REVISION OF GRID/BROWSE
Re: REVISION OF GRID/BROWSE
I want to know, why such a indempendent situation like divide by 0, totally not bound with grid, causes this behaviour...
esgici wrote:
mol wrote:Hi guys!
I want to refresh this topic and present modified sample 38 of grid. My friend was testing this sample with few version of HMG and got a lot of strange behaviours.
The display content of the grid becomes blank when you divide by 0 (call upper menu -> Divide -> Divide 3/0).
The display also stay blank when you lock LOCK.DBF file eg. by dbu before running this sample.
I'm attaching sample with .dbf files.
Regards, Marek
Hi Marek
IMHO you need your own error recovery system in order to distinguish error situations from GRID's one.
Please look at attached demo ( slightly modified version of your test demo.prg);
I hope it will give you an idea :idea:
Viva HMG :D
demoBE.zip
Thanks Esgici, but, I know about errorblocks and I'm using it in my app for eg. reporting errors via e-mail.
mol wrote:...
It was a little and simple remedy as a temporary solution until the physician arrive ;)
You know : Pull yourself up by your bootstraps always is a good way.
mlnr
Post by mlnr »
esgici wrote: Fri Dec 11, 2015 4:16 pm
mol wrote:...
Can I see that the physician has not arrived yet? ;)
I also encountered this problem. I'll use errorblocks, if there is no other solution...I'll take the painkiller :cry:
Gabor.
Try to use this patch:
hmg.3.4.4-patch.7z
(2.84 KiB) Downloaded 528 times
Follow the instructions: http://www.hmgforum.com/viewtopic.php?p=50218#p50218
mlnr
Post by mlnr »
Edward,
As I see it, just had to remove this line from ErrorSys.prg
_HMG_SYSDATA [ 347 ] := .F. // Grid Automatic Update
Thanks it's working fine. You are great. :)
franco
Post by franco »
Does anyone know how to add a label showing current computer memory, or some other method of watching memory as program runs.
I am not sure if I have a memory problem. I use temporary indexes and all files close when I leave the grid, or any othe screen. If the file is open somewhere else it does not close. I keep a counter on when the file is opened and closed. This was a lot of extra work but I always have done this.
I would like to watch memory this will tell what is happening.
All The Best,
Franco
Canada
Try to use Timer and memory(). Parameters of memory(): https://github.com/harbour/core/blob/ma ... bmemory.ch
Also you can look at https://harbour.github.io/doc/harbour.h ... collectall
See in HMG doc: Advanced -> Memory, Processes and Threads
