Just upgraded to 3.0.38, but have problem...
l3whmg
Re: Just upgraded to 3.0.38, but have problem...
Post by l3whmg »
Hi Rathinagiri,
about "hbvpdf" I found "Harbour\examples\hbvpdf". I think this can solve the problem: everyone can compile and get the new library.
On the other hand, I read about "Harbour\lib\win\mingw\libhbhpdf.a" (HaruPdf) that is considered a contrib library; I don't read a lot (f.e. differences) but if can be used....
Cheers
Luigi from Italy
www.L3W.it
Hello,
I found Report.Advanced.<n> samples also not working.
Regarding my old project, no extra library was used. I used only advanced report generator, which Roberto created last year.
Thanks.
l3whmg
Post by l3whmg »
Hi Sudip,
I think Rathinagiri suggest to you to have/get hbvpdf library; I think this is not a lib distribuited with Harbour: this is an example (now, I don't know in the past).
But, HMG lib use this library within report manager and for this reason you must have. I think you should consider it as a library hidden, but required.
I hope this can help you.
Cheers
Luigi from Italy
www.L3W.it
Hi Sudip:
demo.hbp suggests demo.prg looking at the same
# include "hmg.ch"
SET PROCEDURE TO hbvpdf.prg
SET PROCEDURE TO hbvpsup.prg
Looking in C:\hb31\examples\hbvpdf you found these files.
Hbvpdf.ch is also necessary
then compiles without any error.
assumes that the library is not required libhbvpdf.a in C:\HMG3.0.38\LIB and referred directly to.
SET PROCEDURE *****.PRG
demo.hbp apunta a demo.prg mirando el mismo, me encuento esto
Set procedure to hbvpdf.prg
Set procedure to hbvpsup.prg
buscando en C:\hb31\examples\hbvpdf enconte dichos archivos. tambien es necesario hbvpdf.ch
despues compila sin ningun error.
asume que no es necesaria la libreria libhbvpdf.a ya que hace referencia directa a los .PRG con SET PROCEDURE
Thanks a lot to all of you :D
I shall check your suggestions.
Samples\Report.Advanced.1 works after copying hbpdf... files
But, how can I create the lib file?
I am out of touch with HMG for some months, and I need your help / tips ;)
Thanks.
After 10 min.
I added these prg files in my old project. It works! :D
Thanks a lot. :D
Nice coming back Sudip.
l3whmg
Post by l3whmg »
Hi Sudip
the most simple it's to run "hbmk2 hbvpdf.hbp" within folder "harbour\examples\hbvpdf" (I don't try but theorically must work fine). Then you can copy the lib file or put a good pointer to this folder within your project.
Cheers
Luigi from Italy
www.L3W.it
gfilatov wrote:
rathinagiri wrote:...
where can we find these functionalities?
Hi Rathi,
There is a new class WIN_OLEAUTO instead of old TOleAuto() in the Harbour contrib HBWIN library.
You can uncomment also the function FreeLibrary() in the HMG source file c_winapimisc.c as below
HB_FUNC( FREELIBRARY )
   FreeLibrary( (HMODULE) hb_parnl( 1 ) ) ;
Hope that helps :idea:
Hi Grigory,
I tried to compile with 3.1 and had the following problems:
1. Will "WIN_OLEAUTO" just replace TOleAuto()?
2. I got errors of not finding the libraries for functions isnil, ischar, isarray
Any ideas?
rathinagiri wrote: Hi Grigory,
Any ideas?
Hi Rathi,
I've prepared a working class TOleAuto (based upon WIN_OLEAUTO) below.
Please take a look for source of file hbole.prg :
 * Harbour Project source code:
 * Compatibility calls.
