Thanks!rathinagiri wrote:This is my small contribution to the contrib.js (for grid column alignment)
Usage:
oGrid1.justify( [ 'right', 'left', 'center', 'justify', 'right' ] );
HMGSCRIPT 2012: Programming For The Web in The Right Way :)
- HMG Founder
Re: HMGSCRIPT 2012: Programming For The Web in The Right Way
- HMG Founder
And...rathinagiri wrote:Usage:
Could be better, to be inline with the other methods, if you rename to setJustify.
Ok, Roberto. I will rename.
- luisfrancisco62
- dhaine_adp
Hi Roberto,
Thank you once again for leading HMG into another paradigm and setting a new standard together with HB. This one is truly very HMG. In short span of time a new library emerge as extension to HMG. I truly salute your programming abilities. Thanks for sharing the code with us here at HMG Forum.
Danny
Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
- HMG Founder
Thnaks for yor kind words.dhaine_adp wrote:Hi Roberto,
Danny
- HMG Founder
HMGSCRIPT R28
- new: CheckBox, getValue() and setValue() methods. They accepts and return a string
('Yes' and 'No').
- new: textBox. setFocus() method added.
- changed: Append and Modify functions (aValues array). The dates must be specified as ANSI strings now. Logical fields can be specified as boolean or string ('Yes' or 'No'). The numeric fields
can be specified as numbers or strings.
- changed: Initial value for Checkbox can be boolean or string ('Yes' or 'No').
- fixed: variables scope in library internals.
- changed: Browse demo. It features an append window now. Edit and append, supports all column tyoes now.
- changed: TextBox. setAutoFocus() method eliminated.
- hmgscript.r28.zip
- (1.43 MiB) Downloaded 470 times
That is nice!
Long Live Robertodhaine_adp wrote:
Hi Roberto,
Danny
Method setProperty for LABEL:
sample of use:
Possible properties:
col - column position of a Label
sample: oLabelx.setProperty("col",100);
row - row position of a Label
sample: oLabelx.setProperty("row",240);
fontname - font name of Label
sample: oLabelx.setProperty("fontname","Arial");
fontcolor - font color of Label
sample: oLabelx.setProperty("fontcolor","red");
fontsize - font size of Label
sample: oLabelx.setProperty("fontsize","18");
bold - font bold property
sample: oLabelx.setProperty("bold",true);
italic - font italic property
sample: oLabelx.setProperty("italic",true);
underline - font underline property
sample: oLabelx.setProperty("underline",true);
strikeout - font strikeout property
sample: oLabelx.setProperty("strikeout",true);
// Label
function Label( oParent , nRow , nCol , cValue )
// Create the label on the fly, set its properties and append to the specified
// parent window
var cId = 'control' + (nControlCount).toString() ; nControlCount++ ;
var control = document.createElement( "span" );
control.className = "label" ;
control.style.top = nRow ;
control.style.left = nCol ;
control.innerHTML = cValue ;
control.id = cId ;
document.getElementById( oParent.getId() ).appendChild( control ) ;
this.getId = function ()
return cId;
this.setProperty = function ( cPropertyName, PropertyValue )
if ( cPropertyName.toLowerCase() == 'row' )
document.getElementById(cId).style.top = PropertyValue ;
else if ( cPropertyName.toLowerCase() == 'col' )
document.getElementById(cId).style.left = PropertyValue ;
else if ( cPropertyName.toLowerCase() == 'fontname' )
document.getElementById(cId).style.fontFamily = PropertyValue ;
else if ( cPropertyName.toLowerCase() == 'fontcolor' )
document.getElementById(cId).style.color = PropertyValue ;
else if ( cPropertyName.toLowerCase() == 'fontsize' )
document.getElementById(cId).style.fontSize = PropertyValue ;
else if ( cPropertyName.toLowerCase() == 'bold' )
if (PropertyValue)
document.getElementById(cId).style.fontWeight = 'bold' ;
document.getElementById(cId).style.fontWeight = 'normal' ;
else if ( cPropertyName.toLowerCase() == 'italic' )
if (PropertyValue)
document.getElementById(cId).style.fontStyle = 'italic' ;
document.getElementById(cId).style.fontStyle = 'normal' ;
else if ( cPropertyName.toLowerCase() == 'underline' )
if (PropertyValue)
document.getElementById(cId).style.textDecoration = 'underline' ;
document.getElementById(cId).style.textDecoration = 'none' ;
else if ( cPropertyName.toLowerCase() == 'strikeout' )
if (PropertyValue)
document.getElementById(cId).style.textDecoration = 'line-through' ;
}Code: Select all
oWin = new Form( "Label Demo", 600 , 300 );
oLabelx = new Label( oWin , 100 , 260 , "This is a Label!" );
oLabelx.setProperty("fontsize","20");
oLabelx.setProperty("col",100);col - column position of a Label
