MySQL and HMG
Re: MySQL and HMG
I had got your code and found it very much useful Sudip. Thanks a lot for sharing the same. Gr8.
Re: MySQL and HMG
rathinagiri wrote:I had got your code and found it very much useful Sudip. Thanks a lot for sharing the same. Gr8.
You know how happy I am, to know that from you :D
Especially, if the code is written after a very busy day. :D
Today is Sunday, but I have to create some entry modules and reports (created with another software tool :( ) to give the software tomorrow morning.
I shall wait for your finished dbf2mysql.
Thank you very much.
Re: MySQL and HMG
Hello Rathi,
I found some problem regarding date value. I changed your C2Sql functon.
function C2SQL(Value)
   local cValue := ""
   local cFormatoDaData := set(4)
   do case
   case Valtype(Value) == "N"
      cValue := AllTrim(Str(Value))
   case Valtype(Value) == "D"
   	if !empty(Value)
   		cValue := "'"+DTOS(value)+"'"
   		cValue := "'00000000'"
   case Valtype(Value) $ "CM"
      IF Empty( Value)
         cValue="''"
         cValue := "'"
         Value:=DATATOSQL(value)
         cValue+= value+ "'"
   case Valtype(Value) == "L"
      cValue := AllTrim(Str(iif(Value == .F., 0, 1)))
   otherwise
      cValue := "''"                                // NOTE: Here we lose values we cannot convert
   endcase
   return cValue
Please check this and send your comments.
Regards.
Re: MySQL and HMG
Oh. Thanks.
Now, it is simple. Isn't it?
Re: MySQL and HMG
Hello,
How can I connect MySql database from the client computer connected through LAN?
TIA.
Regards.
Re: MySQL and HMG
1. The host name would be the name of the computer (not 'localhost') where MySQL server is installed.
2. Remember to add port number 3306 (default, change if changed) in the firewall table to allow it in both the machines.
That's all!
Re: MySQL and HMG
Thanks a lot! :)
Should I need to install MySql in client computer also?
Regards.
Re: MySQL and HMG
I think, you don't need to install mysql on client computer.
Hi Rathi!
I have a question - You are viewing mysql database with grid - all data is captured in a static table. But what about network working - where few users can work on the same database, all can add new records, delete or edit them? How do you refresh your view?
I always use Browse with *.dbf files - because browse is refreshing view automatically.
I have no experiences with mysql, but try to learn something new...
Re: MySQL and HMG
Yes. No need to install anything except the HMG application in the client computer.
Since MySQL is a back end server, always the user has to give request to get the result.
We have to manually refresh. If we want, we can do with a timer control to refresh frequently.
Re: MySQL and HMG
I think, this method overloads network and server. But, I think other applications (not HMG) are working with the same method.
