All three themes, patched to be IE compatible, since cover transparency was not working on it.
Theoretically IE9 should be HTML/CSS fully compilant, but apparently it isn't (at least on my experience).
For those wondering why IE has historically having trouble with open standards, here is more information.
http://en.wikipedia.org/wiki/Embrace,_e ... extinguish
HMGSCRIPT 2012: Programming For The Web in The Right Way :)
- HMG Founder
Re: HMGSCRIPT 2012: Programming For The Web in The Right Way
- themes.zip
- (1.74 KiB) Downloaded 3142 times
Thanks for the info Roberto.
- HMG Founder
I guess that almost everybody knows about MS policies regarding standards, but I felt compelled to share this, since I'm really upset, because we could have set/get properties in the HMG style, but I can't add to the library, because IE is not standards compliant:rathinagiri wrote:Thanks for the info Roberto.
ie: adding this to the button class, you could access 'value' property as in HMG:
Object.defineProperty(this, "value",
get : function()
return control.value;
set : function(val)
control.value = val;
oButton.value = 'New!';
alert( oButton.value );
So, we must miss a wonderful feature because that.
Again... I'm really upset.
If someone knows some trick to get this working in latest IE, any help is greatly welcome.
TIA.
PS: For those discovering that according MSDN it should work, I know, but it doesn't work anyway
That would be really great. Now, that is one of the reasons the market share of IE for getting down.
- HMG Founder
Yes, but, HMGSCRIPT is for the web and about 50% web clients are IE yet, so we can't ignore it.rathinagiri wrote:That would be really great. Now, that is one of the reasons the market share of IE for getting down.
There is lots of people that uses it, simply because it comes with Windows and changing it does not cross their minds
To make the things worst, IE10 will not have a Windows 7 version (only Windows 8) so, there is no hope that an upgrade will solve the problem.
I'll keep searching for a workaround...
- luisfrancisco62
hola a todos:
como podria crear funciones de menu simple?
gracias
gracias
Re: HMGSCRIPT 2012: Programming For The Web in The Right Way :)
Buenisimas Estas Herramientas para el Uso del hrbload!.
Gracias
Gracias