 * Copyright 2009 Viktor Szakats (harbour.01 syenar.hu)
 * www - http://harbour-project.org
#define HB_CLS_NOTOBJECT  /* avoid definition of method: INIT */
#include "hbclass.ch"
#include "common.ch"
#include "error.ch"
#define EG_OLEEXCEPTION 1001
STATIC s_bBreak := { | oError | Break( oError ) }
STATIC PROCEDURE Throw( oError )
   LOCAL lError := Eval( ErrorBlock(), oError )
   IF ! ISLOGICAL( lError ) .OR. lError
      __ErrInHandler()
   Break( oError )
STATIC FUNCTION ThrowOpError( nSubCode, cOperator, ... )
   LOCAL oError
   oError := ErrorNew()
   oError:Args          := { ... }
   oError:CanDefault    := .F.
   oError:CanRetry      := .F.
   oError:CanSubstitute := .T.
   oError:Description   := "argument error"
   oError:GenCode       := EG_ARG
   oError:Operation     := cOperator
   oError:Severity      := ES_ERROR
   oError:SubCode       := nSubCode
   oError:SubSystem     := "BASE"
   RETURN Throw( oError )
CREATE CLASS TOLEAUTO FROM WIN_OLEAUTO
   /* TODO: Implement compatibility to the required extent */
   VAR cClassName
   METHOD New( xOle, cClass )
   METHOD hObj( xOle )
   METHOD OleValuePlus( xArg )            OPERATOR "+"
   METHOD OleValueMinus( xArg )           OPERATOR "-"
   METHOD OleValueMultiply( xArg )        OPERATOR "*"
   METHOD OleValueDivide( xArg )          OPERATOR "/"
   METHOD OleValueModulus( xArg )         OPERATOR "%"
   METHOD OleValuePower( xArg )           OPERATOR "^"
   METHOD OleValueInc()                   OPERATOR "++"
   METHOD OleValueDec()                   OPERATOR "--"
   METHOD OleValueEqual( xArg )           OPERATOR "="
   METHOD OleValueExactEqual( xArg )      OPERATOR "=="
   METHOD OleValueNotEqual( xArg )        OPERATOR "!="
ENDCLASS
METHOD hObj( xOle ) CLASS TOLEAUTO
   IF PCount() > 0 .AND. xOle != NIL
      IF ISNUMBER( xOle )
         xOle := __OLEPDISP( xOle )
      IF hb_isPointer( xOle )
         ::__hObj := xOle
   RETURN ::__hObj
METHOD New( xOle, cClass ) CLASS TOLEAUTO
   LOCAL hOle
   LOCAL oError
   IF ISNUMBER( xOle )
      ::__hObj := xOle
      IF ISCHARACTER( cClass )
         ::cClassName := cClass
         ::cClassName := hb_ntos( win_P2N( xOle ) )
   ELSEIF ISCHARACTER( xOle )
      hOle := __OleCreateObject( xOle )
      IF ! Empty( hOle )
         ::__hObj := hOle
         ::cClassName := xOle
         oError:Args          := hb_AParams()
         oError:Description   := win_OleErrorText()
         oError:GenCode       := EG_OLEEXCEPTION
         oError:Operation     := ProcName()
         oError:SubCode       := -1
         oError:SubSystem     := "TOleAuto"
   RETURN Self
FUNCTION CreateObject( xOle, cClass )
   RETURN TOleAuto():New( xOle, cClass )
FUNCTION GetActiveObject( xOle, cClass )
   LOCAL o := TOleAuto():New()
   LOCAL hOle
   LOCAL oError
   IF ISNUMBER( xOle )
      o:__hObj := xOle
         o:cClassName := cClass
         o:cClassName := hb_ntos( win_P2N( xOle ) )
      hOle := __OleGetActiveObject( xOle )
      IF ! Empty( hOle )
         o:__hObj := hOle
         o:cClassName := xOle
   RETURN o
METHOD OleValuePlus( xArg ) CLASS TOLEAUTO
   LOCAL xRet
   BEGIN SEQUENCE WITH s_bBreak
      xRet := ::OleValue + xArg
   RECOVER
      RETURN ThrowOpError( 1081, "+", Self, xArg )
   END SEQUENCE
   RETURN xRet
METHOD OleValueMinus( xArg ) CLASS TOLEAUTO
   LOCAL xRet
      xRet := ::OleValue - xArg
   RECOVER
      RETURN ThrowOpError( 1082, "-", Self, xArg )
