There isn't any problem in my sideRoberto Lopez wrote:Es una idea interesante.jrendon wrote: ... integrar el DBA al IDE ...
Saludos,
Saludos,
esgici wrote:There isn't any problem in my sideRoberto Lopez wrote:Es una idea interesante.jrendon wrote: ... integrar el DBA al IDE ...
Saludos,
Roberto.![]()
Muchos Gracias jrendonjrendon wrote:
Bueno. Muuuuuy Bueno
y asi ya tenemos el complemento completo y dejamos el Prometheus 2000
Españolesgici wrote:jrendon wrote:
Prometheus is a very mature and professional project.
I don't have further knowledge about it because of I don't know its languagejrendon wrote: Prometheus is very complete but ...
Thanks again; this is power of HMG and Harbour...and I believe that with the DBA could be doing more things for example to open bases in ODBC, Mysql, etc. mSQL with RDD or connectors such as Leto DB or SQLRDD of xHarbour or AdoRdd Harbour
Si Prometheus esta muy completo pero se quedo estancado, y creo que con el DBA se podrian hacer mas cosaspor ejemplo abrir bases en ODBC, Mysql, MSql etc con los RDD o Conectores como por ejemplo Leto DB o SQLRDD de xHarbour o AdoRdd de Harbour.
Upsfchirico wrote: Juan, mira este producto:
http://sourceforge.net/projects/ourxdbu/
Saludos, Fernando Chirico.
Hola JanJan Ribeiro wrote:É um trabalho excelente !!!!!
Usei e verifiquei a necessidade de um pequeno ajuste.
O arquivo quando modificado criando um campo Memo é criado um .Dbt com um número e não com o nome do .Dbf modificado.
Saludos, Jan
English ( from Portuguese by Google )
It is a great job !!!!!
I used and saw the need for a small adjustment.
The modified file when creating a Memo field is created. DBT with a number and not with the name. Dbf modified.
Hola JanJan Ribeiro wrote: ...
