HMGSCRIPT 2012: Programming For The Web in The Right Way :)
Re: HMGSCRIPT 2012: Programming For The Web in The Right Way
Roberto,
Gracias por la libreria...está genial.
ahora, tengo problemas para ejecutar el uhttp.exe.
cambié el número de puerto pero queda en un loop esperando.
con las primeras versiones no tenía ese problema... que será?.
saludos cordiales,
luisvasquezcl wrote:Roberto,
saludos cordiales,
Siempre ha side exactamente el mismo ejecutable con la misma configuración. Nada cambió.
Si cambias el puerto, el firewall pedirá autorización nuevamente y además, si no es el 80 (por ejemplo 2000), deberás indicarlo en la dirección: localhost:2000.
WOW!
More than 1000 downloads in the first 10 hours after R24 publishing.
There are two possible explanations:
1. HMGSCRIPT is becoming a huge worldwide success that will change the web programming history (*)
2. Someone fell asleep while clicking his mouse left button.
(*) Just a joke ;)
THE NEXT STEPS:
I'm very busy with other stuff right now, so these things could take some time, but my main goals are the following:
1. Add classes for RadioGroup and ListBox controls.
2. Work on styles for Grid and Browse.
3. Add more methods for all widgets to have better functionality.
4. Create two more versions of server functions, with the exactly the same syntax as current ones. One will be PHP_DBF and the other PHP_MYSQL (being the current one HRB_DBF). These back-ends should be interchangeable without affecting our application sources. Please, note that having PHP backends we can use any standard hosting service.
5. Extend Browse and Query server functions to allow a secondary (child) table and a set relation expression to be sure that we can handle any situation without the need to create custom server procedures.
As I've said, I'm pretty busy with other works right now, so, all these things could take some time.
So nice of you Roberto.
HMGSCRIPT R25
- New: ListBox control.
- New: RadioGroup control.
- New: Spinner Control.
- New: Slider Control.
- New: DatePicker Control.
- Changed: 'nWidth' optional parameter for Button.
- Changed: Browse and Grid styles (they look very good now!).
- Fixed: IE Browse incompatibility.
- Fixed: IE/FF Grid incompatibility.
This is the updated reference:
HMGSCRIPT 2012 FUNCTION REFERENCE (R25) - Roberto Lopez (http://www.hmgforum.com)
FORM:
Element: DIV
You can use all the properties, events and methods availables for it via DOM.
Syntax:
Form( cCaption , nWidth , nHeight )
Methods:
- release( cValue )
- getId()
Example:
oWin = new Form ( "Window Demo", 600 , 300 );
oWin.release()
BUTTON:
Element: INPUT (Type: BUTTON)
Syntax:
Button( oParent , nRow , nCol , cCaption , cOnClick [,nWidth] )
Methods:
- setValue( cValue )
- getValue()
- getId()
Example:
oBtn = new Button( oForm ,
50 , 240 ,
"Set Btn Value" ,
"oBtn.setValue('New Value')" );
LABEL:
Element: SPAN
Syntax:
Label( oParent , nRow , nCol , cValue )
Methods:
- getId()
TEXTBOX:
Element: INPUT (Type: TEXT)
Syntax:
TextBox( oParent , nRow , nCol , cValue )
Methods:
- getValue()
- getId()
Example:
oText = new TextBox( oForm , 130, 230, "TextBox!" );
alert( oText.getValue() );
EDITBOX:
Element: INPUT (Type: TEXTAREA)
Syntax:
EditBox( oParent , nRow , nCol , cValue )
Methods:
- getValue()
- getId()
Example:
oEdit = new EditBox( oForm , 130, 230, "TextBox!" );
alert( oEdit.getValue() );
CHECKBOX:
Element: INPUT (Type: CHECKBOX)
Syntax:
CheckBox( oParent , nRow , nCol , bChecked )
Methods:
- check()
- unCheck()
- isChecked()
- getId()
Example:
oCheck = new CheckBox( oForm , 140 , 280 , true );
alert(oCheck.isChecked())
oCheck.check()
oCheck.unCheck()
COMBOBOX:
Element: SELECT
You can use all the properties, events and methods availables for them via DOM.
Syntax:
ComboBox( oParent , nRow , nCol , aOptions , aValues [, nSelectedIndex] )
Methods:
- getValue( nIndex )
- setValue( nIndex , cValue )
- setSelectedIndex ( nIndex )
- getSelectedIndex()
- getId()
Example:
oCombo = new ComboBox( oForm , 140 , 270 ,
[ 'one' , 'two' , 'three' ] ,
[ 'value one' , 'value two' , 'value three' ] , 0 );
alert ( oCombo.getSelectedIndex() );
IMAGE:
Element: IMAGE
Syntax:
Image( oParent , nRow , nCol , cSrc )
Methods:
- getId()
PANEL:
Element: DIV
Syntax:
Panel( oParent , nRow , nCol , nWidth , nHeight , cValue )
Methods:
- getId()
APPEND:
Appends a record.
