HMG 3.3.1 (Stable)
Re: HMG 3.3.1 (Stable)
Pablo César wrote:It seems problem at Win XP.
Another strange thing is when you put "&" as part of prefix in the string, because works perfectly otherwise NOAUTOSIZE works properlly. :(
srvet_claudio wrote:
Pablo César wrote:.. displaying a "४" in place of line feed (LF) and carriage return (CR)
1) IDE... Written on my todo list
Thanks, Claudio.
I will try fix in Win XP.
Win-8 Screen
HMG 3.3.1 (Stable)
Thank you Dave for your test in win8.
srvet_claudio wrote:I will try fix in Win XP.
Tks, Claudio.
This sizing can be setted manually by the programmer.
IMHO this is not urgent.
Exploring innovations in 3.3.1 -- 2
( The first (Global Memory Status Extended Sample) is here )
Process information by new process functions.
Process info screen shoot
ProcInfo.zip
Process info source ( .prg ) file
(787 Bytes) Downloaded 325 times
Thanks to Dr. Soto :D
esgici wrote:Exploring innovations in 3.3.1 -- 2
ProcInfo.zip
Thank you Esgici
The attachment ProcInfo.PNG is no longer available
The attachment ProcInfo.zip is no longer available
Another example.
I attach the .EXE file because DynamicFont property of GRID/TREE Controls will be implemented in the next release.
PS: Attention: to detect processes 32 and 64 bits you should compiling with HMG-64 bits (Build64.bat)
EnumProcesses.rar
(1.05 MiB) Downloaded 328 times
Hola Dr. Soto!
Mi PC es de 32 bits, y me ocasiona este error al querrer abrir el *.EXE
Error x64.jpg (58.23 KiB) Viewed 5810 times
srvet_claudio wrote: PS: Attention: to detect processes 32 and 64 bits you should compiling with HMG-64 bits (Build64.bat)
Javier para detectar procesos de 32 y 64 es necesario compilar con 64bits.... el exe incluido es 64bits y no corre en plataformas de 32.
Hola DanielMaximiliano,
OK, gracias, pensé que estaba a 32 bit el demo.
srvet_claudio wrote: ...
Another example.
Thanks Dr., good enhancement :arrow:
By adding TerminateProcess(), the sample has been a good Task Manager :arrow:
By the way, the SET WINDOW MAIN OFF/ON is what I'm looking for; separate thanks to this :D
