EditBox control: increase capacity
Re: EditBox control: increase capacity
Post by EduardoLuis »
Hi Esguici:
I've test your propousal, and the results was the same.-
memo field limit in table must be under than 29958
Table format dbf / ftp
Tests were maid under:
OS version Win 7 32 & 64 bit
OS version Win XP SP3 32 bit and Win XP 64 bit
OS version Win 8 32 bit
With regards. Eduardo
Hi Esgici:
Me again.-
Making new tests, i discover that the problem with *.TXT files (from EditBox) becomes on MEMOWRIT command.- If you try to write EditBox contents (200000 bytes for example) memowrit() only save 64kb.- I notice that using your example EDIT_TXT_PDF posted on the forum.-
Although i'll try to solve it.-
EduardoLuis wrote:... memowrit() only save 64kb...
Did you tried HB_MemoWrit() ?
Hello Eduardo
EduardoLuis wrote: ...I've test your propousal, and the results was the same...
Try this once ...
Memo fields and text file limits test result
MmoLmTst.zip
Memo fields and text file limits test source files ( .hbp, .prg )
(1.44 KiB) Downloaded 977 times
Viva HMG :D
Hi Eduardo
Tried separately; no size difference found between MemoWrit() and HB_MemoWrit();
only difference is MemoWrit() added EOF marker ( CHR( 26 ) ) at end of output file.
Hi Esguici:
I'm sorry not to answer you yesterday, but as is don't work yesterday and have no internet at home, since now i saw you post.-
I'll test you sample today.-
Thanks very much for your suggestions.-
Hi Esgici
Your demo wokrs OK.-
The only problem i can't solve (like i like) is dbf memo field capacity.-
On my project developed an nearly 260000 characters must stored it on memo field of a principal table, independant from a txt file where the take the portion of text to copy & paste.-
To solve that problem text captured from *.txt file is stored on various memo fields of the table, in portions of 29000 characters.- I know this is not the proper solution, but is the one i found functions OK.- When end user needs to recover that information, EDITBOX loads each one of the memo fields contents; if end user make any changes on the EDITBOX, the sistem split EDITBOX contents on portions of 29000 char and stored again on various memo fields.-
Another chance i'm testing is storing on a character file the name and root of the original *.txt file, so when end user want to check that information, the sistem loads that specify *.txt file.-
As you told me, i create a *.dbf / *.fpt table; but the result was the same as on *.dbf /*.dbt table.-
I'll continuing looking for a better solution.-
Again thanks very much for your cooperation.-
Hi Esgici:
I've rewrite some of your lines to implement on my project and:
IT WORKS FINE.- SUPERB!!!!!!!!!!!!
Thanks again for your share your knowledge with all of us.-
Again very much thanks.
Hi Eduardo
I'm glad I can be helpful to you :)
Please look at also here.
I hope FIF will give to you an idea :idea:
Note that FIF support any type / size of file, not only .txt files ;)
Viva HMG :D
Hi Esgici:
I've made new test - modifying your sample - and again limits appear.-
I attach your sample with the additions i've made to match what i need to do on my developement.-
I include a *.txt file with the lenght i may need 215.166 bytes.-
If you edit SAMPLE.txt and latter save as SHOM.TXT it's cut up to 64999 bytes.-
If you edit SAMPLE.TXT and try to save new MEMO filed, it's also cut up to 64999 bytes.-
Perhaps i've made some mistake on the new code, so forgiveme if i'm wrong.-
I've compiled the sample under HMG 3.046 and 3.14 and the result was the same in both cases.-
I've teste both HMG samples on Win 7 and Win XP SP3, and the result was the same.
I ask you if you could check my code and tell me where i make the mistake.-
MMEMO.zip
(2.75 KiB) Downloaded 308 times