Syntax:
Append( cTable , aColumns , aValues )
DELETE:
Delete records matching the cForExpr.
Syntax:
Delete( cTable , cForExpr )
MODIFY:
Modifies records matching the cForExpr.
Syntax:
Modify( cTable , aColumns , aValues , cForExpr )
LOGIN:
Syntax:
Login( cUser , cPassword )
LOGOUT:
Syntax:
Logout()
BROWSE:
Elements: DIV/TABLE
Creates an HTML table inside a scrollable DIV, loaded with the specified dbf query.
Syntax:
Browse( oParent , nRow, nCol, nWidth, nHeight, cDbfFile, aColumns,
aHeaders , cForExpr , cOrder , nInnerWidth )
Methods:
- refresh()
- getSelectedRows()
- getRowCount()
- select()
- unSelect()
- getCell(nRow,nCount)
- getSelectedRowCount()
- getId()
Example:
oBrowse = new Browse( oParent , 050 , 050 , 550 , 300 ,
'test' , [ 'code' , 'first' , 'last' , 'birth' , 'married' ] ,
[ 'Code' , 'First' , 'last' , 'Birth' , 'Married' ] ,
'code < 100' ,
'code' , 700 );
oBrowse.refresh()
QUERY:
Returns a recordset from a server table as an array.
Syntax:
Query ( cDbf, aColumns, cForExpr, cOrder )
Example:
aRecordSet = Query ( 'test' ,
'code<=10' , '' );
GRID:
Elements: DIV/TABLE
Creates an HTML table inside a scrollable DIV.
Syntax:
Grid( oParent, nRow, nCol, nWidth, nHeight, aHeaders, nInnerWidth )
Methods:
- addRow(aRow)
- getSelectedRows()
- getRowCount()
- select()
- unSelect()
- setCell(nRow,nCount,cValue)
- deleteRow(nRow)
- getId()
Example:
oGrid = new Grid( oWin, 40, 020, 480, 190,
[ 'One' , 'Two' , 'Three' ], 550 );
oGrid.addRow ( [ 'cell 1.1' , 'cell 1.2' , 'Cell 1.3' ] );
RADIOGROUP:
Element: INPUT (Type: RADIO)
Syntax:
RadioGroup( oParent , nRow , nCol , aOptions , nSelectedIndex )
Methods:
- getId( nIndex )
Example:
oRadio = new RadioGroup( oForm , 140 , 270 ,
1 );
alert ( oRadio.getSelectedIndex() );
LISTBOX:
Element: SELECT
Syntax:
ListBox( oParent , nRow , nCol , aOptions , aValues , nSize [, nSelectedIndex] )
Methods:
- getId()
Example:
oList = new ListBox( oForm , 140 , 270 ,
[ 'value one' , 'value two' , 'value three' ] , 3 , 1 );
alert ( oList.getSelectedIndex() );
SPINNER:
Element: INPUT (Type: number)
Syntax:
Spinner( oParent , nRow , nCol , nValue )
Methods:
- setMin( nValue )
- setMax( nValue )
- setStep( nValue )
- getId()
Example:
oSpinner = new Spinner( oWin , 130, 230, 5 );
oSpinner.setMin(1);
oSpinner.setMax(10);
oSpinner.setStep(0.5);
alert( oSpinner.getValue() );
SLIDER:
Element: INPUT (Type: range)
Syntax:
Slider( oParent , nRow , nCol , nValue )
Methods:
- setMin( nValue )
- setMax( nValue )
- setStep( nValue )
- getId()
Example:
oSlider = new Slider( oWin , 130, 230, 5 );
oSlider.setMin(1);
oSlider.setMax(100);
oSlider.setStep(50);
alert( oSlider.getValue() );
DATEPICKER:
Element: INPUT (Type: DATE)
Syntax:
DatePicker( oParent , nRow , nCol , dValue )
Methods:
- getValue()
- getId()
Example:
oDate = new DatePicker( oForm , 130, 230, "2012-12-31" );
alert( oDate.getValue() );
Enjoy!
hmgs025.zip
(1.42 MiB) Downloaded 332 times
Excellant Roberto Sir
luisfrancisco62
Post by luisfrancisco62 »
congratulations
como seria una funcion de menu?
en win7 starter 64 no me funciona el uhttpd.exe
podrias subir los fuentes?
gracias muchas gracias
It is so cool Roberto!
luisfrancisco62 wrote:congratulations
No hay una función 'menu'. La librería usa tecnología estándar, (html, css, javascript) por lo cual puede mezclarse sin problemas con cualquier otro código que use esas tecnologías, si decides hacerlo tu mismo.
No me interesé por el desarrollo de una clase menú, ya que sería muy difícil de usar desde interfaces táctiles, desde donde (en mi opinión) es preferible el uso de botones.
uhttpd.exe está incluido (con código fuente) en la distribución de Harbour (esto se aclara en el archivo 'read.me.first.txt').
Funciona perfectamente a menos que esté bloqueado por el firewall de Windows o que el puerto 80 esté en uso. En ese caso, puede cambiarse desde uhttpd.ini.
