 1 ], cPath + aFile[ 1 ], cPassword )
      HB_ZIPCLOSE( hZip, cComment )
M., Ronaldo
By: IMATECH
Imation Tecnologia
AidTIC
Post by AidTIC »
perdon, a ver si me podeis ayudar.
He retocado el programa que viene con HMG.3.0.46 de Zip. Para que me comprima 2 DBF que tengo en un subdirectorio.
Y me crea el .zip perfectamente. pero no consigo que termine el programa. se queda asi:
El boton de Aceptar siempre esta activo.
Donde esta fallando?
Function main()
AT 114,218 ;
WIDTH 334 ;
HEIGHT 276 ;
TITLE 'ZIP TEST' ;
MAIN
DEFINE MAIN MENU
DEFINE POPUP "Test"
END POPUP
END MENU
DEFINE BUTTON Boton_Ac
ROW 170
COL 100
WIDTH 150
HEIGHT 48
CAPTION ' Aceptar '
FONTNAME "Arial"
FONTSIZE 18
FONTBOLD .T.
ONCLICK form_1.Release // Iif (MsgOkCancel ("Desea Enviar Los Ficheros?", "Envio de Ficheros") , MainCreateZip() , Win_ENLA.Release)
HELPID "Aceptar"
VISIBLE .T.
END BUTTON
form_1.center
form_1.activate
form_1.Boton_Ac.Enabled := .f.
Return NIL
local aDir:=Directory("Enlace\*.DBF")
local afiles:={}
Local x
local nLen
aadd(afiles,"Enlace\"+adir[x,1])
next
COMPRESS afiles ;
TO 'ZipTest.Zip' ;
OVERWRITE
form_1.Boton_Ac.Enabled := .T.
Return nil
Skydone Solutions
www.skydone.com
