Xtract - Data Cube - V0.91 (Ready for release!)
Re: Xtract - Data Cube - V0.91 (Ready for release!)
Rathinagiri wrote:Thank you BPD.
I am just developing Xtract as a general UDF for analyzing grid/array/dbf data in a single command call. Please wait for the new release.
Thanks again for your interest.
We can save report format and select from saved list, that will help to un experience user
Hola Rathi : Compilando con HMG.3.1.4 y con el IDE Unicode borra el contenido del archivo de recurso (.rc) y el archivo de configuracion
(.hbc), los iconos no se presentan en el formulario.
Windows 7 Home Premiun 64, HP4530S Core i3 4GB.
adjunto imagenes.
Translate Google
Hi Rathi :Compiling with HMG.3.1.4 and Unicode IDE clears the resource file (. Rc) and the configuration file
(. hbc), the icons do not appear on the form.
Windows 7 Home Premium 64, HP4530S Core i3 4GB.
attached images.
2013-07-29 07_09_46-Extract0.91a.png (146.86 KiB) Viewed 14751 times
2013-07-29 07_13_11-Xtract Window.png (36.73 KiB) Viewed 14751 times
Yes Daniel. The resource file might be corrupted.?!
tonton2
Post by tonton2 »
Bonsoir ,
est ce qu'on peut ajouter un article pour que "SUM" puisse être négative et la possibilité d'additionner différents champs?
grand merci à vous et à toute l'équipe
Hello,
is what we can add an item so that "SUM" can be negative and the ability to add different fields?
big thank you to you and all the team
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
If we enter amount in negative, 'SUM' can also be negative.
Adding different fields? It is a good idea. It is not possible in this design, but we can do.
tonton2
Post by tonton2 »
bonsoir, et merci mon ami
je voulais dire par exemple enlever "MAXIMUM" et le remplacer par un champ numérique multiplier par (-1) et puis faire la différence avec un autre champ dans une des cellules.
good evening,
I mean take for example "MAX" and replace it with a digital field multiplied by (-1) and then make the difference with another field in a cell.
thank you very much my friend :D
Y.TABET
Rathinagiri wrote: Sat Oct 22, 2011 4:33 am Thank you BPD.
Sir,
Updated version is there ?
No sir. But I want to revisit.