   END SEQUENCE
   RETURN xRet
METHOD OleValueMultiply( xArg ) CLASS TOLEAUTO
   LOCAL xRet
      xRet := ::OleValue * xArg
   RECOVER
      RETURN ThrowOpError( 1083, "*", Self, xArg )
   END SEQUENCE
   RETURN xRet
METHOD OleValueDivide( xArg ) CLASS TOLEAUTO
   LOCAL xRet
      xRet := ::OleValue / xArg
   RECOVER
      RETURN ThrowOpError( 1084, "/", Self, xArg )
   END SEQUENCE
   RETURN xRet
METHOD OleValueModulus( xArg ) CLASS TOLEAUTO
   LOCAL xRet
      xRet := ::OleValue % xArg
   RECOVER
      RETURN ThrowOpError( 1085, "%", Self, xArg )
   END SEQUENCE
   RETURN xRet
METHOD OleValuePower( xArg ) CLASS TOLEAUTO
   LOCAL xRet
      xRet := ::OleValue ^ xArg
   RECOVER
      RETURN ThrowOpError( 1088, "^", Self, xArg )
   END SEQUENCE
   RETURN xRet
METHOD OleValueInc() CLASS TOLEAUTO
      ++::OleValue
   RECOVER
      RETURN ThrowOpError( 1086, "++", Self )
   END SEQUENCE
   RETURN Self
METHOD OleValueDec() CLASS TOLEAUTO
      --::OleValue
   RECOVER
      RETURN ThrowOpError( 1087, "--", Self )
   END SEQUENCE
   RETURN Self
METHOD OleValueEqual( xArg ) CLASS TOLEAUTO
   LOCAL xRet
      xRet := ( ::OleValue = xArg ) /* NOTE: Intentionally using '=' operator. */
   RECOVER
      RETURN ThrowOpError( 1089, "=", Self, xArg )
   END SEQUENCE
   RETURN xRet
METHOD OleValueExactEqual( xArg ) CLASS TOLEAUTO
   LOCAL xRet
      xRet := ( ::OleValue == xArg )
   RECOVER
      RETURN ThrowOpError( 1090, "==", Self, xArg )
   END SEQUENCE
   RETURN xRet
METHOD OleValueNotEqual( xArg ) CLASS TOLEAUTO
   LOCAL xRet
      xRet := ( ::OleValue != xArg )
   RECOVER
      RETURN ThrowOpError( 1091, "!=", Self, xArg )
   END SEQUENCE
   RETURN xRet
#pragma BEGINDUMP
#include "hbapi.h"
#include "hbwinole.h"
HB_FUNC( OLE2TXTERROR )
   HRESULT  lOleError;
   if( HB_ISNUM( 1 ) )
      lOleError = hb_parnl( 1 );
      lOleError = hb_oleGetError();
   switch( lOleError )
      case S_OK:                    hb_retc_const( "S_OK" );                     break;
      case CO_E_CLASSSTRING:        hb_retc_const( "CO_E_CLASSSTRING" );         break;
      case OLE_E_WRONGCOMPOBJ:      hb_retc_const( "OLE_E_WRONGCOMPOBJ" );       break;
      case REGDB_E_CLASSNOTREG:     hb_retc_const( "REGDB_E_CLASSNOTREG" );      break;
      case REGDB_E_WRITEREGDB:      hb_retc_const( "REGDB_E_WRITEREGDB" );       break;
      case E_OUTOFMEMORY:           hb_retc_const( "E_OUTOFMEMORY" );            break;
      case E_INVALIDARG:            hb_retc_const( "E_INVALIDARG" );             break;
      case E_UNEXPECTED:            hb_retc_const( "E_UNEXPECTED" );             break;
      case E_NOTIMPL:               hb_retc_const( "E_NOTIMPL" );                break;
      case DISP_E_UNKNOWNNAME:      hb_retc_const( "DISP_E_UNKNOWNNAME" );       break;
      case DISP_E_UNKNOWNLCID:      hb_retc_const( "DISP_E_UNKNOWNLCID" );       break;
      case DISP_E_BADPARAMCOUNT:    hb_retc_const( "DISP_E_BADPARAMCOUNT" );     break;
      case DISP_E_BADVARTYPE:       hb_retc_const( "DISP_E_BADVARTYPE" );        break;
      case DISP_E_EXCEPTION:        hb_retc_const( "DISP_E_EXCEPTION" );         break;
      case DISP_E_MEMBERNOTFOUND:   hb_retc_const( "DISP_E_MEMBERNOTFOUND" );    break;
      case DISP_E_NONAMEDARGS:      hb_retc_const( "DISP_E_NONAMEDARGS" );       break;
      case DISP_E_OVERFLOW:         hb_retc_const( "DISP_E_OVERFLOW" );          break;
