HMGSCRIPT R42
Re: HMGSCRIPT R42
I'm afraid I can't help (change database to mysql because of series of disasters with XML files, I understand!)
jairpinho
Re: HMGSCRIPT R42
Post by jairpinho »
hello guys need something else in the browser to generate the pdfs? is not generating the pdf I should have installed some extension in the browser, I found out what is the file myapp.cgi makes the connection of the user but I am trying to login and does not accept
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
jairpinho
Re: HMGSCRIPT R42
Post by jairpinho »
Hi guys need an example with mysql connection with grid, do we have this possibility?
Jair Pinho
Re: HMGSCRIPT R42
Yes, it is possible:
Just try something like this:
SET HMGWEB=c:\hmgweb\jairsources
SET HBPATH=C:\hmgweb\harbour\bin
SET HMGINCPATH=c:\hmgweb\include
SET APACHECGIPATH=C:\hmgweb\apache\cgi-bin
%HBPATH%\hbmk2 %HMGWEB%\your_source -i%HMGINCPATH% -shared hbhpdf.hbc hbmysql.hbc hbct.hbc hbmisc.hbc
IF ERRORLEVEL 0 MOVE your_source.exe   %APACHECGIPATH%\your_source.cgi
To compile your source.
jairpinho
Re: HMGSCRIPT R42
Post by jairpinho »
serge_girard wrote: Wed Feb 06, 2019 8:26 am Yes, it is possible:
I need connection via hmgscript I will not use cgi files I chose hmgscript has this example here but I do not use php and yes mariadb
// MySQLBROWSE DEMO
function MySQLBrowse( oParent , nRow , nCol , nWidth , nHeight , cHost, cUser, cPassword, nPort, cDB, cQuery, nInnerWidth )
	var cId = 'control' + (nControlCount).toString() ; nControlCount++ ;
	var query = 'cHost=' + cHost + '&'
               + 'cUser=' + cUser + '&'
               + 'cPassword=' + cPassword + '&'
               + 'nPort=' + nPort + '&'
               + 'cDB=' + cDB + '&'
               + 'cQuery=' + cQuery + '&'
               + 'cId=' + cId + '&'
               + 'nInnerWidth=' + nInnerWidth + '&';
	var control = document.createElement( "div" )        ;
	var panel = cId + '_panel';
	control.className      = "browse"                    ;
	control.style.position = "absolute"                  ;
	control.style.top      = nRow                        ;
	control.style.left     = nCol                        ;
	control.style.width    = nWidth                      ;
	control.style.height   = nHeight                     ;
	control.id             = panel                       ;
	control.innerHTML      = "Loading..."                ;
	control.style.border   = "solid 1px rgb(200,200,200)"    ;
	control.style.overflow = "scroll"                    ;
	document.getElementById( oParent.getId() ).appendChild( control )                ;
	xmlHttp=new XMLHttpRequest();
	xmlHttp.open( "POST" , "/php/mysql.php"  , false ) ;
	xmlHttp.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded');
	xmlHttp.send( query );
	document.getElementById(panel).innerHTML = xmlHttp.responseText;
	this.getPageSize = function()
		return nPageSize ;
	this.getSelectedRowCount = function()
		var i, n ;
		n = 0 ;
		for ( i=1 ; i < document.getElementById(cId).rows.length ; i++ )
			if ( document.getElementById(cId).rows[i].cells[0].getElementsByTagName("input")[0].checked == true )
				n++ ;
		return n;
	this.getSelectedRows = function()
		var selectedRows=new Array();
		var i, code, first, last, n ;
		n = 0 ;
				selectedRows[n] = i ;
				n++ ;
		return selectedRows;
	this.getRowCount = function()
		return document.getElementById(cId).rows.length;
	this.getCell = function( nRow , nCOl )
		return trim(document.getElementById(cId).rows[nRow].cells[nCOl].childNodes[0].data);
	this.select = function( nRow )
		document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0].checked = true ;
		changeState( document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0] );
	this.unSelect = function( nRow )
		document.getElementById(cId).rows[nRow].cells[0].getElementsByTagName("input")[0].checked = false ;
	this.refresh = function(  )
	this.getId = function ()
		return cId;
function test_0()
   oWin = new Form( "MySQLBrowse Test", 590 , 480 );
   Button( oWin , 390 , 40  , "Refresh"         , "oBrowse.refresh()"      );
   Button( oWin , 390 , 170 , "Show Selected"   , "ShowSelected(oBrowse)"  );
   Button( oWin , 390 , 300 , "Append"          , "AppendTest( oBrowse )"  );
   Button( oWin , 430 , 40  , "Delete Selected" , "DeleteTest(oBrowse)"    );
   Button( oWin , 430 , 170 , "Select All"      , "SelectAll( oBrowse )"   );
   Button( oWin , 430 , 300 , "UnSelect All"    , "UnSelectAll( oBrowse )" );
   Button( oWin , 430 , 430 , "Close"           , "oWin.release()"         );
	oBrowse = new MySQLBrowse( oWin ,
	050 , 050 , 510 , 340 , 'localhost', 'root', '401375', '3306', 'techworks', 'select * from clientes', 250 );
function ShowSelected( oBrowse )
	if ( oBrowse.getSelectedRowCount() == 0 )
		alert('No Rows Selected!');
		return;
	var aSelection = oBrowse.getSelectedRows();
	for ( var i = 0 ; i < aSelection.length ; i++ )
		nRow = aSelection [i] ;
		code  = oBrowse.getCell( nRow , 1 );
		first = oBrowse.getCell( nRow , 2 );
		last  = oBrowse.getCell( nRow , 3 );
		alert ( code + ' ' + first + last );
Jair Pinho
jairpinho
Re: HMGSCRIPT R42
Post by jairpinho »
jairpinho wrote: Thu Feb 07, 2019 9:17 pm
// MySQLBROWSE DEMO
		return nPageSize ;
		var i, n ;
		n = 0 ;
				n++ ;
		return n;
		n = 0 ;
				n++ ;
		return cId;
function test_0()
		return;
Hello everyone, could someone help me in an example of connection via .js from hmgscript I am developing system but I still could not connect to the bank in the forum example need arqruivo mysql.php I use mariadb how should I do?
xmlHttp = new XMLHttpRequest ();
xmlHttp.open ("POST", "/php/mysql.php", false);
xmlHttp.setRequestHeader ('Content-Type', 'application / x-www-form-urlencoded');
xmlHttp.send (query);
document.getElementById (panel) .innerHTML = xmlHttp.responseText;
Jair Pinho
Re: HMGSCRIPT R42
Jair,
Can you send complete sources?
jairpinho
Re: HMGSCRIPT R42
Post by jairpinho »
serge_girard wrote: Mon Feb 18, 2019 10:20 am Jair,
added mysql button and example, add the folder harbour, I retired to get smaller file size
app42b.zip
(13.83 KiB) Downloaded 701 times
Jair Pinho
Re: HMGSCRIPT R42
Jair,
File is probably damaged!
jairpinho
Re: HMGSCRIPT R42
Post by jairpinho »
serge_girard wrote: Mon Feb 18, 2019 5:57 pm Jair,
app42b.zip
(13.83 KiB) Downloaded 725 times
Jair Pinho
