IDE UPDATE (XIf)
fchirico
Re: IDE UPDATE (XIf)
Post by fchirico »
Roberto Lopez wrote:
fchirico wrote:
Roberto Lopez wrote:Hi All,
This release features grouping support in report builder and DECLARE WINDOW <Current Window> statement in new code snippets.
Gracias Roberto!
Perdoname, estuve probando el GROUPING y no lo puedo hacer funcionar, si al reporte le saco el GROUPING funciona, de lo contrario aparece un error:
Date:11/14/09 Time: 21:08:18
Error BASE/1072 Argument error: <>
Called from EXECUTEREPORT(688)
Called from VER(8)
Saludos, Fernando Chircio.
I've found the problem and already fixed.
I'll publish a fixed version ASAP.
Thanks for reporting.
Gracias a vos!
Saludos, Fernando Chirico.
mol wrote: I think, problem is similar to that one, when I tried to print bolded text with internal HMG function.
I've added a little hack in test XII as an attempt to solve the problem with bold Polish characters.
Please, test it.
TIA.
Marek,
I'm really puzzled and frustrated for this, because I've realized that this problem is out of my scope.
So, this is a response to you and a help request from someone that have a clue about this.
I'll explain:
When I edit your report source I see one of the titles in notepad as follows:
When I run the report, the preview looks the same:
So, from my system point of view, I'm printing exactly the same text as it looks in my text editor (I've used notepad to assure a full standard editor).
Any help on this is welcome.
Roberto, I'll try it tomorrow.
Today, I had a hard day.
I've tried my sample with mysql, sqlrdd and odbc.
Some strange results, but I'm in contact with author.
I'm not alone with this problem:
Your problem is the same as:
http://lists.harbour-project.org/piperm ... 25319.html
But I'm unable to develop this additional code for these sql types
(values -8 and -9), since both 4.1 and 5.0 servers return a common char
types for me.
It's not a problem of exe I guess it depends on version of server or
(and) odbc driver, or client version.
Mindaugas
I've got message fromMindaugas Kavaliauskas [dbtopas@dbtopas.lt], but I don't know where to search it
I've just committed a fix to odbcdd.c. Please test if you can.
Mindaugas
I've tried http://sourceforge.net/apps/trac/harbou ... ?rev=12910
but there are only older files...
Thanks for your work. Marek
mol wrote:Roberto, I'll try it tomorrow.
Mindaugas
To download current Harbour sources go to: www.harbour-project.org and download 'Nightly source' (zip).
I saw Mindaugas' impatience and I didn't want to ask him again :)
I didn't work anytime with such a big project as Harbour and I don't know where new files are stored.
So, many thanks, Roberto.
I think, you are like an older brother to us :)
I've downloaded harbour nightly, but it compiles with BCC55. I don't know how to compile it with mingw...
mol wrote:I saw Mindaugas' impatience and I didn't want to ask him again :)
You must create a batch installation file at Harbour tree root folder. Some like this:
set path=c:\mingw\bin
mingw32-make install
You must install a FULL MingW copy too (HMG includes a subset that could be not enough to create Harbour)
I've compiled new harbour, tested my sample, but still error occours.
I have no more time and power to try this.
Maybe I'll back to these tests when stable version of harbour will be ready.
Best regards, Marek