      case DISP_E_PARAMNOTFOUND:    hb_retc_const( "DISP_E_PARAMNOTFOUND" );     break;
      case DISP_E_TYPEMISMATCH:     hb_retc_const( "DISP_E_TYPEMISMATCH" );      break;
      case DISP_E_UNKNOWNINTERFACE: hb_retc_const( "DISP_E_UNKNOWNINTERFACE" );  break;
      case DISP_E_PARAMNOTOPTIONAL: hb_retc_const( "DISP_E_PARAMNOTOPTIONAL" );  break;
      default:
         char   buf[ 16 ];
         hb_snprintf( buf, 16, "0x%08x", ( UINT ) ( HB_PTRUINT ) lOleError );
         hb_retc( buf );
HB_FUNC( __OLEPDISP )
   hb_oleInit();
   hb_oleItemPut( hb_param( -1, HB_IT_ANY ),
                  ( IDispatch * ) ( HB_PTRUINT ) hb_parnint( 1 ) );
#pragma ENDDUMP
and source of header file hbwinole.h :
 * $Id: hbwinole.h 16046 2011-01-14 07:35:19Z druzus $
 * OLE library C header
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2, or (at your option)
 * any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this software; see the file COPYING.  If not, write to
 * the Free Software Foundation, Inc., 59 Temple Place, Suite 330,
 * Boston, MA 02111-1307 USA (or visit the web site http://www.gnu.org/).
 * As a special exception, the Harbour Project gives permission for
 * additional uses of the text contained in its release of Harbour.
 * The exception is that, if you link the Harbour libraries with other
 * files to produce an executable, this does not by itself cause the
 * resulting executable to be covered by the GNU General Public License.
 * Your use of that executable is in no way restricted on account of
 * linking the Harbour library code into it.
 * This exception does not however invalidate any other reasons why
 * the executable file might be covered by the GNU General Public License.
 * This exception applies only to the code released by the Harbour
 * Project under the name Harbour.  If you copy code from other
 * Harbour Project or Free Software Foundation releases into a copy of
 * Harbour, as the General Public License permits, the exception does
 * not apply to the code that you add in this way.  To avoid misleading
 * anyone as to the status of such modified files, you must delete
 * this exception notice from them.
 * If you write modifications of your own for Harbour, it is your choice
 * whether to permit this exception to apply to your modifications.
 * If you do not wish that, delete this exception notice.
#ifndef __HBWINOLE_H
#define __HBWINOLE_H
#include "hbapi.h"
#include "hbapiitm.h"
#include "hbapicls.h"
#include "hbapierr.h"
#include "hbvm.h"
#include "hbstack.h"
#include "hbdate.h"
#if defined( HB_OS_WIN )
/* This option can resolve compilation problems in C++ mode for some
 * compilers like OpenWatcom but not for all, f.e. it will not help
 * BCC when used with -P (C++ mode) switch.
#if defined( __cplusplus ) && !defined( CINTERFACE )
   #define CINTERFACE 1
#endif
/* This code uses named union so this declaration is necessary for
 * compilers where nameless unions are default
#if defined( __BORLANDC__ ) || \
   ( defined( __WATCOMC__ ) && !defined( __cplusplus ) )
#     if !defined( NONAMELESSUNION )
#        define NONAMELESSUNION
#     endif
#endif
#include <windows.h>
#include <ole2.h>
#include <ocidl.h>
/* MinGW is lacking a number of variant accessors
#if defined( __MINGW32__ )
