Resource file to accept Animated Cursor
Re: Resource file to acept Animated Cursor
Pablo César wrote: Pena que Claudio, no disponibilizó algun ejemplo en HMG utilizando esa misma funcion _bt_LoadFileFromResources.
HGLOBAL __bt_LoadFileFromResources (TCHAR * FileName, TCHAR * TypeResource);
//       _LoadAnimatedCursor (FileName, TypeResource) --> Return hCursor
HB_FUNC (_LOADANIMATEDCURSOR)
    TCHAR   *FileName     = (TCHAR *) HMG_parc (1);
    TCHAR   *TypeResource = (TCHAR *) HMG_parc (2);
    HCURSOR hCursor = NULL;
    HGLOBAL hGlobal = __bt_LoadFileFromResources (FileName, TypeResource);
    if (hGlobal)
    {   DWORD  nFileSize = GlobalSize (hGlobal);
        LPBYTE lpGlobalAlloc = (LPBYTE) GlobalLock (hGlobal);
        if (lpGlobalAlloc)
        {   hCursor = (HCURSOR) CreateIconFromResource  ((PBYTE)lpGlobalAlloc, nFileSize, FALSE, 0x00030000);
            if (hCursor == NULL && GetLastError() == ERROR_SUCCESS)
                MessageBox (NULL,_TEXT("hCursor == NULL bud The operation completed successfully ???"),_TEXT("Error"),0);
            GlobalUnlock (hGlobal);
        GlobalFree (hGlobal);
       hCursor = LoadCursorFromFile (FileName);
    hb_retnl ((LONG) hCursor);
Fantastic
Thank you, Dr. Claudio
srvet_claudio wrote:This the theory of load animated cursor from resource, but not work!!!
It's very rare error because CreateIconFromResource() return a NULL handle but GetLastError() return 0 (The operation completed successfully).
Sorry Claudio for my delayed response (I didn't see your message).
All this problem is not at loadable animated cursor whatever the code, the problem I think is on the windres.exe responsable to create object file to be assembled with exefile.
I reported at GitHub this problem thinking about hbmk2 and look this answer:
vszakats at 21 days ago wrote:Please report this problem to mingw / windres developers, or alternatively switch
to a C compiler which supports this specific case (MSVC?).
[ Note that hbmk2 doesn't by itself process the majority of input files of various formats,
but calls the appropriate external tool, in this case from the C compiler toolchain. ]
    if (hGlobal)
        if (lpGlobalAlloc)
Fantastic
Hi Dave, do you have run this example ? Could you post the code ?
I got previous example, but in this case does work... but I believe there other reasons.
Hola Claudio,
Te agradezco cuando vos puedas ver este caso, que por lo que me parece le falta el retoque de un master...
En una reciente me funcionó aunque de forma limitada con el uso de 21 y ANICURSOR en el RC y lo hize através de la funcion SetWindowCursor(<ControlHandle>,<CursorName_or_IdAtRC>). Pena que lo hace para todos los componentes. Yo quisiera que solo altere el cursor de determinado control nomás, asi como lo hace la función InitHyperLinkCursor().
Comparé las dos funciones y noté que InitHyperLinkCursor tiene una SubClass.
HB_FUNC( INITHYPERLINKCURSOR )
    HWND hwnd;
    hwnd = (HWND) HMG_parnl (1);
    HyperLinklpfnOldWndProc = (WNDPROC) SetWindowLongPtr ( hwnd , GWLP_WNDPROC, (LONG_PTR) HyperLinkSubClassFunc);
HB_FUNC ( SETWINDOWCURSOR )
    HCURSOR ch;
    if( HB_ISCHAR(2) )
        ch = LoadCursor( GetModuleHandle( NULL ), HMG_parc( 2 ) ) ;
        if ( ch == NULL )
            ch = LoadCursorFromFile ( HMG_parc( 2 ) ) ;
        ch = LoadCursor( NULL, MAKEINTRESOURCE( hb_parni( 2 ) ) ) ;
    SetClassLongPtr ( (HWND) HMG_parnl(1),    // window handle
        GCLP_HCURSOR,                         // change cursor
        (LONG_PTR) ch );                      // new cursor
Podrias indicarme como hacer correcto ?
Aqui dejo mi código para testear, si lo deseas:
AnimatedCursor.rar
Executable and source files
(1.24 MiB) Downloaded 331 times
Googled
Hello Claudio
For when you can see this case, that for what seems to me missing the retouching of a master ...
In a recent it worked me albeit limited with the use of 21 and ANICURSOR in the RC and I made it through the function SetWindowCursor (<ControlHandle>, <CursorName_or_IdAtRC>). The bad thing it does for all controls and I would like it to only alter the cursor of a certain control just like the InitHyperLinkCursor() function.
I compared the two functions and noticed that InitHyperLinkCursor has a SubClass.
<Source code listed above>
Could you tell me how to do it right?
Re: Resource file to accept Animated Cursor
Ok Pablo, lo voy a mirar
