HFCL (Hmg Forum Component Library)
Source code related resources
Re: HFCL (Hmg Forum Component Library)
Yes, I am just working on it.
As you had told, documentation is the hell of the job. :)
I submit a small doc for gridprint. Tell me about your comments. If it is ok, I shall proceed to update HFCL.
gridprint.zip
(2.13 KiB) Downloaded 361 times
Hi Rathi
Perfect for me :)
Thanks a lot
rathinagiri wrote:I submit a small doc for gridprint. Tell me about your comments. If it is ok, I shall proceed to update HFCL.
gridprint.zip
Good!
I had uploaded HFCL latest version.
Change Log:
- Added autofill
- Added Documentation
Kindly try and give your comments. I think it is right time to publish the first version of HFCL in public. :)
hfcl.zip
HFCL Latest version
(31.62 KiB) Downloaded 388 times
Thanks a lot Rathi
Thanks to all who are involved in this project. :) I tested it.
You have done an excellent job :D
Regarding Grid2Print, I don't know how to print totals of specific columns.
And, there is a wish list. Can user store the structure of reports in a separate file for future use?
Thank you again.
rathinagiri wrote:Kindly try and give your comments. I think it is right time to publish the first version of HFCL in public. :)
Yes! :)
Hi Rathi
Only a little proposal : adding a folder Source for files in the root currently.
Ok Esgici. I will do that.
