HMGSCRIPT 2012: Programming For The Web in The Right Way :)
Re: HMGSCRIPT 2012: Programming For The Web in The Right Way
HMGSCRIPT R31
EDIT: Download link updated to hmgscript.r31b.
- new: setOrder( cOrder ) method for Browse class.
- new: setFilter( cFilter ) method for Browse class.
- changed: Optimized Browse.
- changed: Paged Browse demo.
HMGSCRIPT REFERENCE (R31) - Roberto Lopez (http://www.hmgforum.com)
FORM
Element: DIV
You can use all the properties, events and methods availables for it via DOM.
Syntax:
Form( cCaption , nWidth , nHeight )
Methods:
- release( cValue )
- getId()
Example:
oWin = new Form ( "Window Demo", 600 , 300 );
oWin.release()
BUTTON
Element: INPUT (Type: BUTTON)
Syntax:
Button( oParent , nRow , nCol , cCaption , cOnClick [,nWidth] )
Methods:
- setValue( cValue )
- getValue()
- enable()
- disable()
- getId()
Example:
oBtn = new Button( oForm ,
50 , 240 ,
"Set Btn Value" ,
"oBtn.setValue('New Value')" );
LABEL
Element: SPAN
Syntax:
Label( oParent , nRow , nCol , cValue )
Methods:
- getId()
TEXTBOX
Element: INPUT (Type: TEXT/PASSWORD)
Syntax:
TextBox( oParent , nRow , nCol , cValue , bPassword )
Methods:
- setFocus()
- enable()
- disable()
- getValue()
- setJustify( cAlign )
- getId()
- setAsNumber(nValue)
- getAsNumber()
- setNumericMask ( nIintDigits , nDecimals , cDecimalSeparator ,
cGgroupSeparator , bAllowNegative, bLeftToRight,
cCurrencySymbol )
- setStringMask ( cMask )
# digit
A alphabetic
U uppercase
L lowercase
C capitalize
? any character
\ escape
Notes:
Possible values for cAlign: 'right', 'left', 'center' and 'justify'.
Example:
oText = new TextBox( oForm , 130, 230, "TextBox!" );
alert( oText.getValue() );
EDITBOX
Element: INPUT (Type: TEXTAREA)
Syntax:
EditBox( oParent , nRow , nCol , cValue )
Methods:
- getValue()
- getId()
Example:
oEdit = new EditBox( oForm , 130, 230, "TextBox!" );
alert( oEdit.getValue() );
CHECKBOX
Element: INPUT (Type: CHECKBOX)
Syntax:
CheckBox( oParent , nRow , nCol , xChecked )
Notes:
xChecked parameter can be boolean (true or false) or string ('Yes' or 'No')
Methods:
- check()
- unCheck()
- isChecked()
- getValue()
- getId()
Example:
oCheck = new CheckBox( oForm , 140 , 280 , true );
alert(oCheck.isChecked())
oCheck.check()
oCheck.unCheck()
COMBOBOX
Element: SELECT
You can use all the properties, events and methods availables for them via DOM.
Syntax:
ComboBox( oParent , nRow , nCol , aOptions , aValues [, nSelectedIndex] )
Methods:
- getValue( nIndex )
- setValue( nIndex , cValue )
- setSelectedIndex ( nIndex )
- getSelectedIndex()
- getId()
Example:
oCombo = new ComboBox( oForm , 140 , 270 ,
[ 'one' , 'two' , 'three' ] ,
[ 'value one' , 'value two' , 'value three' ] , 0 );
alert ( oCombo.getSelectedIndex() );
Element: IMAGE
Syntax:
Image( oParent , nRow , nCol , cSrc )
Methods:
- getId()
PANEL
Element: DIV
Syntax:
Panel( oParent , nRow , nCol , nWidth , nHeight , cValue )
Methods:
- getId()
APPEND
Appends a record.
Syntax:
Append( cTable , aColumns , aValues )
Notes:
aValues array. The dates must be specified as ANSI strings.
Logical fields can be specified as boolean or strings ('Yes' or 'No').
The numeric fields can be specified as numbers or strings.
DELETE
Delete records matching the cForExpr.
Syntax:
Delete( cTable , cForExpr )
MODIFY
Modifies records matching the cForExpr.
Syntax:
Modify( cTable , aColumns , aValues , cForExpr )
Notes:
LOGIN
Syntax:
Login( cUser , cPassword )
LOGOUT
Syntax:
Logout()
BROWSE
Elements: DIV/TABLE
Creates an HTML table inside a scrollable DIV, loaded with the specified dbf query.
Syntax:
Browse( oParent , nRow, nCol, nWidth, nHeight, cDbfFile, aColumns,
aHeaders , cForExpr , cOrder , nInnerWidth [,nPageSize] )
Methods:
- refresh()
- getSelectedRows()
- getRowCount()
- select()
- unSelect()
- getCell(nRow,nCount)
- getSelectedRowCount()
- getPageSize()
- loadPage( nPage )
- recordCount()
- setOrder( cOrder )
- setFilter( cFilter )
- getId()
Example:
oBrowse = new Browse( oParent , 050 , 050 , 550 , 300 ,
'test' , [ 'code' , 'first' , 'last' , 'birth' , 'married' ] ,
[ 'Code' , 'First' , 'last' , 'Birth' , 'Married' ] ,
'code < 100' ,
'code' , 700 );
oBrowse.refresh()
QUERY
Returns a recordset from a server table as an array.
