HMG and OpenGL
Source code related resources
Re: HMG and OpenGL
It is not the problem of opengl or windows XP. But the compatibility of opengl and video drivers. I don't know how to solve.
http://support.microsoft.com/kb/285912
Re: HMG and OpenGL
rathinagiri wrote:It is not the problem of opengl or windows XP. But the compatibility of opengl and video drivers. I don't know how to solve.
Hi Rathi
No problem.
It's time for upgrading hardware :)
Please continue your software development for OpengL support in HMG.
Re: HMG and OpenGL
Hello Rathi,
Thanks a lot :)
I tested it.
After building it showed distorted graphics. I closed it. Then I ran again. I showed following picture.
Re: HMG and OpenGL
Yes Sudip, it is the incompatibility of Windows XP graphics drivers and openGL. :(
In Vista, it works fine.
Re: HMG and OpenGL
No problem, friend Rathi. Please continue the project :)
For some reasons, I am not able to test it on Vista right now. Can you please show some image output in Vista? So that, I can understand what it should be.
matthew
Re: HMG and OpenGL
Post by matthew »
Is the OpenGL library still being developed?
I just ran the example on my XP netbook but suffered the same problem other users were having with distorted background imagery. I've done some OpenGL programming in the past & was able to solve the problem by adding the following lines in the c_graphics.c file.
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
glLoadIdentity();
The problem was that the screen wasn't being cleared before drawing, the lines above fix that.
Re: HMG and OpenGL
Oh! That's great. Thanks a lot Mathew!
So, the problem is solved after a very long time! :)