#  if !defined( V_I1REF )
#     define V_I1REF( x )     V_UNION( x, pcVal )
#  endif
#  if !defined( V_UI2REF )
#     define V_UI2REF( x )    V_UNION( x, puiVal )
#  endif
#  if !defined( V_INT )
#     define V_INT( x )       V_UNION( x, intVal )
#  endif
#  if !defined( V_INTREF )
#     define V_INTREF( x )    V_UNION( x, pintVal )
#  endif
#  if !defined( V_UINT )
#     define V_UINT( x )      V_UNION( x, uintVal )
#  endif
#  if !defined( V_UINTREF )
#     define V_UINTREF( x )   V_UNION( x, puintVal )
#  endif
#endif
#if defined( NONAMELESSUNION )
#  define HB_WIN_U1( x, y )   ( x )->n1.y
#  define HB_WIN_U2( x, y )   ( x )->n1.n2.y
#  define HB_WIN_U3( x, y )   ( x )->n1.n2.n3.y
#else
#  define HB_WIN_U1( x, y )   ( x )->y
#  define HB_WIN_U2( x, y )   ( x )->y
#  define HB_WIN_U3( x, y )   ( x )->y
#endif
/* macros used to hide type of interface: C or C++
#if defined( __cplusplus ) && !defined( CINTERFACE ) && \
   ( defined( __BORLANDC__ ) || \
     defined( __DMC__ ) || \
     defined( _MSC_VER ) || \
     defined( __MINGW32__ ) || \
     ( defined( __WATCOMC__ ) && ( __WATCOMC__ >= 1270 ) ) )
#  define HB_ID_REF( id )     ( id )
#  define HB_VTBL( pSelf )    ( pSelf )
#  define HB_THIS( pSelf )
#  define HB_THIS_( pSelf )
#else
#  define HB_OLE_C_API        1
#  define HB_ID_REF( id )     ( &id )
#  define HB_VTBL( pSelf )    ( pSelf )->lpVtbl
#  define HB_THIS( pSelf )    ( pSelf )
#  define HB_THIS_( pSelf )   ( pSelf ),
#endif
HB_EXTERN_BEGIN
typedef HB_BOOL ( * HB_OLEOBJ_FUNC )( VARIANT*, PHB_ITEM );
typedef void ( * HB_OLE_DESTRUCTOR_FUNC )( void * );
extern HB_EXPORT HB_BOOL    hb_oleInit( void );
extern HB_EXPORT HRESULT    hb_oleGetError( void );
extern HB_EXPORT void       hb_oleSetError( HRESULT lOleError );
extern HB_EXPORT void       hb_oleDispatchToItem( PHB_ITEM pItem, IDispatch* pdispVal, HB_USHORT uiClass );
extern HB_EXPORT IDispatch* hb_oleItemGetDispatch( PHB_ITEM pItem );
extern HB_EXPORT void       hb_oleVariantToItem( PHB_ITEM pItem, VARIANT * pVariant );
extern HB_EXPORT void       hb_oleVariantToItemEx( PHB_ITEM pItem, VARIANT* pVariant, HB_USHORT uiClass );
extern HB_EXPORT void       hb_oleItemToVariant( VARIANT * pVariant, PHB_ITEM pItem );
extern HB_EXPORT void       hb_oleItemToVariantEx( VARIANT* pVariant, PHB_ITEM pItem, HB_OLEOBJ_FUNC pObjFunc );
extern HB_EXPORT void       hb_oleVariantUpdate( VARIANT * pVariant, PHB_ITEM pItem, HB_OLEOBJ_FUNC pObjFunc );
extern HB_EXPORT IDispatch* hb_oleParam( int iParam );
extern HB_EXPORT IDispatch* hb_oleItemGet( PHB_ITEM pItem );
extern HB_EXPORT PHB_ITEM   hb_oleItemPut( PHB_ITEM pItem, IDispatch * pDisp );
extern HB_EXPORT PHB_ITEM   hb_oleItemGetCallBack( PHB_ITEM pItem );
extern HB_EXPORT void       hb_oleItemSetCallBack( PHB_ITEM pItem, PHB_ITEM * pCallBack );
extern HB_EXPORT HB_BOOL    hb_oleDispInvoke( PHB_SYMB pSym, PHB_ITEM pObject, PHB_ITEM pParam,
                                              DISPPARAMS * pParams, VARIANT* pVarResult,
                                              HB_OLEOBJ_FUNC pObjFunc, HB_USHORT uiClass );
extern HB_EXPORT void       hb_oleItemSetDestructor( PHB_ITEM pItem, HB_OLE_DESTRUCTOR_FUNC pFunc, void * cargo );
/* activex control */
extern HB_EXPORT HB_BOOL    hb_oleAxInit( void );
extern HB_EXPORT PHB_ITEM   hb_oleAxControlNew( PHB_ITEM pItem, HWND hWnd );
HB_EXTERN_END
#endif
#endif /* __HBWINOLE_H */
2. You should start the following replacing to make build old C-code with Harbour 3.1.0dev
- IS*() -> HB_IS*()
