HMG 3.1.4
Re: HMG 3.1.4 (Test)
I meant to replace in the programming and not in HMG itself. It would be a better indication (like always on 'ToolTip' for the user). Tooltip can't be done away with because cuebanner works only for TextBox control.
I don't have XP. Can somebody check and report?
HiRathinagiri wrote:I meant to replace in the programming and not in HMG itself. It would be a better indication (like always on 'ToolTip' for the user). Tooltip can't be done away with because cuebanner works only for TextBox control.
I don´t have at this moment the last HMG release, but I´ve using this code in XP and works fine, on textbox, combobox (edit part) and spinner. Don´t works on editbox, richeditbox. You can compare the HMG code with this one. It was not tested on Hmg, is an adaptation.
HB_FUNC( SETCUEBANNER ) // ( editHandle, cMsg ) -> nil
#ifdef IGH_UNICODE
LPWSTR lpWCStr = HMG_parc(2) ;
#else
LPWSTR lpWCStr = (LPCWSTR) ( hb_parc(2) == NULL ) ? NULL : hb_mbtowc( (const char *) hb_parc(2) ) ;
#endif
SendMessage( (HWND) hb_parnl(1), EM_SETCUEBANNER, (WPARAM) 0, (LPARAM) (LPCWSTR) lpWCStr ) ;
SysFreeString( lpWCStr );
HMG 3.1.4 (Test)
Hi Carlos, your example is not working with HMG in XP, in Win 7 yes but different than Rathi example. The differance (in win7) from your sample and Rathi is that in Rathi example cuebanner text only disapear when start typing and your example disapear initially with prompted.
Any way both example is not working in XP yet. I have seen many VB examples and same behaviour and in most of them talks some about of comctl32.dll version. I am not sure but probably our problem is from MINGW compiler.
Carlos, what do you mean about #ifdef IGH_UNICODE (here in red is it something wrong ?)
- srvet_claudio
Wow Carlos, very clean and nice code!!!Carlos Britos wrote:HiRathinagiri wrote:I meant to replace in the programming and not in HMG itself. It would be a better indication (like always on 'ToolTip' for the user). Tooltip can't be done away with because cuebanner works only for TextBox control.
HB_FUNC( SETCUEBANNER ) // ( editHandle, cMsg ) -> nil { #ifdef IGH_UNICODE LPWSTR lpWCStr = HMG_parc(2) ; #else LPWSTR lpWCStr = (LPCWSTR) ( hb_parc(2) == NULL ) ? NULL : hb_mbtowc( (const char *) hb_parc(2) ) ; #endif SendMessage( (HWND) hb_parnl(1), EM_SETCUEBANNER, (WPARAM) 0, (LPARAM) (LPCWSTR) lpWCStr ) ; SysFreeString( lpWCStr ); }
SETCUEBANNER of the HMG.3.1.4, works also in ANSI because this portion of the code is forced to compile always in Unicode. But the use of MultiByteToWideChar() function in ANSI version is more accurate.
Claudio.
- srvet_claudio
Pablo, change:Pablo César wrote:Carlos, what do you mean about #ifdef IGH_UNICODE (here in red is it something wrong ?)
#ifdef IGH_UNICODE
#ifdef UNICODE
HMG 3.1.4 (Test)
Thank you Dr.srvet_claudio wrote:Pablo, change:for:Code: Select all
#ifdef IGH_UNICODE
#ifdef UNICODE
But please Claudio clarify if is working in XP. Because for me is not working in XP.srvet_claudio wrote:SETCUEBANNER of the HMG.3.1.4, works
And how it could be implemented in your opinion Claudio in Carlos source code ?But the use of MultiByteToWideChar() function in ANSI version is more accurate.
Claudio :
Resolvi el problema del IDE, configure el IDE Ansi con Crimsom como editor y Español como lenguaje, copie los 3 .ini
, por algún problema el IDE no crea estos achivos en su formato de encoding ????
Windows 7 Home Premium 64 recien instalado y aplicado todos sus services pack , 4GB Ram.
- Language.ini
Hmg.ini
Editor.ini
- srvet_claudio
I not tried the Carlo's code, but the CueBanner of HMG.3.1.4 not work well in XP.Pablo César wrote:But please Claudio clarify if is working in XP. Because for me is not working in XP.srvet_claudio wrote:SETCUEBANNER of the HMG.3.1.4, works
Congratulation, Daniel. Probably was not in UTF8 for spanish.danielmaximiliano wrote:Claudio :
- Language.ini
Hmg.ini
Editor.ini
I never use (without "BOM") option, simply "UTF-8" only.danielmaximiliano wrote:UTF8 Without BOM
- srvet_claudio
Que extraño Daniel, verifique y a mi me crea el archivo Language.ini en UTF8.danielmaximiliano wrote:Claudio :
Resolvi el problema del IDE, configure el IDE Ansi con Crimsom como editor y Español como lenguaje, copie los 3 .inilos edite con Notepad++ y los conveti a UTF8 Without BOM, abri el IDE y se ejecuta sin ningun problema
- Language.ini
Hmg.ini
Editor.ini, por algún problema el IDE no crea estos achivos en su formato de encoding ????
Proba borrar el archivo Language.ini, cargar el IDE y cambiar el idioma a Español, tendría que crear automáticamente el archivo Language.ini en UTF8.
