IDE UPDATE (XIIc)
Re: IDE UPDATE (XIIc)
Hello Master Roberto,
I created a small sample and during testing the sample I found the bug :) ;)
Sorry, to give you trouble :(
Again I learned a very good way of debugging. Yes, just create a small sample for the bug we can't solve, in most cases we by ourselves able to solve it :D
Here is my small sample (created with both 2.9.5 and 3.0.0)
GrpRptTest.zip
(3.81 KiB) Downloaded 336 times
While working with this IDE, I get an error:
I've created simple form with 3 buttons in the frame.
I think, this frame causes this error.
I had similar problems with frame in the past.
Here is ErrorLog.htm
Date:2009.11.23 Time: 21:00:51
Error BASE/1003 Variable does not exist: RESULT
Called from EVENTEDIT(42587)
Called from (b)MAIN(944)
Called from EVENTS(2511)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4437)
Called from DOMETHOD(7262)
Called from _OPEN(25047)
Called from EDITFILE(29001)
Called from (b)MAIN(816)
Called from _DOCONTROLEVENTPROCEDURE(4749)
Called from EVENTS(1567)
Called from _ACTIVATEWINDOW(4413)
Called from SHOWLOG(41894)
Called from NEWBUILD(38250)
Called from (b)HMGMAKE(38194)
Called from _PROCESSINITPROCEDURE(4588)
Called from _ACTIVATEWINDOW(4412)
Called from HMGMAKE(38208)
Called from BUILDPROJECTM(35573)
Called from RUNAPPLICATION(30319)
Called from (b)MAIN(501)
Called from EVENTS(1364)
Called from _ACTIVATEWINDOW(4391)
Called from MAIN(965)
Date:2009.11.23 Time: 21:01:18
Date:2009.11.23 Time: 21:04:05
Date:2009.11.23 Time: 21:04:29
This is the reason to ask users for a small sample :) :)
mol wrote:While working with this IDE, I get an error:
It was already reported and I've already fixed.
I'm working on some other little things on IDE now.
I'll publish a fixed version ASAP.
Thanks for the report.
upps!
Sorry, I've missed such an error :)
I think, button "Rebuild" in "Build log" window does not take into account Debug setting.
When I press F8 - Debug and error occours, pressing button rebuild causes building without debugger.
Am I wrong?
mol wrote:I think, button "Rebuild" in "Build log" window does not take into account Debug setting.
Am I wrong?
I'll check it.
Thanks.
