HMG 3.4.3
Re: HMG 3.4.3
serge_girard wrote: Sat Mar 25, 2017 1:34 pm Claudio,
IDE is doing very strange after 20-30 compilations..!
Can't open project and close box is empty. IDE title is gone away.. See attachment,
Thanks, I will check
HMG 3.4.3
I left IDE open all day and nothing bad happend.
I have compiled with it few times. Probably around 10 times.
I think the problem is like the previous IDE version during successively times in compiling actioned.
Re: HMG 3.4.3
Pablo César wrote: Sat Mar 25, 2017 10:28 pm I left IDE open all day and nothing bad happend.
Sorry but I am somewhat confused, the problem is with the previous version of the IDE or with version 1.2?
Re: HMG 3.4.3
It happens in the recent version of IDE also Claudio.
After sometime, it hangs.
Re: HMG 3.4.3
Rathinagiri wrote: Sun Mar 26, 2017 2:14 am It happens in the recent version of IDE also Claudio.
OK, thanks
Re: HMG 3.4.3
Hi Claudio,
The problem started in the previous IDE version at the time when you introduced debugger option.
The last IDE version free of this problem is v. 1.0.8, all the later versions this problem occurs.
I think debugger its a great ressource but only when is required. Sorry if in some way could offend to you but I guess the debugger would it be seaparated of IDE. To work not on IDE, probably in that way would let our IDE lighter or more objetive. I see that many items in IDE could it be modular, not intrinsically and would find a way to work separately and in one way integrated with its functions. That's was an old idea that would it be nice to have it. Our work bench with the most varied options but working independently.
Sorry to give an opinion without knowing much about it in deep. It's just my vision and opinion, as there is a lot of work to be done in our IDE and to dismember so many functions, it should not be easy. But you could try doing some tests. Can not ?
Re: HMG 3.4.3
I'm going to try compiler the IDE with 3.4.1 without debugger.
Re: HMG 3.4.3
Hi all,
please test this IDE version.
HMG_IDE.1.2a.rar
(3.03 MiB) Downloaded 424 times
Re: HMG 3.4.3
Thanks Claudio, I downloaded and will let you know if problems are solved!
Thanks again, Serge
Re: HMG 3.4.3
Until now the new version of IDE didn't give problems. I will confirm after using tomorrow also.