Syntax:
Query ( cDbf, aColumns, cForExpr, cOrder )
Example:
aRecordSet = Query ( 'test' ,
'code<=10' , '' );
GRID
Elements: DIV/TABLE
Creates an HTML table inside a scrollable DIV.
Syntax:
Grid( oParent, nRow, nCol, nWidth, nHeight, aHeaders, nInnerWidth )
Methods:
- addRow(aRow)
- getSelectedRows()
- getRowCount()
- select()
- unSelect()
- setCell(nRow,nCount,cValue)
- deleteRow(nRow)
- setJustify(aAlign)
- getId()
Notes:
Possible values for aAlign array: 'right', 'left', 'center' and 'justify'.
Example:
oGrid = new Grid( oWin, 40, 020, 480, 190,
[ 'One' , 'Two' , 'Three' ], 550 );
oGrid.addRow ( [ 'cell 1.1' , 'cell 1.2' , 'Cell 1.3' ] );
RADIOGROUP
Element: INPUT (Type: RADIO)
Syntax:
RadioGroup( oParent , nRow , nCol , aOptions , nSelectedIndex )
Methods:
- getId( nIndex )
Example:
oRadio = new RadioGroup( oForm , 140 , 270 ,
1 );
alert ( oRadio.getSelectedIndex() );
LISTBOX
Element: SELECT
Syntax:
ListBox( oParent , nRow , nCol , aOptions , aValues , nSize [, nSelectedIndex] )
Methods:
- getId()
Example:
oList = new ListBox( oForm , 140 , 270 ,
[ 'value one' , 'value two' , 'value three' ] , 3 , 1 );
alert ( oList.getSelectedIndex() );
SPINNER
Element: INPUT (Type: number)
Syntax:
Spinner( oParent , nRow , nCol , nValue )
Methods:
- setMin( nValue )
- setMax( nValue )
- setStep( nValue )
- getId()
Example:
oSpinner = new Spinner( oWin , 130, 230, 5 );
oSpinner.setMin(1);
oSpinner.setMax(10);
oSpinner.setStep(0.5);
alert( oSpinner.getValue() );
SLIDER
Element: INPUT (Type: range)
Syntax:
Slider( oParent , nRow , nCol , nValue )
Methods:
- setMin( nValue )
- setMax( nValue )
- setStep( nValue )
- getId()
Example:
oSlider = new Slider( oWin , 130, 230, 5 );
oSlider.setMin(1);
oSlider.setMax(100);
oSlider.setStep(50);
alert( oSlider.getValue() );
DATEPICKER
Element: INPUT (Type: DATE)
Syntax:
DatePicker( oParent , nRow , nCol , dValue )
Methods:
- getValue()
- getId()
Example:
oDate = new DatePicker( oForm , 130, 230, "2012-12-31" );
alert( oDate.getValue() );
Enjoy!
hmgscript.r31b.zip
(1.65 MiB) Downloaded 1069 times
Thanks Roberto :)
Best Regards
After R31 release, I'll play pause on development to think on future directions and to learn more about JavaScript.
I'm really happy with the work done.
Ten years after the initial release of MiniGUI library, that allowed us to go to the GUI world, we are going to the web.
The spirit is the same:
- Easy to learn.
- Easy to write.
- Easy to maintain
- Powerful.
This is the xBase spirit.
There is a lot of work to do yet, but, we are ready to create applications and deploy them everywhere, on any device, without care about what OS it uses.
The main library, is extremely easy to expand to satisfy your needs (if required) so, if something is missing for you, you can add it.
Thanks to all for your support.
Enjoy!
esgici wrote:Thanks Roberto :)
Best Regards
Thanks to you for your support!
Hello Roberto
In fact I can't support sufficiently :(
But what I'm stand to you, as always :D
- Easy to learn.
- Easy to write.
- Easy to maintain
- Powerful.
HMG is easy to understan and use, The same principal is continue in HMGSCRIPT
I salute you for your contribution and principal
luisfrancisco62
Post by luisfrancisco62 »
FELCITACIONES desde COLOMBIA
Estimado Roberto,
te informo que en esta versión los metodos getValue no funcionan en CoolNovo version 2.0.2.26 (Chrome) pero en Firefox funcionan correctamente.
Probé la versión r31b.
Saludos cordiales,
Luis Vasquez.
Mirando la consola de javascript de coolnovo, me indica que el error corresponde a que el servidor no responde. No se está ejecutando el uhttp.exe porque no quiero probar el browse sino el resto de los controles.
El ejemplo de Checkbox y Textbox al leer el valor del control ( getValue ) dependen de que uhttp.exe esté funcionando?.
Pienso que no debería ser así, es correcto esto?
Saludos cordiales,
Luis Vasquez.
Saludos cordiales,
Luis Vasquez.
Aquí todo funciona perfectamente y tengo mi Chrome actualizado:
